    MMM-FHEM
    14 Posts 6 Posters 10.8k Views 6 Watching
    • G Offline
      gismo2006
      Hi, OK, if the op is correct, try the other post.
      God luck! :-)
      I will happy if you post what happens. …
        cpramhofer
        Hi all,
        i tried the setup with the following config but again, nothing is showing up on the mirror.
        module: ‘MMM-FHEM’,
                             deviceNames: [
                                    'CUL_WS_1',
                                    'CUL_WS_2'
                            host: ['10.0.0.110'],
                            deviceReadings: [
                                    { name: 'temperature', icon: 'wi wi-thermometer', suffix: '°' },
        kind regards
        Christoph
        • G Offline
          gismo2006
          Hmm… I can´t stop asking is 10.0.0.110 really the host ip of your FEHM server? Usually in privat Networks is used something like 192.178.168.2 the number one at the end op this Ip is served for your internet router… All devices then will become a other number at this end…
          greets gismo
            cpramhofer
            Hi Gismo,
            Yes it is the correct IP
            Its a an Austrian Network from the Provider A1.
            The Router has the ip 10.0.0.138
            Magic Mirror runs in 10.0.0.101
            FHEM on 10.0.0.110 (as you also can see on the screenshot above)
            • Y Offline
              yawns Moderator @gismo2006
              @gismo2006
              192.168.x.x is a private Class C network
              10.0.0.x is a private class A network
              As you see on the screenshot cpramhofer is able to connect to the management website in a browser, so the IP address should not be the problem.
              • G Offline
                gismo2006
                Oh ok, Sorry I didn´t see it in the posted screenshot till you write it. Hmm, then I couldn´t help… :-)
                  schienw
                  hello,
                  can you try a , behind
                  ‘CUL_WS_1’,
                  ‘CUL_WS_2’
                  you have:
                  deviceNames: [
                  ‘CUL_WS_1’,
                  ‘CUL_WS_2’
                  and i have
                  deviceNames: [
                  ‘Bad’,
                  ‘Wohnzimmer’,
                  ‘Kueche’,
                  schienw
                    cpramhofer
                    Hi All,
                    i´m sorry for not responding. i have currently no access to my system. i will give you feedback as soon i had a chance to test the version with the comma.
                    • strawberry 3.141S Offline
                      strawberry 3.141 Project Sponsor Module Developer @cpramhofer
                      @cpramhofer the last comma will not make a difference.
                      normally a comma at the end is a syntax error, but meanwhile the engines kind of ignore it and handle it correctly
                      it’s like in human languages if you write a list, you will not write buy me eggs, cake, ham,
                        DirkS
