    updated installer script available for testing
    211 Posts 18 Posters 331.0k Views 19 Watching
      BD0G @sdetweil
      @sdetweil Echo $PATH response is
      /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:sbin:/bin:/usr/local/games:/usr/games
        BD0G
        Here is the reponse from node -v
        node: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version CXXABI_1.3.9' not found (required by node) node: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version GLIBCXX_3.4.21’ not found (required by node)
        S 2 Replies Last reply
          BD0G
          Response from which node is
          /usr/local/bin/node
            sdetweil @BD0G
            @BD0G said in Anyone want to try updated installer...:
            CXXABI_1.3.9’ not found
            always something…
            seems jesse is just too old for the version of node we are trying to install…
            i did it on stretch (and buster) sucessfully…
            as u are just starting, any aversion to stretch or buster?
              BD0G
              No aversion. Just want to be able to run MM. :) Which do you suggest?
                sdetweil @BD0G
                @BD0G i’d go with the latest, buster
                  BD0G
                  Ok. I will find the image and reimage my micro sd card and then run the install script from the first post and report back. Thanks!
                  Im going with
                  Raspbian Buster with desktop and recommended software
                  Image with desktop and recommended software based on Debian Buster
                  Version:September 2019
                  Release date:2019-09-26
                  Kernel version:4.19
                  On second thought a smaller image seems more appropriate.
                  Image with desktop based on Debian Buster
                  Kernel version:4.19
                    sdetweil @BD0G
                    @BD0G yeh, the ‘recommended software’ includes a bunch of office apps , which u don’t need for a mirror system
                      BD0G
                      Well that worked! Looks like Jesse is just too long in the tooth to run Magic Mirror2. Thanks again!
                        sdetweil @BD0G
                        @BD0G cool. Thanks for the feedback. Could u post the the install.log to your Dropbox or email to me. Just want to look it over. Need to think about adding info about Jesse now.
                        We need to update electron too (doesn’t work on pi 0 anymore, well armv6l devices)
                          BD0G
                          I am having a heck of a time. I cannot use the local browser to visit my drop box site any longer as it directs me to localhost_/ and there is no web address bar to type the dropbox website into.
                            sdetweil @BD0G
                            @BD0G chrome is being used for the mirror display, as electron no longer works with the later levels of node.
                            I wouldn’t have expected another use to carry over the settings from the mirror task…
                            pm2 stop 0
                            then use chrome
                            them
                            pm2 start 0
                              BD0G
                              Finally got it to work and upload to my dropbox. Stopping Magic Mirror worked and allowed the Chromium browser to access the drop box webpage, but using my standard credentials (which were correct) just timed out on the logon page. I tried this like 20 times. No dice. Finally logged into dropbox using my google account instead and that allowed me to access a dropbox account that I setup using google credentials.
                              Ridiculous!
                              Here is the link to the install.log
                              https://www.dropbox.com/s/425lhitp7tcftih/install.log?dl=0
                              Now on to the fun of making just simple syntax errors in the config.js file when configuring modules only to have Magic Mirror 2 complain that there is no config.js or an error. This process is 100 percent suck!
                                sdetweil @BD0G
                                @BD0G cool, thanks…
                                as for config
                                each module is
                                   module:   "name",
                                   position: "string",
                                   config : {
                                      something: "string",
                                      other_thing: number,
                                      another: true
                                not that each line has a trailing comma
                                number/booleans don’t need quotes,
                                everything else does
                                single or double doesn’t matter, just have to match on a line
                                if troubles
                                do
                                npm run config:check
                                first 1st error, (usually reported on the line AFTER the error )
                                rerun, etc
                                  BD0G
                                  Thanks ! Thats the process I have been using . Painstaking. Small details always cause errors. Even if I cut and paste right from the github repository using the authors code.
                                    sdetweil @BD0G
                                    @BD0G yeh, sometimes/many times they don’t check their doc …
                                    not THAT painstaking
                                    thing on the left of the colon doesn’t need quotes, only words on the right
                                    if something follows something else, the something else better have a trailing comma
                                    I may have found a better way to do the node/npm setup… testing now
                                    it allows node 10 on jesse…
                                    thanks for the trouble report so I could think about the problem
                                      magicmirrorpi4 @sdetweil
                                      @sdetweil I entered this to LXTerminal. Whats the next step i need to do?
                                        sdetweil @magicmirrorpi4
                                        @magicmirrorpi4 u cut/paste the bash-------- )" string into the terminal and hit enter
                                          bdream
                                          Just got Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10 run under Windows 7.
                                          This version of MM is version 2.6.0. I planned to run updatescript from @sdetweil but failed. Have you any idea?
                                          cheers, bdream
                                            sdetweil @bdream
                                            @bdream
                                            what does ‘planned’ mean?
                                            if you DID run my upgrade-script,
                                            can u show me the ~/MagicMirror/installers/upgrade.log
                                            thanks
                                            • 10
                                            • 11
                                            • 6 / 11
