    updated installer script available for testing
    211 Posts 18 Posters 338.1k Views 19 Watching
      BD0G
      I have a Raspberry Pi Zero W and have installed a fresh image of Raspbian Jesse 20017-07-05. Rebooted. Configured WiFi. Changed default password. Set Time , Timezone, Locale. Rebooted.
      Then opened a terminal window and copied and pasted the command in the first post to install MM2. Install progressed and I recieved the message Cloning MagicMirror Done! Then I received an error “Unable to install dependencies” . I am using an 8 Gig MicroSD card.
      I changed directories to MagicMirror to look for the install.log file, but I cannot find one to upload.
        sdetweil @BD0G
        @BD0G said in Anyone want to try updated installer...:
        install.log is in /home/pi the messages from the installer say that (at the beginning)
        cause the MagicMirror folder doesn’t exist yet
        one other user has experienced this, (mrdenmark, he posted a bunch right before you), and it was the memory card…
          BD0G
          I have ordered a new Micro SD card -16 Gig Class 10 card. That should be large enough and fast enough I imagine. I will repeat the steps to image and use your installer once it arrives. 2 Days from now (Gotta love Amazon Prime).
          I will let you know how it goes. Thanks for the information.
            BD0G
            New Micro SD Card Arrived. I imaged it with Raspian Jesse and attempted the install of Magic Mirror from the command posted in the first post. Same Error.
            Unable to install dependencies.
            Here is a link to the install.log file in my dropbox account.
            https://www.dropbox.com/s/rqhsgvapviqpzrn/install.log?dl=0
            I would appreciate some assistance with troubleshooting this issue.
              sdetweil @BD0G
              @BD0G don’t see the link
              B 1 Reply Last reply
                BD0G @sdetweil
                I was having an issue uploading , but finally got it. I modified my post above to include it.
                S 2 Replies Last reply
                  sdetweil @BD0G
                  @BD0G that is wild… how did that happen
                  installed Nodejs v0.10.29
                  ok, working on it…
                  standby
                    sdetweil @BD0G
                    @BD0G ok, give it a try, same installer script command
                    seems they pulled ANY install support for node on armv6l devices… have to do it manually…
                    now works good on my pi 0 w
                      BD0G
                      So I discovered a bug! Yipeee! I will run the installer again from the first post in this thread and post results!
                      I am making the assumption that I do not have to delete the Magic Mirror directory and sub -directories so I will just install over them. Its a good way to enjoy the morning coffee. Thanks for putting in effort!
                        sdetweil @BD0G
                        @BD0G no… the installer wants to start fresh… just rename the folder out of the way…
                        you can copy any things you added from old to new
                          BD0G
                          It looks like the script realizes that Magic Mirror is already installed and presents a message on screen noting that. I am going to delete the Magic Mirror Directory and sub-directories and run the script again. Pretty slick!
                            sdetweil @BD0G
                            @BD0G yes, correct
                              BD0G
                              I ran it again and same error. Unable to install dependencies. It indicates CXXABI_1.3.9 not found and GLIBCXX_3.4.21 not found
                              Here is the new log file in my dropbox
                              https://www.dropbox.com/s/lsplrd6lytr96fn/install.log?dl=0
                                sdetweil @BD0G
                                @BD0G cool, another unexpected thing… node -v returned nothing!
                                try again please
                                  BD0G
                                  I’m on it!
                                    BD0G
                                    Same error. New Install.log file here
                                    https://www.dropbox.com/s/5vu1cgtf17ij84y/install.log?dl=0
                                      sdetweil @BD0G
                                      @BD0G can u do node -v from command line
                                      also , echo $PATH
                                        BD0G @sdetweil
                                        @sdetweil I dumped the Magic Mirror Directory and Subs in anticipation of reinstalling after script modified. Will that matter?
                                          sdetweil @BD0G
                                          @BD0G no
                                            BD0G
                                            Do you want to know the return of Echo $PATH first?
                                            • 10
                                            • 11
                                            • 5 / 11
