    updated installer script available for testing
    211 Posts 18 Posters 337.8k Views 19 Watching
      sdetweil @BD0G
      @BD0G no… the installer wants to start fresh… just rename the folder out of the way…
      you can copy any things you added from old to new
        BD0G
        It looks like the script realizes that Magic Mirror is already installed and presents a message on screen noting that. I am going to delete the Magic Mirror Directory and sub-directories and run the script again. Pretty slick!
          sdetweil @BD0G
          @BD0G yes, correct
            BD0G
            I ran it again and same error. Unable to install dependencies. It indicates CXXABI_1.3.9 not found and GLIBCXX_3.4.21 not found
            Here is the new log file in my dropbox
            https://www.dropbox.com/s/lsplrd6lytr96fn/install.log?dl=0
              sdetweil @BD0G
              @BD0G cool, another unexpected thing… node -v returned nothing!
              try again please
                BD0G
                I’m on it!
                  BD0G
                  Same error. New Install.log file here
                  https://www.dropbox.com/s/5vu1cgtf17ij84y/install.log?dl=0
                    sdetweil @BD0G
                    @BD0G can u do node -v from command line
                    also , echo $PATH
                    B 1 Reply Last reply
                      BD0G @sdetweil
                      @sdetweil I dumped the Magic Mirror Directory and Subs in anticipation of reinstalling after script modified. Will that matter?
                        sdetweil @BD0G
                        @BD0G no
                          BD0G
                          Do you want to know the return of Echo $PATH first?
                            sdetweil @BD0G
                            @BD0G u can put all the results in the same response here
                            also add output of
                            which node
                              BD0G @sdetweil
                              @sdetweil Echo $PATH response is
                              /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:sbin:/bin:/usr/local/games:/usr/games
                                BD0G
                                Here is the reponse from node -v
                                node: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version CXXABI_1.3.9' not found (required by node) node: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version GLIBCXX_3.4.21’ not found (required by node)
                                S 2 Replies Last reply
                                  BD0G
                                  Response from which node is
                                  /usr/local/bin/node
                                    sdetweil @BD0G
                                    @BD0G said in Anyone want to try updated installer...:
                                    CXXABI_1.3.9’ not found
                                    always something…
                                    seems jesse is just too old for the version of node we are trying to install…
                                    i did it on stretch (and buster) sucessfully…
                                    as u are just starting, any aversion to stretch or buster?
                                      BD0G
                                      No aversion. Just want to be able to run MM. :) Which do you suggest?
                                        sdetweil @BD0G
                                        @BD0G i’d go with the latest, buster
                                          BD0G
                                          Ok. I will find the image and reimage my micro sd card and then run the install script from the first post and report back. Thanks!
                                          Im going with
                                          Raspbian Buster with desktop and recommended software
                                          Image with desktop and recommended software based on Debian Buster
                                          Version:September 2019
                                          Release date:2019-09-26
                                          Kernel version:4.19
                                          On second thought a smaller image seems more appropriate.
                                          Image with desktop based on Debian Buster
                                          Kernel version:4.19
                                            sdetweil @BD0G
                                            @BD0G yeh, the ‘recommended software’ includes a bunch of office apps , which u don’t need for a mirror system
                                            • 10
                                            • 11
                                            • 5 / 11
