    MMM-MealViewer
    48 Posts 6 Posters 34.6k Views 6 Watching
    • htilburgsH Offline
      htilburgs
      So in my case the URL produces:
      0_1576260496007_7fa5a24c-528a-4697-9557-2a9058df2860-image.png image url)
      json_data.SD[0].SPEED@attributes.TEXT will be:
      json.data.film[0].titel    --> 'Bellicher: Cel'
      Correct?
      (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
        sdetweil @htilburgs
        @htilburgs correct (json_data is the name of the output variable, note underscore, not dot, using dot means ‘go into’) … if you use one of the module add ons… not the code shown…
          @htilburgs and the number of films in the array would be
          json_data.film.length
          using the developers window you can put a code stop on the line after the xml2json
          and then u can explore the conversion…
          you can also use console.log(JSON.stringify(some_object)) and it will dump the structure in json format
            htilburgs
            Mmmm… not working yet…
            My current node_helper.js:
            const NodeHelper = require('node_helper');
            const request = require('request');
                start: function() {
                    console.log("Starting node_helper for: " + this.name);
            	// Changes XML to JSON
            	xmlToJson: function(xml) {
            		// Create the return object
            		var obj = {};
            		if (xml.nodeType == 1) { // element
            			// do attributes
            			if (xml.attributes.length > 0) {
            			obj["@attributes"] = {};
            				for (var j = 0; j < xml.attributes.length; j++) {
            					var attribute = xml.attributes.item(j);
            					obj["@attributes"][attribute.nodeName] = attribute.nodeValue;
            		} else if (xml.nodeType == 3) { // text
            			obj = xml.nodeValue;
            		// do children
            		if (xml.hasChildNodes()) {
            			for(var i = 0; i < xml.childNodes.length; i++) {
            				var item = xml.childNodes.item(i);
            				var nodeName = item.nodeName;
            				if (typeof(obj[nodeName]) == "undefined") {
            					obj[nodeName] = xmlToJson(item);
            				} else {
            					if (typeof(obj[nodeName].push) == "undefined") {
            						var old = obj[nodeName];
            						obj[nodeName] = [];
            						obj[nodeName].push(old);
            					obj[nodeName].push(xmlToJson(item));
            		return obj;
            	getMTVM: function(url) {
            		request(url, function(err, res, body) {
            		// if no error and server was happy
            			if(err == null && res.statusCode ==200){
            			console.log(body);
            			var json_data = this.xmlToJson(body)
            			console.log("Text is " + json_data.film[0].titel)
                    if (notification === 'GET_MTVM') {
                        this.getMTVM(payload);
            In the dev console I get an error:
            TypeError: this.xmlToJson is not a function
              sdetweil @htilburgs
              @htilburgs ah the fun of ‘this’…
                             let self=this
              			   console.log(body);
              			   var json_data = self.xmlToJson(body)
              htilburgsH 1 Reply Last reply Reply Quote 0
                htilburgs @sdetweil
                @sdetweil Yeah! That part is working. Now I’ve an other error which has something to do with the xmlToJson function:
                TypeError: xml.hasChildNodes is not a function
                Any idea?
                  sdetweil @htilburgs
                  @htilburgs yeh, tricky crap… they had a special runtime that supported that… sorry…
                  have to use one of the libs…
                  in your module folder do
                  npm install xml2js
                  then in your code
                  const xml2js = require('xml2js');
                  then
                                 let self=this
                  			   console.log(body);
                  			   xml2js.parseString(body,function (err,result) {
                  			       let json_data = result // not needed but may make more clear
                    htilburgs @sdetweil
                    @sdetweil Almost there I think ;-)
                    TypeError: Cannot read property '0' of undefined
                        at /home/pi/MagicMirror/modules/MMM-MyTVMovies/node_helper.js:28:47
                        at Parser.<anonymous> (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/xml2js/lib/parser.js:306:18)
                        at Parser.emit (events.js:182:13)
                        at SAXParser.onclosetag (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/xml2js/lib/parser.js:264:26)
                        at emit (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/sax/lib/sax.js:624:35)
                        at emitNode (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/sax/lib/sax.js:629:5)
                        at closeTag (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/sax/lib/sax.js:889:7)
                        at SAXParser.write (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/sax/lib/sax.js:1436:13)
                        at Parser.exports.Parser.Parser.parseString (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/xml2js/lib/parser.js:325:31)
                        at Parser.parseString (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/xml2js/lib/parser.js:5:59)
                    Has this something to do with the json_data.film[0].titel ??
                    Or is it something else?
                    When I remove .film[0].titel I got:
                    Text is [object Object]
                    200[object Object]
                      sdetweil @htilburgs
                      @htilburgs u should look at the data format
                                     let self=this
                      			   console.log(body);
                      			       console.log(JSON.stringify(json_data))
                        htilburgs @sdetweil
                        @sdetweil JSON is perfect:
                        Thanks for the help so far!! Now I have my data I can play around with it.
                        • 3 / 3
