    MMM-MealViewer
    48 Posts 6 Posters 35.4k Views 6 Watching
    • G
      gonzonia
      Okay. I’ve identified the problem. In the code below, everything gets setup in the “start” function. Then it calls getMenuData. That function ends by setting up a timer to call itself but isn’t supplying the object necessary. This means it won’t work. If I add the _this object to pass it causes all sorts of problems.
      I’m not a js expert. I’m sure a way to re-factor this will eventually occur to me, but right now I’m just not seeing it.
      start:  function() {
          Log.log('Starting module: ' + this.name);
          // Set up the local values
          var today = moment();
          this.loaded = false;
          this.urls = [];
          this.results = [];
          // Uses now are today if before noon and tomorrow as today if after noon
          if (today.hour() >= 12) {
            var todayFormatted = today.add(1, 'day').format('MM-DD-YYYY');
          else {
            var todayFormatted = today.format('MM-DD-YYYY');
          // Currently set to only pull one day's data so endDayFormatted = todayFormatted
          //var endDay = today.add(config.showDays, 'days');
          //var endDayFormatted = endDay.format('MM-DD-YYYY');
          var endDayFormatted = todayFormatted;
          // Construct the url array for the schools
          for (var i in this.config.schools) {
      			this.urls.push({school: this.config.schools[i], url: 'https://api.mealviewer.com/api/v4/school/' + this.config.schools[i] + '/' + todayFormatted + '/' + endDayFormatted + '/'});
          // Trigger the first request
          this.getMenuData(this);
        getMenuData: function(_this) {
          // Make the initial request to the helper then set up the timer to perform the updates
          _this.sendSocketNotification('GET-MENU-DATA', _this.urls);
          setTimeout(_this.getMenuData(), _this.config.interval, _this);
        sdetweil @gonzonia
        @gonzonia said in MMM-MealViewer:
        _this.sendSocketNotification(‘GET-MENU-DATA’, _this.urls);
        do this
            setTimeout(function() {_this.getMenuData(_this)}, _this.config.interval);
        this creates a little inline function which CAN pass parms on to the next routine
        • G
          gonzonia @sdetweil
          @sdetweil Thanks! I’ll make the change and see what happens when it should update mid-day tomorrow.
          • cowboysdudeC
            Or you could do this:
            scheduleUpdate: function() {
                   setInterval(() => {
                       this.getMenuData();
                   }, this.config.updateInterval);
                getMenuData: function() {
                   this.sendSocketNotification('GET-MENU-DATA');
            At the top of the main js you set the interval:
            updateInterval: 15 * 60 * 1000,
            Then in the start section you call it:
            // Define start sequence.
               start: function() {
                   this.scheduleUpdate();
            Either the way Sam showed you or the above will work :)
            • G
              gonzonia @cowboysdude
              @cowboysdude Thanks! I might switch to that. I’ve had to rework it a little because the URL wasn’t getting set except at the first call. I just moved setup for that into the getMenuData and I think it’s all working now. I’ll give it a day to run and see what happens tomorrow before I try messing with it again and update the file on github.
              -updated to fix grammar
              • cowboysdudeC
                Sam is a REALLY smart guy so he gives you the smart guy answer…
                I’m not as smart so I give you my dumb guy answer LOL
                It will work either way … so now you def have an answer that works :)
                  sdetweil @cowboysdude
                  @cowboysdude said in MMM-MealViewer:
                  nah, Sam is the LAZY guy… change as LITTLE as possible. especially for folks just starting out
                  • G
                    gonzonia
                    Well, thanks to both of you! I can confirm it is finally working.
                    Now to update github. Someday I should write some documentation too.
                    • htilburgsH
                      htilburgs
                      @cowboysdude, I’m looking for the part where you “change” the XML data to JSON data. I’m trying to write a new MMM, but the data is presented in XML. I like the have it in JSON, so I can use it.
                      Maybe I read over it, but I cannot figure out where you do this.
                      (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
                        sdetweil @htilburgs
                        @htilburgs there are a few xml to json modules
                        https://www.npmjs.com/package/xml2js
                        google search
                        ‘nodejs xmltojson’
                        here is one with a just code, no extra libs
                        https://davidwalsh.name/convert-xml-json
                        • htilburgsH
                          htilburgs
                          @sdetweil , I’ve found them, but I don’t know how to use it in combination with the URL that creates the XML.
                          Indeed the last one with no extra libs looks promising. I tried to simply add this in the node_helper.js but getting stuck at how to use it.
                          I’ve looked into all the MMM Modules but cannot seem to find an example.
                            sdetweil @htilburgs
                            @htilburgs the url bring back the data with request
                            request(url, function(err, res, body) {
                                // if no error and server was happy
                                if(err == null && res.statusCode ==200){
                                console.log(body);
                                var json_data=this.xmlToJson(body)
                                console.log("Speed[0] text is "+json_data.SD[0].SPEED.@attributes.TEXT)
                            when the server responds, the function is called and passed the data, body)
                            and then u would convert it from xml to json . using the last code
                            then the json is accessed with the normal structure notation
                            (using the sample with the code in the last link)
                            json_data.SD[0].SPEED.@attributes.TEXT will be ‘1421’
                            SD is an array (multiple of same xml tags)
                            a little ugly in the data layour, could get rid of the @attributes thing with a small code change
                            • htilburgsH
                              htilburgs
                              So in my case the URL produces:
                              0_1576260496007_7fa5a24c-528a-4697-9557-2a9058df2860-image.png image url)
                              json_data.SD[0].SPEED@attributes.TEXT will be:
                              json.data.film[0].titel    --> 'Bellicher: Cel'
                              Correct?
                                sdetweil @htilburgs
                                @htilburgs correct (json_data is the name of the output variable, note underscore, not dot, using dot means ‘go into’) … if you use one of the module add ons… not the code shown…
                                  @htilburgs and the number of films in the array would be
                                  json_data.film.length
                                  using the developers window you can put a code stop on the line after the xml2json
                                  and then u can explore the conversion…
                                  you can also use console.log(JSON.stringify(some_object)) and it will dump the structure in json format
                                  • htilburgsH
                                    htilburgs
                                    Mmmm… not working yet…
                                    My current node_helper.js:
                                    const NodeHelper = require('node_helper');
                                    const request = require('request');
                                        start: function() {
                                            console.log("Starting node_helper for: " + this.name);
                                    	// Changes XML to JSON
                                    	xmlToJson: function(xml) {
                                    		// Create the return object
                                    		var obj = {};
                                    		if (xml.nodeType == 1) { // element
                                    			// do attributes
                                    			if (xml.attributes.length > 0) {
                                    			obj["@attributes"] = {};
                                    				for (var j = 0; j < xml.attributes.length; j++) {
                                    					var attribute = xml.attributes.item(j);
                                    					obj["@attributes"][attribute.nodeName] = attribute.nodeValue;
                                    		} else if (xml.nodeType == 3) { // text
                                    			obj = xml.nodeValue;
                                    		// do children
                                    		if (xml.hasChildNodes()) {
                                    			for(var i = 0; i < xml.childNodes.length; i++) {
                                    				var item = xml.childNodes.item(i);
                                    				var nodeName = item.nodeName;
                                    				if (typeof(obj[nodeName]) == "undefined") {
                                    					obj[nodeName] = xmlToJson(item);
                                    				} else {
                                    					if (typeof(obj[nodeName].push) == "undefined") {
                                    						var old = obj[nodeName];
                                    						obj[nodeName] = [];
                                    						obj[nodeName].push(old);
                                    					obj[nodeName].push(xmlToJson(item));
                                    		return obj;
                                    	getMTVM: function(url) {
                                    			console.log(body);
                                    			var json_data = this.xmlToJson(body)
                                    			console.log("Text is " + json_data.film[0].titel)
                                            if (notification === 'GET_MTVM') {
                                                this.getMTVM(payload);
                                    In the dev console I get an error:
                                    TypeError: this.xmlToJson is not a function
                                      sdetweil @htilburgs
                                      @htilburgs ah the fun of ‘this’…
                                                     let self=this
                                      			   console.log(body);
                                      			   var json_data = self.xmlToJson(body)
                                      htilburgsH 1 Reply Last reply Reply Quote 0
                                      • htilburgsH
                                        htilburgs @sdetweil
                                        @sdetweil Yeah! That part is working. Now I’ve an other error which has something to do with the xmlToJson function:
                                        TypeError: xml.hasChildNodes is not a function
                                        Any idea?
                                          sdetweil @htilburgs
                                          @htilburgs yeh, tricky crap… they had a special runtime that supported that… sorry…
                                          have to use one of the libs…
                                          in your module folder do
                                          npm install xml2js
                                          then in your code
                                          const xml2js = require('xml2js');
                                          then
                                                         let self=this
                                          			   console.log(body);
                                          			   xml2js.parseString(body,function (err,result) {
                                          			       let json_data = result // not needed but may make more clear
                                          • htilburgsH
                                            htilburgs @sdetweil
                                            @sdetweil Almost there I think ;-)
                                            TypeError: Cannot read property '0' of undefined
                                                at /home/pi/MagicMirror/modules/MMM-MyTVMovies/node_helper.js:28:47
                                                at Parser.<anonymous> (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/xml2js/lib/parser.js:306:18)
                                                at Parser.emit (events.js:182:13)
                                                at SAXParser.onclosetag (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/xml2js/lib/parser.js:264:26)
                                                at emit (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/sax/lib/sax.js:624:35)
                                                at emitNode (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/sax/lib/sax.js:629:5)
                                                at closeTag (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/sax/lib/sax.js:889:7)
                                                at SAXParser.write (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/sax/lib/sax.js:1436:13)
                                                at Parser.exports.Parser.Parser.parseString (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/xml2js/lib/parser.js:325:31)
                                                at Parser.parseString (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/xml2js/lib/parser.js:5:59)
                                            Has this something to do with the json_data.film[0].titel ??
                                            Or is it something else?
                                            When I remove .film[0].titel I got:
                                            Text is [object Object]
                                            200[object Object]
                                            • 2 / 3
