    updated installer script available for testing
    211 Posts 18 Posters 313.0k Views 19 Watching
      BD0G
      It looks like the script realizes that Magic Mirror is already installed and presents a message on screen noting that. I am going to delete the Magic Mirror Directory and sub-directories and run the script again. Pretty slick!
        sdetweil @BD0G
        @BD0G yes, correct
          BD0G
          I ran it again and same error. Unable to install dependencies. It indicates CXXABI_1.3.9 not found and GLIBCXX_3.4.21 not found
          Here is the new log file in my dropbox
          https://www.dropbox.com/s/lsplrd6lytr96fn/install.log?dl=0
            sdetweil @BD0G
            @BD0G cool, another unexpected thing… node -v returned nothing!
            try again please
              BD0G
              I’m on it!
                BD0G
                Same error. New Install.log file here
                https://www.dropbox.com/s/5vu1cgtf17ij84y/install.log?dl=0
                  sdetweil @BD0G
                  @BD0G can u do node -v from command line
                  also , echo $PATH
                    BD0G @sdetweil
                    @sdetweil I dumped the Magic Mirror Directory and Subs in anticipation of reinstalling after script modified. Will that matter?
                      sdetweil @BD0G
                      @BD0G no
                        BD0G
                        Do you want to know the return of Echo $PATH first?
                          sdetweil @BD0G
                          @BD0G u can put all the results in the same response here
                          also add output of
                          which node
                            BD0G @sdetweil
                            @sdetweil Echo $PATH response is
                            /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:sbin:/bin:/usr/local/games:/usr/games
                              BD0G
                              Here is the reponse from node -v
                              node: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version CXXABI_1.3.9' not found (required by node) node: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version GLIBCXX_3.4.21’ not found (required by node)
                                BD0G
                                Response from which node is
                                /usr/local/bin/node
                                  sdetweil @BD0G
                                  @BD0G said in Anyone want to try updated installer...:
                                  CXXABI_1.3.9’ not found
                                  always something…
                                  seems jesse is just too old for the version of node we are trying to install…
                                  i did it on stretch (and buster) sucessfully…
                                  as u are just starting, any aversion to stretch or buster?
                                    BD0G
                                    No aversion. Just want to be able to run MM. :) Which do you suggest?
                                      sdetweil @BD0G
                                      @BD0G i’d go with the latest, buster
                                        BD0G
                                        Ok. I will find the image and reimage my micro sd card and then run the install script from the first post and report back. Thanks!
                                        Im going with
                                        Raspbian Buster with desktop and recommended software
                                        Image with desktop and recommended software based on Debian Buster
                                        Version:September 2019
                                        Release date:2019-09-26
                                        Kernel version:4.19
                                        On second thought a smaller image seems more appropriate.
                                        Image with desktop based on Debian Buster
                                        Kernel version:4.19
                                          sdetweil @BD0G
                                          @BD0G yeh, the ‘recommended software’ includes a bunch of office apps , which u don’t need for a mirror system
                                            BD0G
                                            Well that worked! Looks like Jesse is just too long in the tooth to run Magic Mirror2. Thanks again!
                                            • 10
                                            • 11
                                            • 5 / 11
