    expressApp.get - Error Cannot GET ...
    4 Posts 2 Posters 1.4k Views 2 Watching
    • spitzlbergerjS Offline
      spitzlbergerj Project Sponsor Module Developer
      I intercept a webservice call via node_helper.js. Now I wanted to handle two more webservice calls. Unfortunately this doesn’t work.
      my code:
      const NodeHelper = require("node_helper")
      var async = require('async');
      var exec = require('child_process').exec;
      var express = require('express');
      var app = express();
      	start: function() {
      		//console.error('Starting node helper: ' + this.name);
      		var self = this;
      		// Updateinterval ändern über Aufruf http://127.0.0.1:8080/MMM-CaravanPiPosition/changeUpdateInterval
      		this.expressApp.get('/' + this.name + '/changeUpdateInterval', function (req, res) {
      			res.send('Change UpdateInterval from '+ myUpdateInterval);
      			self.changeUpdateInterval();
      		// Kalibrierung anzeigen über Aufruf http://127.0.0.1:8080/MMM-CaravanPiPosition/setCalibration
      		this.expressApp.get('/' + this.name + '/setCalibration', function (req, res) {
      			res.send('set Calibration');
      			valueListNHCaravanPiPosition[0]["cal"] = 1;
      		// Kalibrierung löschen über Aufruf http://127.0.0.1:8080/MMM-CaravanPiPosition/unsetCalibration
      		this.expressApp.get('/' + this.name + '/unsetCalibration', function (req, res) {
      			res.send('unset Calibration');
      			valueListNHCaravanPiPosition[0]["cal"] = 0;
      The call of http://127.0.0.1:8080/MMM-CaravanPiPosition/changeUpdateInterval works as desired.
      The calls of http://127.0.0.1:8080/MMM-CaravanPiPosition/setCalibration and … unsetCalibration does not work.
      Instead the error message Cannot GET /MMM-CaravanPiPosition/setCalibration is displayed.
      what am i doing wrong? can’t several different webservice calls be processed?
      Thanks for every help
      Sepp
      Regards
      Josef
      http://www.spitzlberger.de/smartmirror, https://github.com/spitzlbergerj/MMM-TeslaLogger, https://github.com/spitzlbergerj/CaravanPi, https://www.la-gondola-barocca.de
        sdetweil @spitzlbergerj
        @spitzlbergerj said in expressApp.get - Error Cannot GET ...:
        this.expressApp.
        where is expressApp set?
        typically it is
        const app = express()
          // setup the pattern you listen for
          app.get(url_pattern, (req,res) => {})
          Hi Sam,
          yes, I had always asked myself that, but I am still a Javascript Newby. I got the code from a forum post. After it worked with the first pattern, I thought, that’s because of my low JavaScript knowledge.
          I have now changed it with your help. And now it works.
          Thank you very much!
          Sepp
          Regards
          Josef
            @spitzlbergerj cool!!
