    MMM-MealViewer
    48 Posts 6 Posters 35.4k Views 6 Watching
    • G
      gonzonia @sdetweil
      @sdetweil Thank you. That’s helpful (I’m still learning the ins and outs of Magic Mirror) but there’s no errors. The “Undefined” is coming up while it’s loading the data. There’s no documentation for the module, I’m thinking there’s something that’s missing in the setup.
        sdetweil @gonzonia
        @gonzonia can u should your config info?
        looking at the code, these are the options that are configurable
          defaults: {
            schools: [],
            maxWidth: "300px",
            updateInterval: 5 * 60 * 1000,
            interval: 1000 * 60 * 15,
        where schools is an array of names
        [ ‘school1’,school2’, ‘school3’]
        used to call the api
        https://api.mealviewer.com/api/v4/school/’ + this.config.schools[i]
        school names can be found here
        https://schools.mealviewer.com/
        comment says only for one day
        // Currently set to only pull one day’s data so endDayFormatted = todayFormatted
        • G
          gonzonia @sdetweil
          Thanks. I actually went in to the code and tweaked it. It was pulling the data fine, I think the issue was that the original developer’s usage only had a single meal (Lunch) available at the school and so it worked as is. Our school has Breakfast and Lunch I added an additional iteration to show all the meals or just what was placed in the config. The header now also reflects that. I’m not sure what that was supposed to do before because I couldn’t figure out where it was expecting the data.header to come from since nothing was loaded.
          My changes can be found here.
          https://github.com/gonzonia/MMM-MealViewer/tree/patch-1
          added shortName to config to replace text based on config option instead of hardcoded
          changed className to menuWrapper to allow for style control without interfering with other modules
          added config option for showing single or multiple meals based on name, default is All
          Still need to add some documentation but it might be a couple of weeks.
          • G
            gonzonia
            The module works great on the initial load. The problem is that it doesn’t seem to be updating. After 12pm it’s supposed to start showing the next days meals but doesn’t. Even the next day it doesn’t update. I’ll try to dig into the core aspects of developing a module and see if I can find out why, but if anyone with more experience has any ideas where I should start looking I’d appreciate it.
            • G
              gonzonia
              Okay. I’ve identified the problem. In the code below, everything gets setup in the “start” function. Then it calls getMenuData. That function ends by setting up a timer to call itself but isn’t supplying the object necessary. This means it won’t work. If I add the _this object to pass it causes all sorts of problems.
              I’m not a js expert. I’m sure a way to re-factor this will eventually occur to me, but right now I’m just not seeing it.
              start:  function() {
                  Log.log('Starting module: ' + this.name);
                  // Set up the local values
                  var today = moment();
                  this.loaded = false;
                  this.urls = [];
                  this.results = [];
                  // Uses now are today if before noon and tomorrow as today if after noon
                  if (today.hour() >= 12) {
                    var todayFormatted = today.add(1, 'day').format('MM-DD-YYYY');
                  else {
                    var todayFormatted = today.format('MM-DD-YYYY');
                  // Currently set to only pull one day's data so endDayFormatted = todayFormatted
                  //var endDay = today.add(config.showDays, 'days');
                  //var endDayFormatted = endDay.format('MM-DD-YYYY');
                  var endDayFormatted = todayFormatted;
                  // Construct the url array for the schools
                  for (var i in this.config.schools) {
              			this.urls.push({school: this.config.schools[i], url: 'https://api.mealviewer.com/api/v4/school/' + this.config.schools[i] + '/' + todayFormatted + '/' + endDayFormatted + '/'});
                  // Trigger the first request
                  this.getMenuData(this);
                getMenuData: function(_this) {
                  // Make the initial request to the helper then set up the timer to perform the updates
                  _this.sendSocketNotification('GET-MENU-DATA', _this.urls);
                  setTimeout(_this.getMenuData(), _this.config.interval, _this);
                sdetweil @gonzonia
                @gonzonia said in MMM-MealViewer:
                _this.sendSocketNotification(‘GET-MENU-DATA’, _this.urls);
                do this
                    setTimeout(function() {_this.getMenuData(_this)}, _this.config.interval);
                this creates a little inline function which CAN pass parms on to the next routine
                • G
                  gonzonia @sdetweil
                  @sdetweil Thanks! I’ll make the change and see what happens when it should update mid-day tomorrow.
                  • cowboysdudeC
                    Or you could do this:
                    scheduleUpdate: function() {
                           setInterval(() => {
                               this.getMenuData();
                           }, this.config.updateInterval);
                        getMenuData: function() {
                           this.sendSocketNotification('GET-MENU-DATA');
                    At the top of the main js you set the interval:
                    updateInterval: 15 * 60 * 1000,
                    Then in the start section you call it:
                    // Define start sequence.
                       start: function() {
                           this.scheduleUpdate();
                    Either the way Sam showed you or the above will work :)
                    • G
                      gonzonia @cowboysdude
                      @cowboysdude Thanks! I might switch to that. I’ve had to rework it a little because the URL wasn’t getting set except at the first call. I just moved setup for that into the getMenuData and I think it’s all working now. I’ll give it a day to run and see what happens tomorrow before I try messing with it again and update the file on github.
                      -updated to fix grammar
                      • cowboysdudeC
                        Sam is a REALLY smart guy so he gives you the smart guy answer…
                        I’m not as smart so I give you my dumb guy answer LOL
                        It will work either way … so now you def have an answer that works :)
                          sdetweil @cowboysdude
                          @cowboysdude said in MMM-MealViewer:
                          nah, Sam is the LAZY guy… change as LITTLE as possible. especially for folks just starting out
                          • G
                            gonzonia
                            Well, thanks to both of you! I can confirm it is finally working.
                            Now to update github. Someday I should write some documentation too.
                            • htilburgsH
                              htilburgs
                              @cowboysdude, I’m looking for the part where you “change” the XML data to JSON data. I’m trying to write a new MMM, but the data is presented in XML. I like the have it in JSON, so I can use it.
                              Maybe I read over it, but I cannot figure out where you do this.
                              (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
                                sdetweil @htilburgs
                                @htilburgs there are a few xml to json modules
                                https://www.npmjs.com/package/xml2js
                                google search
                                ‘nodejs xmltojson’
                                here is one with a just code, no extra libs
                                https://davidwalsh.name/convert-xml-json
                                • htilburgsH
                                  htilburgs
                                  @sdetweil , I’ve found them, but I don’t know how to use it in combination with the URL that creates the XML.
                                  Indeed the last one with no extra libs looks promising. I tried to simply add this in the node_helper.js but getting stuck at how to use it.
                                  I’ve looked into all the MMM Modules but cannot seem to find an example.
                                    sdetweil @htilburgs
                                    @htilburgs the url bring back the data with request
                                    request(url, function(err, res, body) {
                                        // if no error and server was happy
                                        if(err == null && res.statusCode ==200){
                                        console.log(body);
                                        var json_data=this.xmlToJson(body)
                                        console.log("Speed[0] text is "+json_data.SD[0].SPEED.@attributes.TEXT)
                                    when the server responds, the function is called and passed the data, body)
                                    and then u would convert it from xml to json . using the last code
                                    then the json is accessed with the normal structure notation
                                    (using the sample with the code in the last link)
                                    json_data.SD[0].SPEED.@attributes.TEXT will be ‘1421’
                                    SD is an array (multiple of same xml tags)
                                    a little ugly in the data layour, could get rid of the @attributes thing with a small code change
                                    • htilburgsH
                                      htilburgs
                                      So in my case the URL produces:
                                      0_1576260496007_7fa5a24c-528a-4697-9557-2a9058df2860-image.png image url)
                                      json_data.SD[0].SPEED@attributes.TEXT will be:
                                      json.data.film[0].titel    --> 'Bellicher: Cel'
                                      Correct?
                                        sdetweil @htilburgs
                                        @htilburgs correct (json_data is the name of the output variable, note underscore, not dot, using dot means ‘go into’) … if you use one of the module add ons… not the code shown…
                                          @htilburgs and the number of films in the array would be
                                          json_data.film.length
                                          using the developers window you can put a code stop on the line after the xml2json
                                          and then u can explore the conversion…
                                          you can also use console.log(JSON.stringify(some_object)) and it will dump the structure in json format
                                          • htilburgsH
                                            htilburgs
                                            Mmmm… not working yet…
                                            My current node_helper.js:
                                            const NodeHelper = require('node_helper');
                                            const request = require('request');
                                                start: function() {
                                                    console.log("Starting node_helper for: " + this.name);
                                            	// Changes XML to JSON
                                            	xmlToJson: function(xml) {
                                            		// Create the return object
                                            		var obj = {};
                                            		if (xml.nodeType == 1) { // element
                                            			// do attributes
                                            			if (xml.attributes.length > 0) {
                                            			obj["@attributes"] = {};
                                            				for (var j = 0; j < xml.attributes.length; j++) {
                                            					var attribute = xml.attributes.item(j);
                                            					obj["@attributes"][attribute.nodeName] = attribute.nodeValue;
                                            		} else if (xml.nodeType == 3) { // text
                                            			obj = xml.nodeValue;
                                            		// do children
                                            		if (xml.hasChildNodes()) {
                                            			for(var i = 0; i < xml.childNodes.length; i++) {
                                            				var item = xml.childNodes.item(i);
                                            				var nodeName = item.nodeName;
                                            				if (typeof(obj[nodeName]) == "undefined") {
                                            					obj[nodeName] = xmlToJson(item);
                                            				} else {
                                            					if (typeof(obj[nodeName].push) == "undefined") {
                                            						var old = obj[nodeName];
                                            						obj[nodeName] = [];
                                            						obj[nodeName].push(old);
                                            					obj[nodeName].push(xmlToJson(item));
                                            		return obj;
                                            	getMTVM: function(url) {
                                            			console.log(body);
                                            			var json_data = this.xmlToJson(body)
                                            			console.log("Text is " + json_data.film[0].titel)
                                                    if (notification === 'GET_MTVM') {
                                                        this.getMTVM(payload);
                                            In the dev console I get an error:
                                            TypeError: this.xmlToJson is not a function
                                            • 2 / 3
