    MMM-CalendarExt2
    486 Posts 83 Posters 1.1m Views 83 Watching
      jani.karna
      @Sean said in MMM-CalendarExt2:
      @jani-karna
      1. Slightly narrow event’s width is intentional to avoid margin of error on calculation. It is hardcoded. But if you want to modify it by yourself,
        https://github.com/eouia/MMM-CalendarExt2/blob/a5d509ada997034f91e0790ad72e87512cb24c60/CALEXT2_Slot.js#L250
      eventDom.style.width = width - 15 + "px"
      Change 15 to what you want.
      Worked perfectly, thank you!
        jani.karna @Guest
        Can I also shrink the gap between events vertically somehow?
        Tell me more exact details? Even a picture will help.
        What I mean with gap between events is this:
          [[global:former-user]] @jani.karna
          @jani-karna
          Hmmm… in Original CSS, there was no huge gap. It would be only 2px. I think you probably have modified CSS by yourself, but I don’t know what you changed. Sorry, can’t help you.
            jani.karna @Guest
            Thats fine, I’ll figure it out.
            In the upcoming calendar, I have location or additional information in the events and their font is too big. Can I somehow make it smaller? Here’s a pic, the last row being the additional information:
              @jani-karna
              https://github.com/eouia/MMM-CalendarExt2/wiki/4.-Styling
              Each event has eventSub (and its sub-elements eventLocation and eventDescription). By default, agenda(upcoming and current) views would reveal eventSub, so, you can use that CSS selector to specify.
                jani.karna @Guest
                @jani-karna
                Missed that styling part… :grimacing_face: got it working, thank you again!
                  code999
                  Hello again. is there a way to scroll the events when there are so many on a single day with displaying the (+x).
                  Thanks.
                    [[global:former-user]] @code999
                    @code999
                    no. i was tried scrolling in my older CALEXT but too burden to rpi.
                      @code999
                      Instead, you can sort and filter the order of events to be shown.
                        ChickenBeard
                        Did CalendarExt in Weeks (or Month) view automatically adjust the height of the day to accommodate the events?
                        I swear if there was only one or two events for a day (in a given week), the whole row was shorter.
                          [[global:former-user]] @ChickenBeard
                          @ChickenBeard
                          Not adjusted automatically. you can set the height of the slot manually.
                            ChickenBeard
                            Is it CX2 .slot ?
                              @ChickenBeard
                              if you mean some table views (month, week), set slotMaxHeight of view configuration.
                              https://github.com/eouia/MMM-CalendarExt2/wiki/2c4.-View:week,-month
                                code999 @Guest
                                @Sean okay. it would be great to have though. not seeing the events is not good. limited space on the screen so i cant just make more room because then i will lose a full week from the month view.
                                thanks.
                                  code999
                                  @Sean could you help me do that anyway? lol
                                  i would really like it to do that.
                                  Thanks.
                                    @code999
                                    do what?
                                      code999
                                      @Sean make the events under a date that is not showing scroll.
                                      I am trying to figure it out but I have no coding knowledge at all so I just randomly change things and see what it does but I am not getting anywhere doing that at all.
                                        @code999
                                        To show more events in a cell, just set bigger slotMaxHeight. And shrinking the font-size and height of event element could be help.
                                        But anyway, Usual MagicMirror Screen has not so enough space to show many events with Table Views(month and week view). Even normal Desktop calendar programs like Google Calendar MS-Office or Apple Calendar couldn’t show too many events in a cell.
                                        Maybe you can make show 5 or 6 events in a day cell. But What about 7 events or 8 events? It could not be solved at last.
                                        Auto-scroll could be the ideal solution, but RPI has not enough power to maintain so many scrolling effects. (Maybe RPI4 could have enough power but many ppl also are using even RPI0)
                                        However, you want it, use MMM-CalendarExt instead. It has that feature but will be very slow.
                                        Another possible approach would be to filter and/or to sort events to show. Some of the events will not be more important than others to show in that view. You can filter unimportant events not to show, Or at least, you can sort them to hide.
                                          cskenney
                                          Just a general question. I have my calendar pulling from 6-7 different Google calendars. I have the module configured to retrieve the calendar data every 5 minutes. I did this to allow changes made to an entry to be updated pretty quickly on my display.
                                          The issue is if I modify a calendar entry in my Google calendar it doesn’t get updated in the MM calendar display. If I stop MM and then restart it then everything will be correct. But leaving it running it doesn’t update with the changes. I have also seen this if I deleted a calendar entry it will remain in my MM calendar on the display.
                                          Here is the code I am using. I put the scan interval for the calendars in the default section.
                                          				locale: "en",
                                          				defaultSet: {
                                          						calendars: {
                                          							maxItems: 500,
                                          							scanInterval: 1000*60*5,
                                          							beforeDays: 5,
                                          							afterDays: 60,
                                          							maxIterations: 100,
                                            [[global:former-user]] @cskenney
                                            @cskenney
                                            scanInterval is just for scanning calendars, finding something changed, then loading them. So, your modified events would definitely be loaded on the module.
                                            But displaying is another issue. rotateInterval(when you are using multi-scenes) or updateInterval (When you are using single-scenes) could make refreshing the displaying.
                                            https://github.com/eouia/MMM-CalendarExt2/wiki/2e.-Configuration:Others
                                            • 10
                                            • 11
                                            • 24
                                            • 25
                                            • 9 / 25
