    updated installer script available for testing
    211 Posts 18 Posters 330.9k Views 19 Watching
      BD0G
      New Micro SD Card Arrived. I imaged it with Raspian Jesse and attempted the install of Magic Mirror from the command posted in the first post. Same Error.
      Unable to install dependencies.
      Here is a link to the install.log file in my dropbox account.
      https://www.dropbox.com/s/rqhsgvapviqpzrn/install.log?dl=0
      I would appreciate some assistance with troubleshooting this issue.
        sdetweil @BD0G
        @BD0G don’t see the link
          BD0G @sdetweil
          I was having an issue uploading , but finally got it. I modified my post above to include it.
            sdetweil @BD0G
            @BD0G that is wild… how did that happen
            installed Nodejs v0.10.29
            ok, working on it…
            standby
              sdetweil @BD0G
              @BD0G ok, give it a try, same installer script command
              seems they pulled ANY install support for node on armv6l devices… have to do it manually…
              now works good on my pi 0 w
                BD0G
                So I discovered a bug! Yipeee! I will run the installer again from the first post in this thread and post results!
                I am making the assumption that I do not have to delete the Magic Mirror directory and sub -directories so I will just install over them. Its a good way to enjoy the morning coffee. Thanks for putting in effort!
                  sdetweil @BD0G
                  @BD0G no… the installer wants to start fresh… just rename the folder out of the way…
                  you can copy any things you added from old to new
                    BD0G
                    It looks like the script realizes that Magic Mirror is already installed and presents a message on screen noting that. I am going to delete the Magic Mirror Directory and sub-directories and run the script again. Pretty slick!
                      sdetweil @BD0G
                      @BD0G yes, correct
                        BD0G
                        I ran it again and same error. Unable to install dependencies. It indicates CXXABI_1.3.9 not found and GLIBCXX_3.4.21 not found
                        Here is the new log file in my dropbox
                        https://www.dropbox.com/s/lsplrd6lytr96fn/install.log?dl=0
                          sdetweil @BD0G
                          @BD0G cool, another unexpected thing… node -v returned nothing!
                          try again please
                            BD0G
                            I’m on it!
                              BD0G
                              Same error. New Install.log file here
                              https://www.dropbox.com/s/5vu1cgtf17ij84y/install.log?dl=0
                                sdetweil @BD0G
                                @BD0G can u do node -v from command line
                                also , echo $PATH
                                  BD0G @sdetweil
                                  @sdetweil I dumped the Magic Mirror Directory and Subs in anticipation of reinstalling after script modified. Will that matter?
                                    sdetweil @BD0G
                                    @BD0G no
                                      BD0G
                                      Do you want to know the return of Echo $PATH first?
                                        sdetweil @BD0G
                                        @BD0G u can put all the results in the same response here
                                        also add output of
                                        which node
                                          BD0G @sdetweil
                                          @sdetweil Echo $PATH response is
                                          /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:sbin:/bin:/usr/local/games:/usr/games
                                            BD0G
                                            Here is the reponse from node -v
                                            node: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version CXXABI_1.3.9' not found (required by node) node: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version GLIBCXX_3.4.21’ not found (required by node)
                                            • 10
                                            • 11
                                            • 5 / 11
