    updated installer script available for testing
    211 Posts 18 Posters 307.6k Views 19 Watching
      sdetweil @BD0G
      @BD0G yeh, the ‘recommended software’ includes a bunch of office apps , which u don’t need for a mirror system
        BD0G
        Well that worked! Looks like Jesse is just too long in the tooth to run Magic Mirror2. Thanks again!
          sdetweil @BD0G
          @BD0G cool. Thanks for the feedback. Could u post the the install.log to your Dropbox or email to me. Just want to look it over. Need to think about adding info about Jesse now.
          We need to update electron too (doesn’t work on pi 0 anymore, well armv6l devices)
            BD0G
            I am having a heck of a time. I cannot use the local browser to visit my drop box site any longer as it directs me to localhost_/ and there is no web address bar to type the dropbox website into.
              sdetweil @BD0G
              @BD0G chrome is being used for the mirror display, as electron no longer works with the later levels of node.
              I wouldn’t have expected another use to carry over the settings from the mirror task…
              pm2 stop 0
              then use chrome
              them
              pm2 start 0
                BD0G
                Finally got it to work and upload to my dropbox. Stopping Magic Mirror worked and allowed the Chromium browser to access the drop box webpage, but using my standard credentials (which were correct) just timed out on the logon page. I tried this like 20 times. No dice. Finally logged into dropbox using my google account instead and that allowed me to access a dropbox account that I setup using google credentials.
                Ridiculous!
                Here is the link to the install.log
                https://www.dropbox.com/s/425lhitp7tcftih/install.log?dl=0
                Now on to the fun of making just simple syntax errors in the config.js file when configuring modules only to have Magic Mirror 2 complain that there is no config.js or an error. This process is 100 percent suck!
                  sdetweil @BD0G
                  @BD0G cool, thanks…
                  as for config
                  each module is
                     module:   "name",
                     position: "string",
                     config : {
                        something: "string",
                        other_thing: number,
                        another: true
                  not that each line has a trailing comma
                  number/booleans don’t need quotes,
                  everything else does
                  single or double doesn’t matter, just have to match on a line
                  if troubles
                  do
                  npm run config:check
                  first 1st error, (usually reported on the line AFTER the error )
                  rerun, etc
                    BD0G
                    Thanks ! Thats the process I have been using . Painstaking. Small details always cause errors. Even if I cut and paste right from the github repository using the authors code.
                      sdetweil @BD0G
                      @BD0G yeh, sometimes/many times they don’t check their doc …
                      not THAT painstaking
                      thing on the left of the colon doesn’t need quotes, only words on the right
                      if something follows something else, the something else better have a trailing comma
                      I may have found a better way to do the node/npm setup… testing now
                      it allows node 10 on jesse…
                      thanks for the trouble report so I could think about the problem
                        magicmirrorpi4 @sdetweil
                        @sdetweil I entered this to LXTerminal. Whats the next step i need to do?
                          sdetweil @magicmirrorpi4
                          @magicmirrorpi4 u cut/paste the bash-------- )" string into the terminal and hit enter
                            bdream
                            Just got Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10 run under Windows 7.
                            This version of MM is version 2.6.0. I planned to run updatescript from @sdetweil but failed. Have you any idea?
                            cheers, bdream
                              sdetweil @bdream
                              @bdream
                              what does ‘planned’ mean?
                              if you DID run my upgrade-script,
                              can u show me the ~/MagicMirror/installers/upgrade.log
                              thanks
                                bdream
                                @sdetweil umpf, yes I started the script but it doesn’t work. So it was a plan not a run :rolling_on_the_floor_laughing:
                                bdream@win7 MINGW64 ~/MagicMirror (master)
                                $ bash -c "$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)"
                                $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
                                $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
                                $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
                                $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
                                $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
                                $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
                                \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
                                                        \______/
                                install log being saved to /c/Users/HikischB/install.log
                                this appears not to be a Raspberry Pi 2 or 3, do you want to continue installation (y/N)?y
                                Updating packages ...
                                bash: line 93: sudo: command not found
                                Update failed, carrying on installation ...
                                Installing helper tools ...
                                bash: line 99: sudo: command not found
                                Seems there is an failure with sudo on my windows machine.
                                Do I need to run as admin for update GIT Bash as admin?
                                cheers, bdream
                                  sdetweil @bdream
                                  @bdream i don’t think it will run in the CYGWIN or MINW environments
                                  you will have to do the manual install
                                  see the instructions here https://github.com/MichMich/MagicMirror#manual-installation
                                  this also requires sudo, to install nodejs
                                  if you succeed, let me know what you did (step by step) and I will consider updating the installer
                                    bdream
                                    @sdetweil looks like a new workingplace :dizzy_face:
                                    I will hang it on for the next time and mark your comment for further usage.
                                    1st try to follow the manual installation instruction failed and need more investigatin and understanding on my side
                                    bdream@win7 MINGW64 ~ (master)
                                    $ curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
                                    bash: sudo: command not found
                                    cheers, bdream
                                      sdetweil @bdream
                                      @bdream CYGWIN and MINW don’t allow sudo operations, as they don’t control the machine directly
                                        bdream
                                        @sdetweil yeah, that is I don’t know what and how to do. And it sounds like a big lack of knowledge on my side…
                                        cheers, bdream
                                          sdetweil @bdream
                                          @bdream try, this, may not work
                                          curl -sL https://deb.nodesource.com/setup_10.x | bash -
                                            bdream
                                            @sdetweil it don’t work
                                            $ curl -sL https://deb.nodesource.com/setup_10.x | bash -
                                            ## Installing the NodeSource Node.js 10.x repo...
                                            ## Populating apt-get cache...
                                            + apt-get update
                                            bash: apt-get: command not found
                                            Error executing command, exiting
                                            cheers, bdream
                                            • 10
                                            • 11
                                            • 6 / 11
