    Third-Party Module - how to get help?
    64 Posts 3 Posters 40.4k Views 4 Watching
    • E Offline
      ember1205 @sdetweil
      I’ll definitely give it a try. But… If it were a browser zoom issue, wouldn’t that prevent the other module from displaying them properly as well?
        sdetweil @ember1205
        @ember1205 yes…
          I just added a little bit of debug messaging…
          go to the MMM-ImagesPhotos folder, and do a git pull
          then edit the config and add
          debug:true,
          then restart MM
          using keyboard, hit ctrl-shift-i, a window will open on right side, select the tab labeled console, and type
          image into the field labeled filter…
          now u will see messages from the module as it loads images and gets the image actual size, and sets the location and dimension of the image to be displayed… like this sizes are width/height
          top is the top left corner (all locations are relative to the top left corner of the screen, 0,0 is the top left… so 0:72 is all the way left and 72 pixels down. (note its centered, so height+2*offset = max,.
          MMM-ImagesPhotos.js:237 image setting size to 3023:2015
          MMM-ImagesPhotos.js:238 image setting top to 0:72
          2015+72*2=2159 (of 2160) in this case
          MM-ImagesPhotos.js:222 image loaded=http://localhost:8080/MMM-ImagesPhotos/photo/DSC_0491.JPG size=4000:6000
          MMM-ImagesPhotos.js:237 image setting size to 1440:2160
          MMM-ImagesPhotos.js:238 image setting top to 791:0
          MMM-ImagesPhotos.js:222 image loaded=http://localhost:8080/MMM-ImagesPhotos/photo/PICT0097.JPG size=5472:3648
          MMM-ImagesPhotos.js:222 image loaded=http://localhost:8080/MMM-ImagesPhotos/photo/DSC_0027.JPG size=6000:4000
          MMM-ImagesPhotos.js:222 image loaded=http://localhost:8080/MMM-ImagesPhotos/photo/DSC_0476.JPG size=6000:4000
          MMM-ImagesPhotos.js:222 image loaded=http://localhost:8080/MMM-ImagesPhotos/photo/DSC_0042.JPG size=6000:4000
          MMM-ImagesPhotos.js:222 image loaded=http://localhost:8080/MMM-ImagesPhotos/photo/DSC_0198.JPG size=6000:4000
          MMM-ImagesPhotos.js:222 image loaded=http://localhost:8080/MMM-ImagesPhotos/photo/DSC_0720.JPG size=4496:3000
          MMM-ImagesPhotos.js:237 image setting size to 3023:2017
          MMM-ImagesPhotos.js:238 image setting top to 0:71
          MMM-ImagesPhotos.js:222 image loaded=http://localhost:8080/MMM-ImagesPhotos/photo/DSC_0697.JPG size=3000:4496
          MMM-ImagesPhotos.js:237 image setting size to 1441:2160
          MMM-ImagesPhotos.js:222 image loaded=http://localhost:8080/MMM-ImagesPhotos/photo/DSC_0319.JPG size=4000:6000
          • E Offline
            ember1205 @sdetweil
            “do a get pull”… To date, I’ve done little with repositories - can you elaborate on how I do this to make sure I do it correctly?
            Also… Some updates.
            1. CTRL - does not affect image size in any way. It DOES affect the sizing of the text for the other modules, though.
            2. I believe that I have determined that the desktop / browser “believes” that it is in portrait mode. The images seem to be getting constrained properly, but because the browser is configured to be as tall as it is, I’m losing all kinds of content off the bottom of the screen. If I do a CTRL-SHIFT-I and then turn on the device toolbar, I see a full vertical representation of the browser and I can see the entire image. As I increase the zoom, it becomes apparent where the image is getting clipped vertically.
            Thoughts?
              sdetweil @ember1205
              @ember1205
              do a get pull…
              No
              “do a git pull”
              Do
              cd ~/MagicMirror/modules/MMM-ImagesPhotos
              git pull
              That copies the latest from a remote repo and updates the local copy and working directory.
              I don’t understand how electron thinks it should be in portrait mode. Never seen that
                @sdetweil yeh, you should NOT zoom in
                I wonder if this has anything to do with the fake kms driver?
                • E Offline
                  ember1205
                  git pull says everything up to date and didn’t do anything. No image size info available.
                  I tried reverting TO the fake driver as I was not using it (real one instead) and that hasn’t made any difference. I also tried editing the startup file to remove the rotate setting, also didn’t help.
                    sdetweil @ember1205
                    @ember1205 did u install.my MMM-ImagesPhotos or the original?
                    I JUST updated mine before telling u, and I just checked the new code is there.
                    In the MMM-ImagePhotos folder do
                    git remote -v
                    Should point to sdetweil
                    • E Offline
                      ember1205 @sdetweil
                      I followed the directions on the page for your module:
                      Clone this repository inside your MagicMirror's modules folder
                      git clone https://github.com/roramirez/MMM-ImagesPhotos.git.
                      I saw the reference to roramirez, but as I said - I don’t do a lot with git, so I have to go with what’s on the page. Did that install the original?
                        sdetweil @ember1205
                        @ember1205 yes, u installed the original… when one develops enhancements of a git project, you make a connected copy (fork), anything u change can be sent back to the author with a ‘pull request’. I didn’t change any of his install instructions.
                        when u are on a git project, there is a button, clone or download(the fork, not the original), u press that, and then click the little clipboard icon to copy the url for the git clone command
                        at any time, you can see where your instance is sourced from by doing
                        git remote -v
                        in the module folder
                        so, I would rename the current folder out of the way (the original doesn’t work at all for me)
                        mv MMM-ImagesPhotos MMM-ImagesPhotos.orig
                        git clone https://github.com/sdetweil/MMM-ImagesPhotos
                        and then restart the mirror
                        • E Offline
                          ember1205 @sdetweil
                          Sigh. Best laid plans… lol
                          At any rate - I actually rm’ed the original dir and re-did the clone using YOUR version. Came right up and started working properly right out of the gate.
                          Thanks for not only all of the help, but all of the patience. I do learn quickly, and this should now remain fairly firmly entrenched in my brain going forward.
                          Now I’m off to see how to modify the CSS of MM to change some of the font aspects for text!
                            sdetweil @ember1205
                            @ember1205 cool. thanks for the feedback… come on back when u need help, there are amazing talented folks who can help with just about everything!
                            • E Offline
                              ember1205
                              I know this is marked ‘solved’, but I wanted to mention that A ) the module does still crash with “out of memory” errors and B ) a little bit of investigative tinkering makes me think that this all ties back to a garbage collection issue with Java.
                              If I change the timing of how often the images change, I can effectively ‘force’ or almost eliminate a crash. The shorter the duration between photos, the more likely a crash will occur. I changed the timing to 45 seconds and saw the setup run reliably from power on at 7AM until power off at 11PM for multiple days in a row.
                              Shortening the window down to 5 seconds between images will cause the system to crash typically within about 10-15 minutes at a maximum.
                              At no time do I actively witness memory levels dropping down to zero, but that could just be “bad luck” in not seeing the issue arise when it errors out. Is there an easy way on the Pi to track a process and watch for a specific, correlating event when something crashes?
                              • E Offline
                                ember1205
                                Also - I caught this error with your debug output:
                                Failed to load resource: the server responded with a status of 404 (Not Found) :8080/MMM-ImagesPhotos/photos:1
                                That’s at the beginning of the console output along with another error I have seen later in the console:
                                MMM-ImagesPhotos Could not load photos
                                photosrequest.onreadystatechange @ :8080/modules/MMM-ImagesPhotos/MMM-ImagesPhotos.js:65
                                Any thoughts on those?
                                  sdetweil @ember1205
                                  @ember1205 i am not aware of any debugging tools or strategy that can get to the type of issue being encountered. I have been chasing these for the last 4 years…
                                  i also think the error reported is bogus, caused by the mishandling of some other error.
                                  the ‘problem’ is that the browser thinks IT is in control of the content update cycle, but with all these modules running separate timer event handlers, it is not.
                                  I have debugged a lot of ‘electron is single threaded’ problems down to , ‘you might THINK its single threaded, but it is NOT’… when the timer fires, SOMETHING is getting interrupted… in gosh knows what state…
                                  one way you might prove this, is to turn off every other module, so only ONE does any content updating (it is a web page after all)
                                  One of my modules has 2-10 images loaded over the top of the web page, on independent timing cycles. i traced failures to attempting to load an image, while an image load was already in progress. I added code to my module to prevent this behavior, and my failures went away.
                                  I added a background image thing, and they returned when my module is running…
                                  they are both loading images at the same time sometimes… and electron crashes… in various ways.
                                  I have been trying (last 6 months) to find a mechanism to serialize this across multiple modules, without changing the modules, but have failed so far.
                                  we are also running on an age old electron (3.x), which the most recent version that will run for MM is 6.x) (7.x will not run)
                                    sdetweil @ember1205
                                    @ember1205 said in Third-Party Module - how to get help?:
                                    yeh, the code attempts to load the folder… once… I haven’t debugged it cause it doesn’t matter
                                    • E Offline
                                      ember1205 @sdetweil
                                      @sdetweil said in Third-Party Module - how to get help?:
                                      Thanks.
                                      What about second error I mentioned? Or, is that essentially part of the overall error?
                                        sdetweil @ember1205
                                        @ember1205 part of the same… looking at it now
                                          @ember1205
                                          ok, fixed the error message… a startup timing error…
                                          module tried to get images from node_helper, before node_helper had established the linkage…
                                          (if u are using my repo)
                                          go to your MMM-ImagesPhotos folder and do
                                          git pull
                                          then restart mirror app
                                          • E Offline
                                            ember1205
                                            I don’t seem to be seeing that error any more, but now it’s crying about not using HTTPS (warning, not error, and specifically for Electron). For whatever reason, that warning wasn’t showing up in the console prior although I’m sure that it was there in some capacity.
                                            I -do- see an indication of an error but can’t seem to find any error in the console.
                                            • 3 / 4
