    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 921.7k Views 74 Watching
      BD0G
      How about I do a full shut down /power off?
        sdetweil @BD0G
        @BD0G no… it will autostart on reboot (at least it should)
          @BD0G but this could be a clue
          Could not find main module js file for MMM-darkSkyForecast
          the system is case sensitive…
          so, the module name in config.js is 'MMM-DarkSkyForecast"
          (notice u have a lowercase d)
          the folder in modules, should be the same MMM-DarkSkyForecast ( created from the git clone)
            BD0G
            Just checked and the module name in the module directory is
            MMM-darkSkyForecast and that was created by git cloning as stated in the instructions from the GitHub Repository.
            So the name of the directory DOES have a lowercase d in it.
              sdetweil @BD0G
              @BD0G can’t be
              git clone https://github.com/jclarke0000/MMM-DarkSkyForecast.git
              will produce folder MMM-DarkSkyForecast
                sdetweil @BD0G
                @BD0G what are the filenames INSIDE the folder?
                  BD0G
                  When I issue the ps -ef | grep node
                  it returns pi 988 811 3 17:20 pts/0 00:00:00 grep --color=auto node
                    sdetweil @BD0G
                    @BD0G ok, and how about
                    ps -ef | grep chromium
                      BD0G
                      Here is the response
                      pi 904 588 30 17:22 ? 00:00:14 /usr/lib/chromium-browser/chromium-browser --disable-quic --enable-tcp-fast-open --enable-pinch
                      pi 924 904 3 17:22 ? 00:00:01 /usr/lib/chromium-browser/chromium-browser --type=zygote
                      pi 926 924 0 17:22 ? 00:00:00 /usr/lib/chromium-browser/chromium-browser --type=zygote
                      pi 947 904 21 17:22 ? 00:00:08 /usr/lib/chromium-browser/chromium-browser --type=gpu-process --field-trial-handle=7332482715831649297,2455911672236890155,131072 --gpu-preferences=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 --service-request-channel-token=5493558882893021086
                      pi 951 904 6 17:22 ? 00:00:02 /usr/lib/chromium-browser/chromium-browser --type=utility --field-trial-handle=7332482715831649297,2455911672236890155,131072 --lang=en-US --service-sandbox-type=network --disable-quic --service-request-channel-token=14967951688445977275 --shared-files=v8_context_snapshot_data:100,v8_natives_data:101
                      pi 1034 926 6 17:23 ? 00:00:01 /usr/lib/chromium-browser/chromium-browser --type=renderer --field-trial-handle=7332482715831649297,2455911672236890155,131072 --lang=en-US --instant-process --enable-offline-auto-reload --enable-offline-auto-reload-visible-only --num-raster-threads=1 --service-request-channel-token=17867901049141360113 --renderer-client-id=7 --no-v8-untrusted-code-mitigations --shared-files=v8_context_snapshot_data:100,v8_natives_data:101
                      pi 1135 926 15 17:23 ? 00:00:03 /usr/lib/chromium-browser/chromium-browser --type=renderer --field-trial-handle=7332482715831649297,2455911672236890155,131072 --lang=en-US --extension-process --enable-offline-auto-reload --enable-offline-auto-reload-visible-only --num-raster-threads=1 --service-request-channel-token=8805285444412210348 --renderer-client-id=4 --no-v8-untrusted-code-mitigations --shared-files=v8_context_snapshot_data:100,v8_natives_data:101
                      pi 1189 926 16 17:23 ? 00:00:03 /usr/lib/chromium-browser/chromium-browser --type=renderer --field-trial-handle=7332482715831649297,2455911672236890155,131072 --lang=en-US --extension-process --enable-offline-auto-reload --enable-offline-auto-reload-visible-only --num-raster-threads=1 --service-request-channel-token=2818717241021702166 --renderer-client-id=5 --no-v8-untrusted-code-mitigations --shared-files=v8_context_snapshot_data:100,v8_natives_data:101
                      pi 1210 947 0 17:23 ? 00:00:00 /usr/lib/chromium-browser/chromium-browser --type=broker
                      pi 1217 811 0 17:23 pts/0 00:00:00 grep --color=auto chromium
                        BD0G @sdetweil
                        Pinky Swear!
                        It did produce a directory with a lowercase d in the name.
                        Here is listing of the directories under modules
                        pi@raspberrypi:~/MagicMirror/modules $ dir
                        default MMM-darkSkyForecast MMM-Remote-Control node_modules README.md
                          sdetweil @BD0G
                          @BD0G ok,
                          pm2 stop 0
                          should have worked
                          sudo killall chromium-browser
                            sdetweil @BD0G
                            @BD0G said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                            MMM-darkSkyForecast
                            thanks…
                            ls ~/MagicMirror/modules/MMM-darkSkyForecast
                              BD0G @sdetweil
                              I ran the sudo killall chromium-browser and response was
                              chromium-browser : no process found
                                sdetweil @BD0G
                                @BD0G ok
                                sudo killall /usr/lib/chromium-browser/chromium-browser
                                  BD0G
                                  That killed the browser window I had open and then returned to the command prompt
                                    sdetweil @BD0G
                                    @BD0G ok, and the ls results
                                    I work from my windows machine and ssh into the pi.
                                    use bitvise ssh client… opens a terminal window and a file browser window at the same time…
                                    double click on files to edit
                                    commands in the ssh window… almost never go to the actual mirror screen, except for the dev window
                                      BD0G
                                      ls results? You lost me there. ssh has been painfully slow when using Putty.
                                        sdetweil @BD0G
                                        @BD0G back a few messages
                                          BD0G
                                          Here it is
                                          pi@raspberrypi:~/MagicMirror/modules $ ls ~/MagicMirror/modules/MMM-darkSkyForecast
                                          icons node_helper.js README.md
                                          MMM-DarkSkyForecast.css node_modules skycons.js
                                          MMM-DarkSkyForecast.js package.json
                                          mmm-darksky-forecast.njk package-lock.json
                                            sdetweil @BD0G
                                            file name is uppercase D
                                            all has to match
                                            change the name of the folder and the entry in config.js
                                            S B 2 Replies Last reply Reply Quote 0
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 13 / 17
