    The mirror that wasn't a mirror
    25 Posts 10 Posters 25.7k Views 10 Watching
      bhepler Module Developer @DazDavid
      @DazDavid Please post the relevant portion of your config.js file. That is a good place to start. Also please use the markdown commands to make your code easier for us to read.
        DazDavid @bhepler
        @bhepler
        Yes you are right, sorry my fault.
        So I copied the example from the github Page and just entered my Api Key to make sure the Module is working with basic Informations.
        This is the appropriate part of my config:
            module: 'MMM-Traffic',
            position: 'bottom_bar',
            classes: 'dimmed medium', //optional, default is 'bright medium', only applies to commute info not route_name
                api_key: '******',
                mode: 'driving',
                origin: '4 Pennsylvania Plaza, New York, NY 10001',
                destination: '1 MetLife Stadium Dr, East Rutherford, NJ 07073',
                arrival_time: '0800', //optional, but needs to be in 24 hour time if used.
                route_name: 'Home to Work',
                changeColor: true,
                showGreen: false,
                limitYellow: 5, //Greater than 5% of journey time due to traffic
                limitRed: 20, //Greater than 20% of journey time due to traffic
                traffic_model: 'pessimistic',
                interval: 120000 //2 minutes
        Edit: Like this the mirror stucks on “Loading Commute” and the mentioned error is shown on console output continuously. Any idea what could be the Problem?
          Mitchfarino Module Developer @DazDavid
          @DazDavid
          @Notumlord had a similar issue, and when they changed the locations it worked fine
          Not sure if they’ve made any progress with is - https://forum.magicmirror.builders/topic/446/trafficmaps/36
            DazDavid @Mitchfarino
            @Mitchfarino thanks for the hint but I´m not sure how exactly to enter the locations. Does anybody have an example for germany? I assume it would be street & no, postalcodd city. So for example Hauptstraße 15, 99090 Erfurt.
            Is that correct?
              @DazDavid how do you do it usually in Google maps? In the UK I can just put in the postcode and it works.
              Go to Google maps, place a pin on your destination and copy the address that it generates.
              See if that works
                @Mitchfarino i copied from Maps before and now I tryied only with postalcode and Postalcode + City name but still get the same error as written above. I think I have to contact the developer of the module.
                  @DazDavid try these postcodes
                  SE1 9SP
                  SW1A 1AA
                  See if it gets through the loading commute message
                    DazDavid
                    ok, somebody opened a bug report for this problem 20h hours ago so I think im not the only affected person :)
                      @Mitchfarino Not working also
                        DazDavid
                        My Problem was solved by the developer. The API Key was not valid. For everybody else with this problem here is a link to test your Key. If it is not valid just create a new one:
                        Replace <API_KEY> with your Key:
                        https://maps.googleapis.com/maps/api/directions/json?origin=toledo ohio&destination=san antonio texas&key=<API_KEY>
                        Thanks for everybodys help.
                          DazDavid
                          Maybe somebody can point me in the right direction with another problem… How do I link to a local calendar file? I tried different ways but non worked. Also SMB would be a possibility. How should the syntax look like?
                          • cowboysdudeC Offline
                            VERY nice!! See just not for mirrors anymore :) That’s why I built my mini alarm clock using MM2 :)
