    updated installer script available for testing
    211 Posts 18 Posters 319.4k Views 19 Watching
      BD0G
      I am having a heck of a time. I cannot use the local browser to visit my drop box site any longer as it directs me to localhost_/ and there is no web address bar to type the dropbox website into.
        sdetweil @BD0G
        @BD0G chrome is being used for the mirror display, as electron no longer works with the later levels of node.
        I wouldn’t have expected another use to carry over the settings from the mirror task…
        pm2 stop 0
        then use chrome
        them
        pm2 start 0
          BD0G
          Finally got it to work and upload to my dropbox. Stopping Magic Mirror worked and allowed the Chromium browser to access the drop box webpage, but using my standard credentials (which were correct) just timed out on the logon page. I tried this like 20 times. No dice. Finally logged into dropbox using my google account instead and that allowed me to access a dropbox account that I setup using google credentials.
          Ridiculous!
          Here is the link to the install.log
          https://www.dropbox.com/s/425lhitp7tcftih/install.log?dl=0
          Now on to the fun of making just simple syntax errors in the config.js file when configuring modules only to have Magic Mirror 2 complain that there is no config.js or an error. This process is 100 percent suck!
            sdetweil @BD0G
            @BD0G cool, thanks…
            as for config
            each module is
               module:   "name",
               position: "string",
               config : {
                  something: "string",
                  other_thing: number,
                  another: true
            not that each line has a trailing comma
            number/booleans don’t need quotes,
            everything else does
            single or double doesn’t matter, just have to match on a line
            if troubles
            do
            npm run config:check
            first 1st error, (usually reported on the line AFTER the error )
            rerun, etc
              BD0G
              Thanks ! Thats the process I have been using . Painstaking. Small details always cause errors. Even if I cut and paste right from the github repository using the authors code.
                sdetweil @BD0G
                @BD0G yeh, sometimes/many times they don’t check their doc …
                not THAT painstaking
                thing on the left of the colon doesn’t need quotes, only words on the right
                if something follows something else, the something else better have a trailing comma
                I may have found a better way to do the node/npm setup… testing now
                it allows node 10 on jesse…
                thanks for the trouble report so I could think about the problem
                  magicmirrorpi4 @sdetweil
                  @sdetweil I entered this to LXTerminal. Whats the next step i need to do?
                    sdetweil @magicmirrorpi4
                    @magicmirrorpi4 u cut/paste the bash-------- )" string into the terminal and hit enter
                      bdream
                      Just got Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10 run under Windows 7.
                      This version of MM is version 2.6.0. I planned to run updatescript from @sdetweil but failed. Have you any idea?
                      cheers, bdream
                        sdetweil @bdream
                        @bdream
                        what does ‘planned’ mean?
                        if you DID run my upgrade-script,
                        can u show me the ~/MagicMirror/installers/upgrade.log
                        thanks
                          bdream
                          @sdetweil umpf, yes I started the script but it doesn’t work. So it was a plan not a run :rolling_on_the_floor_laughing:
                          bdream@win7 MINGW64 ~/MagicMirror (master)
                          $ bash -c "$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)"
                          $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
                          $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
                          $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
                          $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
                          $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
                          $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
                          \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
                                                  \______/
                          install log being saved to /c/Users/HikischB/install.log
                          this appears not to be a Raspberry Pi 2 or 3, do you want to continue installation (y/N)?y
                          Updating packages ...
                          bash: line 93: sudo: command not found
                          Update failed, carrying on installation ...
                          Installing helper tools ...
                          bash: line 99: sudo: command not found
                          Seems there is an failure with sudo on my windows machine.
                          Do I need to run as admin for update GIT Bash as admin?
                          cheers, bdream
                            sdetweil @bdream
                            @bdream i don’t think it will run in the CYGWIN or MINW environments
                            you will have to do the manual install
                            see the instructions here https://github.com/MichMich/MagicMirror#manual-installation
                            this also requires sudo, to install nodejs
                            if you succeed, let me know what you did (step by step) and I will consider updating the installer
                              bdream
                              @sdetweil looks like a new workingplace :dizzy_face:
                              I will hang it on for the next time and mark your comment for further usage.
                              1st try to follow the manual installation instruction failed and need more investigatin and understanding on my side
                              bdream@win7 MINGW64 ~ (master)
                              $ curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
                              bash: sudo: command not found
                              cheers, bdream
                                sdetweil @bdream
                                @bdream CYGWIN and MINW don’t allow sudo operations, as they don’t control the machine directly
                                  bdream
                                  @sdetweil yeah, that is I don’t know what and how to do. And it sounds like a big lack of knowledge on my side…
                                  cheers, bdream
                                    sdetweil @bdream
                                    @bdream try, this, may not work
                                    curl -sL https://deb.nodesource.com/setup_10.x | bash -
                                      bdream
                                      @sdetweil it don’t work
                                      $ curl -sL https://deb.nodesource.com/setup_10.x | bash -
                                      ## Installing the NodeSource Node.js 10.x repo...
                                      ## Populating apt-get cache...
                                      + apt-get update
                                      bash: apt-get: command not found
                                      Error executing command, exiting
                                      cheers, bdream
                                        sdetweil @bdream
                                        @bdream yeh, figured
                                        if u have windows 10, you could install the ubuntu support, MM will install and run (in serveronly mode) there.
                                          bdream
                                          then I will start thinking update to Windows10, latest in case I get trouble with MM 2.6.0
                                          cheers, bdream
                                            sdetweil @bdream
                                            @bdream 2.9 is current version.
                                            • 10
                                            • 11
                                            • 6 / 11
