MMM-FHEM
14 Posts 6 Posters 8.9k Views 6 Watching
    cpramhofer
    Hi All, and happy Sunday!
    has anyone of you running this module with a FHEM server running on another machine?
    i tried it with the following config but i can’t finde anything on the screen. the module is installed as i can see that it is listening to events in the debug mode.
                        module: 'MMM-FHEM',
                        position: 'top_left',
                        host: '10.0.0.110',
                         deviceNames: [
                                'CUL_WS_1',
                                'CUL_WS_2'
                        deviceReadings: [
                                { name: 'temperature', icon: 'wi wi-thermometer', suffix: '°' },
                                { name: 'humidity', icon: 'wi wi-humidity', suffix: '%' }
    FHEM is also up and running:
    Thanks a lot
    Christoph
    • G Offline
      gismo2006
      @cpramhofer I didn’t know anythink about FEHM yet. But I look at your posted code and remember you write: “has anyone of you running this module with a FHEM server running on another machine?” And then I think about the line:
      host: ‘10.0.0.110’,
      Is it really the Host? It looks like a Ip. In this case is it correct?
      But, you have to know I’m didn’t use FEHM yet, and didn’t know about the config.
      By the way the FEHM serve you ran is reacheable from the Mirror IP?
      Greets gismo
        schienw
        yes, it work’s.
        Here is my configfile:
        deviceNames: [
        ‘Bad’,
        ‘Wohnzimmer’,
        ‘Kueche’,
        host: [‘192.168.178.87’],
        deviceReadings: [
        { name: ‘temperature’, icon: ‘wi wi-thermometer’, suffix: ‘°’ },
        Regards
        Schienw
          cpramhofer
          @gismo2006 yes, in the readme file host is defined as an IP address. I can access FHEM from the MM Pi.
          @schienw great! i will try host as an array too…
          have a nice day!
          • G Offline
            gismo2006
            Hi, OK, if the op is correct, try the other post.
            God luck! :-)
            I will happy if you post what happens. …
              cpramhofer
              Hi all,
              i tried the setup with the following config but again, nothing is showing up on the mirror.
              module: ‘MMM-FHEM’,
                                   deviceNames: [
                                          'CUL_WS_1',
                                          'CUL_WS_2'
                                  host: ['10.0.0.110'],
                                  deviceReadings: [
              kind regards
              Christoph
              • G Offline
                gismo2006
                Hmm… I can´t stop asking is 10.0.0.110 really the host ip of your FEHM server? Usually in privat Networks is used something like 192.178.168.2 the number one at the end op this Ip is served for your internet router… All devices then will become a other number at this end…
                greets gismo
                Y 1 Reply Last reply Oct 18, 2016, 9:58 AM Reply Quote 0
                  cpramhofer
                  Hi Gismo,
                  Yes it is the correct IP
                  Its a an Austrian Network from the Provider A1.
                  The Router has the ip 10.0.0.138
                  Magic Mirror runs in 10.0.0.101
                  FHEM on 10.0.0.110 (as you also can see on the screenshot above)
                  • Y Offline
                    yawns Moderator @gismo2006
                    @gismo2006
                    192.168.x.x is a private Class C network
                    10.0.0.x is a private class A network
                    As you see on the screenshot cpramhofer is able to connect to the management website in a browser, so the IP address should not be the problem.
                    • G Offline
                      gismo2006
                      Oh ok, Sorry I didn´t see it in the posted screenshot till you write it. Hmm, then I couldn´t help… :-)
