    ioBroker MagicMirror Module
    16 Posts 8 Posters 8.1k Views 7 Watching
    • FoziF Offline
      Fozi Project Sponsor @Chris87-ux
      @Chris87-ux I’m a bit late to the party but as I’m tinkering with that module. too, maybe I can help.
      First, change the port to 8082. This seems to have been changed in one of the 2.x releases of the simple API.
      Second, go in ioBroker to the adapter setting for the web adater (!) and check “Eingebaute ‘Simple API’”
      Now the values should be pulled from ioBroker. Hope that helps.
      • F Offline
        falke69 @Fozi
        @Fozi does not work :disappointed_face:
        • FoziF Offline
          Fozi Project Sponsor @falke69
          @falke69 is “[IPv4] 0.0.0.0 - Alle IP-Adressen zulassen” enabled?
          If this doesn’t work, too, the I’d ask bluefox in the ioBroker forum. There is also a very lenghty thread about that issue.
          • F Offline
            falke69 @Fozi
            @Fozi have all settings exactly as in the screenshot
            • FoziF Offline
              @falke69 Damned…Then try port 8087, maybe this is your standard port.
              Are you using Homematic components, too? If so, then check MMM-Homematic. I switched to that module as its presentation is much nicer and the readouts of the actuators and sensors are translated and can be coloured if thresholds are met.
              • F Offline
                falke69 @Fozi
                @Fozi have already installed MMM-Homematic.
                But found the other module better (line break)
                If all of my windows are open, everything is shown on one line
                • FoziF Offline
                  @falke69 What I didn’t like with MMM-ioBroker, was that the door and windows sensor didn’t display “auf”/“zu” but “true”/“false” or “1”/“0”. I couldn’t find a place in the code to modify or translate the status messages, so I dropped it.
                  • F Offline
                    falke69 @Fozi
                    @Fozi
                    that’s how I solved it
                    Program on CCU
                    var sec=dom.GetObject("Verschlussensoren");
                    string i;
                    string list;
                    string seit;
                    string itemName;
                    string status_new;
                    string stunde=system.Date("%H").ToInteger();
                    string minute=system.Date("%M").ToInteger();
                    string textReplace = "Kontakt";
                    list="";
                    integer textReplaceLength = textReplace.Length();
                    foreach(i,sec.EnumUsedIDs()) {
                    var item=dom.GetObject(i);
                    var dev=dom.GetObject(item.Device());
                    if((dev.HssType()=="HM-Sec-RHS") ||
                    (dev.HssType()=="HM-Sec-SC") ||
                    (dev.HssType()=="HM-Sec-SC-2")||
                    (dev.HssType()=="HM-Sec-RHS-2")||
                    (dev.HssType()=="HM-Sec-SCo")) {
                    var status = item.DPByHssDP("STATE").Value();
                    if(status.Value()) {
                    if (status == 1 ) { status_new = "gekippt"; }
                    if (status == 2 ) { status_new = "offen"; }
                    itemName=dev.Name();
                    if(itemName.Length() >= textReplaceLength){
                    itemName = itemName.Substr(textReplaceLength, itemName.Length() - textReplaceLength);
                    list=list # itemName #",";
                    if(list.Length() < 5){
                    list=" kein Fenster ";
                    WriteLine(list);
                    dom.GetObject("offene Fenster").State(list);
                    settings MMM-ioBroker
                    // iobroker offene Fenster / brennende Lampen
                             disabled: false,
                             module: 'MMM-ioBroker',
                             position: 'top_right',
                          host: 'localhost',
                            port: '8082',
                            https: false,
                            devices: [
                            { name: 'offene Fenster:',
                            deviceStates: [
                          { id: 'hm-rega.0.3102', icon: '',  suffix: '' },
                          { name: 'brennende Lampen:',
                            deviceStates: [
                            { id: 'hm-rega.0.9048', icon: '',  suffix: '' },
                    FoziF M 2 Replies Last reply Reply Quote 1
                    • FoziF Offline
                      @falke69 Thanks so much! I bookmarked this post for later use, if the MMM-Homeatic module won’t serve as I expect. Very interesting that you have to script the CCU. Great job!
                      • kusselinK Offline
                        kusselin
                        Hallo Zusammen, ich klinke mich hier mal mit ein. Ich habe das MMM-irobroker modul installiert und auch in die Config geschrieben. Ich habe einen Zigbee stick udn dort habe ich ein lumi weather sensor erfolgreich gepairt.
                        Leider bin ich mir nun nicht schlüssig was in die Config mit reinkommt damit die humidity und die temoeratur angezeigt wird. Könnt ihr mir den Code bitte mitteilen…jetzt sieht der Code so aus:
                            position: 'bottom_right',
                              host: '192.168.200.120',
                              port: '8081',
                              https: false,
                              devices: [
                                  { name: 'lumi.weather',
                                    deviceStates: [
                                                      { id: 'mqtt.0.sensorX.temperature', icon: 'wi wi-thermometer', suffix: '&deg;' },
                                                      { id: 'mqtt.0.sensorX.humidity',    icon: 'wi wi-humidity',    suffix: '%' }
                        Das mqtt passt natürlich nicht. Ich weiss es aber nicht wie ich es einfügen muss.
                        Hier noch die Infos aus iobroker für den Weather adapter:
                        00158d0002fb4915
                        lumi.weather
                        	device
                        battery
                        Battery percent
                        	state	battery.percent
                        humidity	state
                        Humidity
                        	state	value.humidity			50.3 %
                        link_quality	state
                        Link quality
                        	state	state			70
                        pressure	state
                        Pressure
                        	state	value.pressure			1009 hPa
                        temperature	state
                        Temperature
                        	state	value.temperature			20.31 °C
                        voltage
                        Battery voltage
                        	state	battery.voltage
                        Über ne Info wie der Code aussehen muss herzichen Dank.
                        Gruss
                        (Hello everyone, I’m going to hook myself in here. I installed the MMM-irobroker module and also wrote it in the config. I have a Zigbee stick and there I successfully paired a lumi weather sensor.
                        Unfortunately I am not conclusive now what comes into the config so that the humidity and the temperature is displayed. Can you tell me the code please … now the code looks like this:)
                        Das Webinterface von iobroker erreiche ich mit 192.168.200.120:8081
                        Die ID habe ich gelesen ist wichtig…nur finde ich diese auch nicht…ist halt immer schwer wenn man sowas zum ersten mal macht! Ist mit ID die API gemeint?
                        1 Reply Last reply Reply Quote -1
