    MMM-FHEM
    14 Posts 6 Posters 10.1k Views 6 Watching
      schienw
      yes, it work’s.
      Here is my configfile:
      deviceNames: [
      ‘Bad’,
      ‘Wohnzimmer’,
      ‘Kueche’,
      host: [‘192.168.178.87’],
      deviceReadings: [
      { name: ‘temperature’, icon: ‘wi wi-thermometer’, suffix: ‘°’ },
      Regards
      Schienw
        cpramhofer
        @gismo2006 yes, in the readme file host is defined as an IP address. I can access FHEM from the MM Pi.
        @schienw great! i will try host as an array too…
        have a nice day!
        • G Offline
          gismo2006
          Hi, OK, if the op is correct, try the other post.
          God luck! :-)
          I will happy if you post what happens. …
            cpramhofer
            Hi all,
            i tried the setup with the following config but again, nothing is showing up on the mirror.
            module: ‘MMM-FHEM’,
                                 deviceNames: [
                                        'CUL_WS_1',
                                        'CUL_WS_2'
                                host: ['10.0.0.110'],
                                deviceReadings: [
                                        { name: 'temperature', icon: 'wi wi-thermometer', suffix: '°' },
            kind regards
            Christoph
            • G Offline
              gismo2006
              Hmm… I can´t stop asking is 10.0.0.110 really the host ip of your FEHM server? Usually in privat Networks is used something like 192.178.168.2 the number one at the end op this Ip is served for your internet router… All devices then will become a other number at this end…
              greets gismo
                cpramhofer
                Hi Gismo,
                Yes it is the correct IP
                Its a an Austrian Network from the Provider A1.
                The Router has the ip 10.0.0.138
                Magic Mirror runs in 10.0.0.101
                FHEM on 10.0.0.110 (as you also can see on the screenshot above)
                • yawnsY Offline
                  yawns Moderator @gismo2006
                  @gismo2006
                  192.168.x.x is a private Class C network
                  10.0.0.x is a private class A network
                  As you see on the screenshot cpramhofer is able to connect to the management website in a browser, so the IP address should not be the problem.
                  • G Offline
                    gismo2006
                    Oh ok, Sorry I didn´t see it in the posted screenshot till you write it. Hmm, then I couldn´t help… :-)
                      schienw
                      hello,
                      can you try a , behind
                      ‘CUL_WS_1’,
                      ‘CUL_WS_2’
                      you have:
                      deviceNames: [
                      ‘CUL_WS_1’,
                      ‘CUL_WS_2’
                      and i have
                      deviceNames: [
                      ‘Bad’,
                      ‘Wohnzimmer’,
                      ‘Kueche’,
                      schienw
                        cpramhofer
                        Hi All,
                        i´m sorry for not responding. i have currently no access to my system. i will give you feedback as soon i had a chance to test the version with the comma.
