Solved config
@cowboysdude can it be copied to the config sample
@geo you do not want to copy over the sample…
@La7dan hi,mm not opening now on boot.
i have the cal and clock on uk time with us hols,would like the news to be uk,i dont have the weather.
thx -
try
pm2 start 0
is the magicmirror working ?
@geo has it always not been opening on boot?
use this script to fix that
see here
https://forum.magicmirror.builders/topic/10907/new-script-to-install-fix-pm2-config-for-start-on-bootif the mm won’t start at all, that is a different problem
new on uk… which news source do you want? open their page, and scroll down to the bottom… thy usually list rss feeds
@La7dan just use pm2
@sdetweil true service could be confusing
@geo http://rss.cnn.com/services/podcasting/cnn10/rss.xml
this is an example for CNN news/. -
@La7dan use the search feature on your favorite news site… here from the bbc, to find an rss feed to put into the news config
@La7dan hi sorry for the delay the mm is up and running
