    MMM-CalendarExt2
    486 Posts 83 Posters 1.1m Views 83 Watching
      jani.karna
      I’m trying to use local .ics file for two of my calendars. They are holiday calendars that stay the same throughout the year so they don’t need to be fetched from the web. I just can’t get them to work.
      I get the same error message on both of them:
      [CALEXT2] calendar: Suomen juhlapyhät >> write EPROTO 1936543760:error:1408F10B:SSL routines:ssl3_get_record:wrong version number:../../vendor/node/deps/openssl/openssl/ssl/record/ssl3:record.c:252:
      My url looks like this:
      url: "https://192.168.1.187:8080/Pyhat.ics",
      I tried using
      localhost:8080
      but it tried to force 127.0.0.1 which don’t work.
        A Former User @jani.karna
        @jani-karna
        Well, it’s not the issue of my module, anyway…
        It seems, your RPI is not available to handle SSL of itself.
        Can you open “https://192.168.1.187:8080/Pyhat.ics” or “https://localhost:8080/Pyhat.ics” on the browser of your RPI when MM is running?
        Try “http” instead of “https”
          jani.karna
          Have to see if the problem comes back after RPI reinstall. It seems my SD-card just came to the end of its life.
            jani.karna
            I finally had a chance trying this. By trying “https://192.168.1.187:8080/Pyhat.ics” with browser while MM is running I get “ERR_SSL_PROTOCOL_ERROR”. I have no idea how to solve this. “Localhost” gives a little different error, but so does MM. But neither of them work. I know it is not about your module, but if you have any suggestions I’d be glad to hear.
              @jani-karna
              try http instead of https
                @jani-karna
                put your ical file into ~/MagicMirror/modules/MMM-CalendarExt2 then, try to use this URL;
                http://localhost:8080/modules/MMM-CalendarExt2/Pyhat.ics
                  jani.karna
                  @Sean said in MMM-CalendarExt2:
                  For some reason “localhost” tries to use 127.0.0.1 which gives error, but I tried “http://192.168.1.187:8080/modules/MMM-CalendarExt2/Pyhat.ics” and that worked! Thank you!
                  • BKeyportB Offline
                    BKeyport Module Developer
                    Hey, Just started using this module, and today’s update blew up everything… It and MMM-CalendarExtMinimonth fails now.
                    Am I doing something wrong?
                    			module: 'MMM-CalendarExt2',
                    					calendars : [
                    							url: "https://calendar.google.com/calendar/ical/mycalendar/info/basic.ics",
                    							name: "Main Calendar", // Optional, Recommended
                    							maxItems: 100,
                    							scanInterval: 1000*60*1, // 1000*Seconds*minutes
                    							beforeDays: 0,
                    							afterDays: 999,
                    							maxIterations: 100,
                    							forceLocalTZ: false,
                    					views: [
                    							mode: "daily",
                    							position: "top_center",
                    							slotCount: 20,
                    					scenes: [
                    			module: "MMM-CalendarExtMinimonth",
                    			position: "bottom_right",
                    			refreshInterval: 60*2.5*1000,
                    Thanks!
                      A Former User @BKeyport
                      @BKeyport
                      Sorry, Yesterday I fixed something but it made another bug. I fixed it now.
                      • BKeyportB Offline
                        Thanks, that fixed it.
                        The only thing I can’t figure out then is massive space between the end of the previous day’s activities, and the next day.
                        Is there a way to solve this? Loving it otherwise.
                          @BKeyport
                          Controll that margin with hideOverflow and slotMaxHeight .
                          https://github.com/eouia/MMM-CalendarExt2/wiki/2c.-Configuration:View
                            Mariba
                            I’m really satisfied with this module. Thank you.
                            Although, I’m facing an issue. I want to display two calendars in the same view and same scene. The calendars just won’t show. It works individually but not together.
                            Replace My URL with the original url. Sorry for the indentations.
                            My config:
                            url: "My URL",
                            url: "my URL",
                            views: [
                            title: "Calendar",
                            mode: "daily", fromNow:2, slotCount:2,
                            type: "row",
                            position: "upper_third",
                            calendars: ["Regular", "University"],
                            scenes: [
                            My CSS:
                            body {
                            /* .CX2 .slot .event {
                            background: inherit;
                             .CX2 .slot .slotHeader {
                            background-color: inherit;
                            text-transform: uppercase;
                            font-size: 12px;
                            font-family: "Roboto Condensed", Arial, helvetica, sans-serif;
                            font-weight: 400;
                            color: #999;
                            .CX2 .event[data-calendar-name="Regular"] {
                            border-left: #0098e9 solid;
                            .CX2 .event[data-calendar-name="University"] {
                            border-left: #60bb41 solid;
                              mrmagoo_83
                              Don’t you need to call out the view name the scene?
                                A Former User @Mariba
                                @Mariba
                                Well, I haven’t inspected your code yet, but most of the cases, it would be maxItems issue of view. For the performance, default maxItems of view is set to 100. If your calendars might have many events, set that option to a bigger value. You can estimate the number needed with your serverside log.
                                • BKeyportB Offline
                                  BKeyport Module Developer @Guest
                                  @Sean Neither of those are what I would want. No matter how many items I have, there is a space there. I want to rid myself of the excess blank space, so that I can fit more real items into the display. When the day is empty there is very little space between days.
                                    Mariba @Guest
                                    @Sean Hello,
                                    I tried with maxItems set to 10. I’m definitely sure that I dont have more than 8 items with the calendars combined. It still doesn’t solve the problem.
                                      mrmagoo_83
                                      How does one replace a parentheses in the title of an event?
                                      • BKeyportB Offline
                                        BKeyport Module Developer @mrmagoo_83
                                        @mrmagoo_83 Regex would be “\(” and “\)” to find both.
                                          @BKeyport
                                            @Mariba
                                            In that case, I should have real data to inspect.
                                            • 24
                                            • 25
                                            • 6 / 25
