    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 918.5k Views 74 Watching
      BD0G
      Latest version of Magic Mirror on Raspberry Pi Zero W.
      Git cloned directory for MMM-DarkSkyForecast. Directory created under MagicMirror/Modules. Ran npm install. . Installed and mentioned 16 severe vulnerabilities.
      Whatever?
      Modified /config/config.js with entries from git hub repositiory instructions.
      Ran linter against config.js. No lint :)
      Restarted Magic Mirror. Module does not display. Here is my config.js
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	address: "0.0.0.0", // Address to listen on, can be:
      	port: 8080,
      	ipWhitelist: [], // Set [] to allow all IP addresses
      	language: "en",
      	timeFormat: 12,
      	units: "imperial",
      			     // false, default for all  NON-armv6l devices
              		module: 'MMM-Remote-Control',
              		position: 'bottom_left',
                  		apiKey: '56cab4b5d5e24cfea8c436ac591d722c'
        			module: "MMM-DarkSkyForecast",
        			header: "Weather",
        			classes: "default everyone",
        			disabled: false,
          			apikey: "not gonna share it :)",
          			latitude: "39.164581",
          			longitude: "-119.766922",
          			iconset: "4c",
          			concise: false,
          			forecastLayout: "table"
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			header: "US Holidays",
      						symbol: "calendar-check",
      						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
        sdetweil @BD0G
        @BD0G open the developers window ctrl-shift-i on the keyboard. Select the console tab and scroll up to see any errors, usually red text.
          BD0G
          I press CTRL-SHIFT-I with Magic Mirror Running and no console is presented. Actually there is no change at all. Its as if I have not pressed any keys.
            sdetweil @BD0G
            @BD0G the right side should open up as white.
            Do this
            pm2 stop 0
            npm start dev
            That will start mm with the dev window open
              sdetweil @BD0G
              @BD0G last letter is i , lower case (ice), not L lowercase
                BD0G
                Yup. Thats what I pressed CTRL-SHIFT-lowercase i. Nothing. Strange eh? I will try the method above.
                  BD0G
                  Well that did not display the DEV console either. Just Magic Mirror standard display. I have my display rotated 90 degree’s if thats a concern. So its in Portrait Mode essentially and not Landscape.
                    BD0G
                    Ahh looks like the console was behind Magic Mirror and has these entries.
                      sdetweil @BD0G
                      @BD0G yeh, don’t know what happens in portrait mode
                        BD0G
                        [16:51:14.569] [LOG] Starting MagicMirror: v2.10.0-develop
                        [16:51:14.714] [LOG] Loading config …
                        [16:51:14.985] [LOG] Loading module helpers …
                        0 [LOG] Initializing new module helper …
                        0 [LOG] Module helper loaded: MMM-Remote-Control
                        0 [LOG] No helper found for module: MMM-DarkSkyForecast.
                        0 [LOG] No helper found for module: alert.
                        [16:51:16.448] [LOG] Initializing new module helper …
                        [16:51:16.469] [LOG] Module helper loaded: updatenotification
                        [16:51:16.486] [LOG] No helper found for module: clock.
                        [16:51:21.582] [LOG] Initializing new module helper …
                        [16:51:21.589] [LOG] Module helper loaded: calendar
                        0 [LOG] All module helpers loaded.
                        [16:51:21.619] [LOG] Starting server on port 8080 …
                        [16:51:21.765] [INFO] You’re using a full whitelist configuration to allow for all IPs
                        0 [LOG] Server started …
                        0 [LOG] Connecting socket for: MMM-Remote-Control
                        0 [LOG] Starting node helper for: MMM-Remote-Control
                        0 [LOG] Connecting socket for: updatenotification
                        0 [LOG] Connecting socket for: calendar
                        0 [LOG] Starting node helper for: calendar
                        0 [LOG] Sockets connected & modules started …
                        0 [LOG]
                        Ready to go! Please point your browser to: http://0.0.0.0:8080
                        Starting chromium browser now, have patience, it takes a minute
                        [16:51:23.548] [ERROR] { Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                        at Server.setupListenHandle [as _listen2] (net.js:1280:14)
                        at listenInCluster (net.js:1328:12)
                        at doListen (net.js:1461:7)
                        at process._tickCallback (internal/process/next_tick.js:63:19)
                        at Function.Module.runMain (internal/modules/cjs/loader.js:834:11)
                        at startup (internal/bootstrap/node.js:283:19)
                        at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
                        code: ‘EADDRINUSE’,
                        errno: ‘EADDRINUSE’,
                        syscall: ‘listen’,
                        address: ‘0.0.0.0’,
                        port: 8080 }
                        [16:51:29.611] [ERROR] ERROR! Could not find main module js file for MMM-darkSkyForecast
                          sdetweil @BD0G
                          @BD0G said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                          ah, you have the old one running still
                          pm2 start 0
                          check to make sure its shut down
                          ps -ef | grep node
                            BD0G
                            How about I do a full shut down /power off?
                              sdetweil @BD0G
                              @BD0G no… it will autostart on reboot (at least it should)
                                @BD0G but this could be a clue
                                the system is case sensitive…
                                so, the module name in config.js is 'MMM-DarkSkyForecast"
                                (notice u have a lowercase d)
                                the folder in modules, should be the same MMM-DarkSkyForecast ( created from the git clone)
                                  BD0G
                                  Just checked and the module name in the module directory is
                                  MMM-darkSkyForecast and that was created by git cloning as stated in the instructions from the GitHub Repository.
                                  So the name of the directory DOES have a lowercase d in it.
                                    sdetweil @BD0G
                                    @BD0G can’t be
                                    git clone https://github.com/jclarke0000/MMM-DarkSkyForecast.git
                                    will produce folder MMM-DarkSkyForecast
                                      sdetweil @BD0G
                                      @BD0G what are the filenames INSIDE the folder?
                                        BD0G
                                        When I issue the ps -ef | grep node
                                        it returns pi 988 811 3 17:20 pts/0 00:00:00 grep --color=auto node
                                          sdetweil @BD0G
                                          @BD0G ok, and how about
                                          ps -ef | grep chromium
                                            BD0G
                                            Here is the response
                                            pi 904 588 30 17:22 ? 00:00:14 /usr/lib/chromium-browser/chromium-browser --disable-quic --enable-tcp-fast-open --enable-pinch
                                            pi 924 904 3 17:22 ? 00:00:01 /usr/lib/chromium-browser/chromium-browser --type=zygote
                                            pi 926 924 0 17:22 ? 00:00:00 /usr/lib/chromium-browser/chromium-browser --type=zygote
                                            pi 947 904 21 17:22 ? 00:00:08 /usr/lib/chromium-browser/chromium-browser --type=gpu-process --field-trial-handle=7332482715831649297,2455911672236890155,131072 --gpu-preferences=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 --service-request-channel-token=5493558882893021086
                                            pi 951 904 6 17:22 ? 00:00:02 /usr/lib/chromium-browser/chromium-browser --type=utility --field-trial-handle=7332482715831649297,2455911672236890155,131072 --lang=en-US --service-sandbox-type=network --disable-quic --service-request-channel-token=14967951688445977275 --shared-files=v8_context_snapshot_data:100,v8_natives_data:101
                                            pi 1034 926 6 17:23 ? 00:00:01 /usr/lib/chromium-browser/chromium-browser --type=renderer --field-trial-handle=7332482715831649297,2455911672236890155,131072 --lang=en-US --instant-process --enable-offline-auto-reload --enable-offline-auto-reload-visible-only --num-raster-threads=1 --service-request-channel-token=17867901049141360113 --renderer-client-id=7 --no-v8-untrusted-code-mitigations --shared-files=v8_context_snapshot_data:100,v8_natives_data:101
                                            pi 1135 926 15 17:23 ? 00:00:03 /usr/lib/chromium-browser/chromium-browser --type=renderer --field-trial-handle=7332482715831649297,2455911672236890155,131072 --lang=en-US --extension-process --enable-offline-auto-reload --enable-offline-auto-reload-visible-only --num-raster-threads=1 --service-request-channel-token=8805285444412210348 --renderer-client-id=4 --no-v8-untrusted-code-mitigations --shared-files=v8_context_snapshot_data:100,v8_natives_data:101
                                            pi 1189 926 16 17:23 ? 00:00:03 /usr/lib/chromium-browser/chromium-browser --type=renderer --field-trial-handle=7332482715831649297,2455911672236890155,131072 --lang=en-US --extension-process --enable-offline-auto-reload --enable-offline-auto-reload-visible-only --num-raster-threads=1 --service-request-channel-token=2818717241021702166 --renderer-client-id=5 --no-v8-untrusted-code-mitigations --shared-files=v8_context_snapshot_data:100,v8_natives_data:101
                                            pi 1210 947 0 17:23 ? 00:00:00 /usr/lib/chromium-browser/chromium-browser --type=broker
                                            pi 1217 811 0 17:23 pts/0 00:00:00 grep --color=auto chromium
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 13 / 17
