    MMM-MealViewer
    48 Posts 6 Posters 35.9k Views 6 Watching
      sdetweil @htilburgs
      @htilburgs there are a few xml to json modules
      https://www.npmjs.com/package/xml2js
      google search
      ‘nodejs xmltojson’
      here is one with a just code, no extra libs
      https://davidwalsh.name/convert-xml-json
      • htilburgsH
        htilburgs
        @sdetweil , I’ve found them, but I don’t know how to use it in combination with the URL that creates the XML.
        Indeed the last one with no extra libs looks promising. I tried to simply add this in the node_helper.js but getting stuck at how to use it.
        I’ve looked into all the MMM Modules but cannot seem to find an example.
        (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
          sdetweil @htilburgs
          @htilburgs the url bring back the data with request
          request(url, function(err, res, body) {
              // if no error and server was happy
              if(err == null && res.statusCode ==200){
              console.log(body);
              var json_data=this.xmlToJson(body)
              console.log("Speed[0] text is "+json_data.SD[0].SPEED.@attributes.TEXT)
          when the server responds, the function is called and passed the data, body)
          and then u would convert it from xml to json . using the last code
          then the json is accessed with the normal structure notation
          (using the sample with the code in the last link)
          json_data.SD[0].SPEED.@attributes.TEXT will be ‘1421’
          SD is an array (multiple of same xml tags)
          a little ugly in the data layour, could get rid of the @attributes thing with a small code change
          • htilburgsH
            htilburgs
            So in my case the URL produces:
            0_1576260496007_7fa5a24c-528a-4697-9557-2a9058df2860-image.png image url)
            json_data.SD[0].SPEED@attributes.TEXT will be:
            json.data.film[0].titel    --> 'Bellicher: Cel'
            Correct?
              sdetweil @htilburgs
              @htilburgs correct (json_data is the name of the output variable, note underscore, not dot, using dot means ‘go into’) … if you use one of the module add ons… not the code shown…
                @htilburgs and the number of films in the array would be
                json_data.film.length
                using the developers window you can put a code stop on the line after the xml2json
                and then u can explore the conversion…
                you can also use console.log(JSON.stringify(some_object)) and it will dump the structure in json format
                • htilburgsH
                  htilburgs
                  Mmmm… not working yet…
                  My current node_helper.js:
                  const NodeHelper = require('node_helper');
                  const request = require('request');
                      start: function() {
                          console.log("Starting node_helper for: " + this.name);
                  	// Changes XML to JSON
                  	xmlToJson: function(xml) {
                  		// Create the return object
                  		var obj = {};
                  		if (xml.nodeType == 1) { // element
                  			// do attributes
                  			if (xml.attributes.length > 0) {
                  			obj["@attributes"] = {};
                  				for (var j = 0; j < xml.attributes.length; j++) {
                  					var attribute = xml.attributes.item(j);
                  					obj["@attributes"][attribute.nodeName] = attribute.nodeValue;
                  		} else if (xml.nodeType == 3) { // text
                  			obj = xml.nodeValue;
                  		// do children
                  		if (xml.hasChildNodes()) {
                  			for(var i = 0; i < xml.childNodes.length; i++) {
                  				var item = xml.childNodes.item(i);
                  				var nodeName = item.nodeName;
                  				if (typeof(obj[nodeName]) == "undefined") {
                  					obj[nodeName] = xmlToJson(item);
                  				} else {
                  					if (typeof(obj[nodeName].push) == "undefined") {
                  						var old = obj[nodeName];
                  						obj[nodeName] = [];
                  						obj[nodeName].push(old);
                  					obj[nodeName].push(xmlToJson(item));
                  		return obj;
                  	getMTVM: function(url) {
                  			console.log(body);
                  			var json_data = this.xmlToJson(body)
                  			console.log("Text is " + json_data.film[0].titel)
                          if (notification === 'GET_MTVM') {
                              this.getMTVM(payload);
                  In the dev console I get an error:
                  TypeError: this.xmlToJson is not a function
                    sdetweil @htilburgs
                    @htilburgs ah the fun of ‘this’…
                                   let self=this
                    			   console.log(body);
                    			   var json_data = self.xmlToJson(body)
                    htilburgsH 1 Reply Last reply
                    • htilburgsH
                      htilburgs @sdetweil
                      @sdetweil Yeah! That part is working. Now I’ve an other error which has something to do with the xmlToJson function:
                      TypeError: xml.hasChildNodes is not a function
                      Any idea?
                        sdetweil @htilburgs
                        @htilburgs yeh, tricky crap… they had a special runtime that supported that… sorry…
                        have to use one of the libs…
                        in your module folder do
                        npm install xml2js
                        then in your code
                        const xml2js = require('xml2js');
                        then
                                       let self=this
                        			   console.log(body);
                        			   xml2js.parseString(body,function (err,result) {
                        			       let json_data = result // not needed but may make more clear
                        • htilburgsH
                          htilburgs @sdetweil
                          @sdetweil Almost there I think ;-)
                          TypeError: Cannot read property '0' of undefined
                              at /home/pi/MagicMirror/modules/MMM-MyTVMovies/node_helper.js:28:47
                              at Parser.<anonymous> (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/xml2js/lib/parser.js:306:18)
                              at Parser.emit (events.js:182:13)
                              at SAXParser.onclosetag (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/xml2js/lib/parser.js:264:26)
                              at emit (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/sax/lib/sax.js:624:35)
                              at emitNode (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/sax/lib/sax.js:629:5)
                              at closeTag (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/sax/lib/sax.js:889:7)
                              at SAXParser.write (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/sax/lib/sax.js:1436:13)
                              at Parser.exports.Parser.Parser.parseString (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/xml2js/lib/parser.js:325:31)
                              at Parser.parseString (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/xml2js/lib/parser.js:5:59)
                          Has this something to do with the json_data.film[0].titel ??
                          Or is it something else?
                          When I remove .film[0].titel I got:
                          Text is [object Object]
                          200[object Object]
                            sdetweil @htilburgs
                            @htilburgs u should look at the data format
                                           let self=this
                            			   console.log(body);
                            			       console.log(JSON.stringify(json_data))
                            • htilburgsH
                              htilburgs @sdetweil
                              @sdetweil JSON is perfect:
                              Thanks for the help so far!! Now I have my data I can play around with it.
                              • 3 / 3
