    Alexa Controll.... Some questions
    10 Posts 4 Posters 2.9k Views 4 Watching
      JoChef2 Module Developer
        JoChef2 Module Developer @Clubjack
        @Clubjack It’s possible. You have to create a routine in your Alexa app. There you can create a custom voice command and a device that should turn on or off.
        • StoffbeuteluweS Offline
          Stoffbeuteluwe Project Sponsor @Clubjack
          @Clubjack https://forum.magicmirror.builders/topic/11568/hi-there-is-a-new-alexa-module?page=1
            Clubjack
            @Stoffbeuteluwe
            Thank you.
            I read this thread. However, I could not find anything to changed announcements. Maybe we can communicate via PM in German. 😉 Or is it also allowed in the thread?
              Clubjack
              I read it again.
              Now I probably understand it.
              Each newly created page will become a device in alexa.
              With a routine you can therefore select specific pages.
              Did I understand it correctly?
              Here’s an example:
              Page 1 with a calendar becomes device 1, page 2 with a newsfeed becomes device 2.
              I create a routine in alexa with “when I say open calendar, then activate device 1” etc.
              I’ll try that as soon as I have time again.
              Is it also possible that after a certain time again and again the main page appears?
                @Clubjack That’s right. It should work with routines.
                  pumpy266
                  Why not change the name of the device that Alexa has found to something more memorable? Mine found page1, page 2 etc
                  Renaming, with the Alexa App on my phone, “page 1” to “clock” meant that the command “Alexa turn on clock” displays the clock page.
                    Stoffbeuteluwe Project Sponsor @JoChef2
                    @JoChef2 Hi, thanks for that amazing module I’m using it every day.
                      Clubjack
                      All that sounds very good. I will try it and hopefully I can do it.
                      Thank You all for that.
