    MMM-MealViewer
    48 Posts 6 Posters 35.9k Views 6 Watching
    • cowboysdudeC
      Sam is a REALLY smart guy so he gives you the smart guy answer…
      I’m not as smart so I give you my dumb guy answer LOL
      It will work either way … so now you def have an answer that works :)
        sdetweil @cowboysdude
        @cowboysdude said in MMM-MealViewer:
        nah, Sam is the LAZY guy… change as LITTLE as possible. especially for folks just starting out
        • G
          gonzonia
          Well, thanks to both of you! I can confirm it is finally working.
          Now to update github. Someday I should write some documentation too.
          • htilburgsH
            htilburgs
            @cowboysdude, I’m looking for the part where you “change” the XML data to JSON data. I’m trying to write a new MMM, but the data is presented in XML. I like the have it in JSON, so I can use it.
            Maybe I read over it, but I cannot figure out where you do this.
            (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
              sdetweil @htilburgs
              @htilburgs there are a few xml to json modules
              https://www.npmjs.com/package/xml2js
              google search
              ‘nodejs xmltojson’
              here is one with a just code, no extra libs
              https://davidwalsh.name/convert-xml-json
              • htilburgsH
                htilburgs
                @sdetweil , I’ve found them, but I don’t know how to use it in combination with the URL that creates the XML.
                Indeed the last one with no extra libs looks promising. I tried to simply add this in the node_helper.js but getting stuck at how to use it.
                I’ve looked into all the MMM Modules but cannot seem to find an example.
                  sdetweil @htilburgs
                  @htilburgs the url bring back the data with request
                  request(url, function(err, res, body) {
                      // if no error and server was happy
                      if(err == null && res.statusCode ==200){
                      console.log(body);
                      var json_data=this.xmlToJson(body)
                      console.log("Speed[0] text is "+json_data.SD[0].SPEED.@attributes.TEXT)
                  when the server responds, the function is called and passed the data, body)
                  and then u would convert it from xml to json . using the last code
                  then the json is accessed with the normal structure notation
                  (using the sample with the code in the last link)
                  json_data.SD[0].SPEED.@attributes.TEXT will be ‘1421’
                  SD is an array (multiple of same xml tags)
                  a little ugly in the data layour, could get rid of the @attributes thing with a small code change
                  • htilburgsH
                    htilburgs
                    So in my case the URL produces:
                    0_1576260496007_7fa5a24c-528a-4697-9557-2a9058df2860-image.png image url)
                    json_data.SD[0].SPEED@attributes.TEXT will be:
                    json.data.film[0].titel    --> 'Bellicher: Cel'
                    Correct?
                      sdetweil @htilburgs
                      @htilburgs correct (json_data is the name of the output variable, note underscore, not dot, using dot means ‘go into’) … if you use one of the module add ons… not the code shown…
                        @htilburgs and the number of films in the array would be
                        json_data.film.length
                        using the developers window you can put a code stop on the line after the xml2json
                        and then u can explore the conversion…
                        you can also use console.log(JSON.stringify(some_object)) and it will dump the structure in json format
                        • htilburgsH
                          htilburgs
                          Mmmm… not working yet…
                          My current node_helper.js:
                          const NodeHelper = require('node_helper');
                          const request = require('request');
                              start: function() {
                                  console.log("Starting node_helper for: " + this.name);
                          	// Changes XML to JSON
                          	xmlToJson: function(xml) {
                          		// Create the return object
                          		var obj = {};
                          		if (xml.nodeType == 1) { // element
                          			// do attributes
                          			if (xml.attributes.length > 0) {
                          			obj["@attributes"] = {};
                          				for (var j = 0; j < xml.attributes.length; j++) {
                          					var attribute = xml.attributes.item(j);
                          					obj["@attributes"][attribute.nodeName] = attribute.nodeValue;
                          		} else if (xml.nodeType == 3) { // text
                          			obj = xml.nodeValue;
                          		// do children
                          		if (xml.hasChildNodes()) {
                          			for(var i = 0; i < xml.childNodes.length; i++) {
                          				var item = xml.childNodes.item(i);
                          				var nodeName = item.nodeName;
                          				if (typeof(obj[nodeName]) == "undefined") {
                          					obj[nodeName] = xmlToJson(item);
                          				} else {
                          					if (typeof(obj[nodeName].push) == "undefined") {
                          						var old = obj[nodeName];
                          						obj[nodeName] = [];
                          						obj[nodeName].push(old);
                          					obj[nodeName].push(xmlToJson(item));
                          		return obj;
                          	getMTVM: function(url) {
                          			console.log(body);
                          			var json_data = this.xmlToJson(body)
                          			console.log("Text is " + json_data.film[0].titel)
                                  if (notification === 'GET_MTVM') {
                                      this.getMTVM(payload);
                          In the dev console I get an error:
                          TypeError: this.xmlToJson is not a function
                            sdetweil @htilburgs
                            @htilburgs ah the fun of ‘this’…
                                           let self=this
                            			   console.log(body);
                            			   var json_data = self.xmlToJson(body)
                            htilburgsH 1 Reply Last reply
                            • htilburgsH
                              htilburgs @sdetweil
                              @sdetweil Yeah! That part is working. Now I’ve an other error which has something to do with the xmlToJson function:
                              TypeError: xml.hasChildNodes is not a function
                              Any idea?
                                sdetweil @htilburgs
                                @htilburgs yeh, tricky crap… they had a special runtime that supported that… sorry…
                                have to use one of the libs…
                                in your module folder do
                                npm install xml2js
                                then in your code
                                const xml2js = require('xml2js');
                                then
                                               let self=this
                                			   console.log(body);
                                			   xml2js.parseString(body,function (err,result) {
                                			       let json_data = result // not needed but may make more clear
                                • htilburgsH
                                  htilburgs @sdetweil
                                  @sdetweil Almost there I think ;-)
                                  TypeError: Cannot read property '0' of undefined
                                      at /home/pi/MagicMirror/modules/MMM-MyTVMovies/node_helper.js:28:47
                                      at Parser.<anonymous> (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/xml2js/lib/parser.js:306:18)
                                      at Parser.emit (events.js:182:13)
                                      at SAXParser.onclosetag (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/xml2js/lib/parser.js:264:26)
                                      at emit (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/sax/lib/sax.js:624:35)
                                      at emitNode (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/sax/lib/sax.js:629:5)
                                      at closeTag (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/sax/lib/sax.js:889:7)
                                      at SAXParser.write (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/sax/lib/sax.js:1436:13)
                                      at Parser.exports.Parser.Parser.parseString (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/xml2js/lib/parser.js:325:31)
                                      at Parser.parseString (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/xml2js/lib/parser.js:5:59)
                                  Has this something to do with the json_data.film[0].titel ??
                                  Or is it something else?
                                  When I remove .film[0].titel I got:
                                  Text is [object Object]
                                  200[object Object]
                                    sdetweil @htilburgs
                                    @htilburgs u should look at the data format
                                                   let self=this
                                    			   console.log(body);
                                    			       console.log(JSON.stringify(json_data))
                                    • htilburgsH
                                      htilburgs @sdetweil
                                      @sdetweil JSON is perfect:
                                      Thanks for the help so far!! Now I have my data I can play around with it.
                                      • 3 / 3
