    MMM-MealViewer
    48 Posts 6 Posters 34.6k Views 6 Watching
    • G Offline
      gonzonia
      Well, thanks to both of you! I can confirm it is finally working.
      Now to update github. Someday I should write some documentation too.
      • htilburgsH Offline
        htilburgs
        @cowboysdude, I’m looking for the part where you “change” the XML data to JSON data. I’m trying to write a new MMM, but the data is presented in XML. I like the have it in JSON, so I can use it.
        Maybe I read over it, but I cannot figure out where you do this.
        (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
          sdetweil @htilburgs
          @htilburgs there are a few xml to json modules
          https://www.npmjs.com/package/xml2js
          google search
          ‘nodejs xmltojson’
          here is one with a just code, no extra libs
          https://davidwalsh.name/convert-xml-json
            htilburgs
            @sdetweil , I’ve found them, but I don’t know how to use it in combination with the URL that creates the XML.
            Indeed the last one with no extra libs looks promising. I tried to simply add this in the node_helper.js but getting stuck at how to use it.
            I’ve looked into all the MMM Modules but cannot seem to find an example.
              sdetweil @htilburgs
              @htilburgs the url bring back the data with request
              request(url, function(err, res, body) {
                  // if no error and server was happy
                  if(err == null && res.statusCode ==200){
                  console.log(body);
                  var json_data=this.xmlToJson(body)
                  console.log("Speed[0] text is "+json_data.SD[0].SPEED.@attributes.TEXT)
              when the server responds, the function is called and passed the data, body)
              and then u would convert it from xml to json . using the last code
              then the json is accessed with the normal structure notation
              (using the sample with the code in the last link)
              json_data.SD[0].SPEED.@attributes.TEXT will be ‘1421’
              SD is an array (multiple of same xml tags)
              a little ugly in the data layour, could get rid of the @attributes thing with a small code change
                htilburgs
                So in my case the URL produces:
                0_1576260496007_7fa5a24c-528a-4697-9557-2a9058df2860-image.png image url)
                json_data.SD[0].SPEED@attributes.TEXT will be:
                json.data.film[0].titel    --> 'Bellicher: Cel'
                Correct?
                  sdetweil @htilburgs
                  @htilburgs correct (json_data is the name of the output variable, note underscore, not dot, using dot means ‘go into’) … if you use one of the module add ons… not the code shown…
                    @htilburgs and the number of films in the array would be
                    json_data.film.length
                    using the developers window you can put a code stop on the line after the xml2json
                    and then u can explore the conversion…
                    you can also use console.log(JSON.stringify(some_object)) and it will dump the structure in json format
                      htilburgs
                      Mmmm… not working yet…
                      My current node_helper.js:
                      const NodeHelper = require('node_helper');
                      const request = require('request');
                          start: function() {
                              console.log("Starting node_helper for: " + this.name);
                      	// Changes XML to JSON
                      	xmlToJson: function(xml) {
                      		// Create the return object
                      		var obj = {};
                      		if (xml.nodeType == 1) { // element
                      			// do attributes
                      			if (xml.attributes.length > 0) {
                      			obj["@attributes"] = {};
                      				for (var j = 0; j < xml.attributes.length; j++) {
                      					var attribute = xml.attributes.item(j);
                      					obj["@attributes"][attribute.nodeName] = attribute.nodeValue;
                      		} else if (xml.nodeType == 3) { // text
                      			obj = xml.nodeValue;
                      		// do children
                      		if (xml.hasChildNodes()) {
                      			for(var i = 0; i < xml.childNodes.length; i++) {
                      				var item = xml.childNodes.item(i);
                      				var nodeName = item.nodeName;
                      				if (typeof(obj[nodeName]) == "undefined") {
                      					obj[nodeName] = xmlToJson(item);
                      				} else {
                      					if (typeof(obj[nodeName].push) == "undefined") {
                      						var old = obj[nodeName];
                      						obj[nodeName] = [];
                      						obj[nodeName].push(old);
                      					obj[nodeName].push(xmlToJson(item));
                      		return obj;
                      	getMTVM: function(url) {
                      			console.log(body);
                      			var json_data = this.xmlToJson(body)
                      			console.log("Text is " + json_data.film[0].titel)
                              if (notification === 'GET_MTVM') {
                                  this.getMTVM(payload);
                      In the dev console I get an error:
                      TypeError: this.xmlToJson is not a function
                        sdetweil @htilburgs
                        @htilburgs ah the fun of ‘this’…
                                       let self=this
                        			   console.log(body);
                        			   var json_data = self.xmlToJson(body)
                        htilburgsH 1 Reply Last reply Reply Quote 0
                          htilburgs @sdetweil
                          @sdetweil Yeah! That part is working. Now I’ve an other error which has something to do with the xmlToJson function:
                          TypeError: xml.hasChildNodes is not a function
                          Any idea?
                            sdetweil @htilburgs
                            @htilburgs yeh, tricky crap… they had a special runtime that supported that… sorry…
                            have to use one of the libs…
                            in your module folder do
                            npm install xml2js
                            then in your code
                            const xml2js = require('xml2js');
                            then
                                           let self=this
                            			   console.log(body);
                            			   xml2js.parseString(body,function (err,result) {
                            			       let json_data = result // not needed but may make more clear
                              htilburgs @sdetweil
                              @sdetweil Almost there I think ;-)
                              TypeError: Cannot read property '0' of undefined
                                  at /home/pi/MagicMirror/modules/MMM-MyTVMovies/node_helper.js:28:47
                                  at Parser.<anonymous> (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/xml2js/lib/parser.js:306:18)
                                  at Parser.emit (events.js:182:13)
                                  at SAXParser.onclosetag (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/xml2js/lib/parser.js:264:26)
                                  at emit (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/sax/lib/sax.js:624:35)
                                  at emitNode (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/sax/lib/sax.js:629:5)
                                  at closeTag (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/sax/lib/sax.js:889:7)
                                  at SAXParser.write (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/sax/lib/sax.js:1436:13)
                                  at Parser.exports.Parser.Parser.parseString (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/xml2js/lib/parser.js:325:31)
                                  at Parser.parseString (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/xml2js/lib/parser.js:5:59)
                              Has this something to do with the json_data.film[0].titel ??
                              Or is it something else?
                              When I remove .film[0].titel I got:
                              Text is [object Object]
                              200[object Object]
                                sdetweil @htilburgs
                                @htilburgs u should look at the data format
                                               let self=this
                                			   console.log(body);
                                			       console.log(JSON.stringify(json_data))
                                  htilburgs @sdetweil
                                  @sdetweil JSON is perfect:
                                  Thanks for the help so far!! Now I have my data I can play around with it.
                                  • 3 / 3
