    ioBroker MagicMirror Module
    16 Posts 8 Posters 8.0k Views 7 Watching
    • cruunnerrC Offline
      cruunnerr
      @GermanBluefox
      i just installed the module and it works :) so far so good ^^
      The only thing is, that no icons appear. Any idea?
                disabled: false,
                module: 'MMM-ioBroker',
                position: 'top_center',
                  host: '192.168.x.x',
                  port: '8082',
                  https: false,
                  devices: [
                      { name: "Oelstand",
                        deviceStates: [
                                          { id: "mqtt.0.Oeltank.Oelstand", icon: "fa fa-oil-can", suffix: " L" },
                      { name: 'Oelpreis',
                        deviceStates: [
                                          { id: 'javascript.0.Heizoel.Ist.Price', icon: 'fa fa-euro-sign', suffix: ' €/100L' },
                                       //   { id: 'avascript.0.Heizoel.Ist.Date',    icon: 'fa clock',    suffix: '' }
                      { name: 'Wohnzimmer',
                        deviceStates: [
                                          { id: 'maxcube.0.devices.thermostat_XXXXX.setpoint', icon: 'wi wi-thermometer', suffix: '°' },
                                          { id: 'maxcube.0.devices.thermostat_XXXXX.valve', icon: 'wi wi-thermometer', suffix: ' %' },
                      { name: 'Esszimmer',
                        deviceStates: [
                      { name: 'Kueche',
                        deviceStates: [
                      { name: 'Schlafzimmer',
                        deviceStates: [
                      { name: 'Bad',
                        deviceStates: [
        Chris87-ux
        @GermanBluefox ,
        Thanks for this module it is a great thing, unfortunately it seems to be not working with modbus values.
              position: 'bottom_bar',
                host: '192.168.178.xx',
                port: '8087',
                https: false,
                devices: [
                    { name: 'Pufferspeicher',
                      deviceStates: [
                                        { id: 'modbus.0.inputRegisters.12288_puffer_füllung',       icon: 'wi wi-thermometer',   suffix: '%' },
                                        { id: 'modbus.0.inputRegisters.78_Pufferspeicher_Druck',    icon: 'wi wi-barometer',     suffix: 'bar'}
                    { name: 'Druckluft',
                      deviceStates: [
                                        { id: 'modbus.0.inputRegisters.42_Druckluft_Dachboden1',       icon: 'wi wi-barometer',   suffix: 'bar' }
        do you see any failure in the code?
        Everything i see on the mirror is e.g. “— %”.
        Br Chris
        • FoziF Offline
          Fozi Project Sponsor @Chris87-ux
          @Chris87-ux I’m a bit late to the party but as I’m tinkering with that module. too, maybe I can help.
          First, change the port to 8082. This seems to have been changed in one of the 2.x releases of the simple API.
          Second, go in ioBroker to the adapter setting for the web adater (!) and check “Eingebaute ‘Simple API’”
          Now the values should be pulled from ioBroker. Hope that helps.
          • F Offline
            falke69 @Fozi
            @Fozi does not work :disappointed_face:
            • FoziF Offline
              Fozi Project Sponsor @falke69
              @falke69 is “[IPv4] 0.0.0.0 - Alle IP-Adressen zulassen” enabled?
              If this doesn’t work, too, the I’d ask bluefox in the ioBroker forum. There is also a very lenghty thread about that issue.
              • F Offline
                falke69 @Fozi
                @Fozi have all settings exactly as in the screenshot
                • FoziF Offline
                  @falke69 Damned…Then try port 8087, maybe this is your standard port.
                  Are you using Homematic components, too? If so, then check MMM-Homematic. I switched to that module as its presentation is much nicer and the readouts of the actuators and sensors are translated and can be coloured if thresholds are met.
                  • F Offline
                    falke69 @Fozi
                    @Fozi have already installed MMM-Homematic.
                    But found the other module better (line break)
                    If all of my windows are open, everything is shown on one line
                    • FoziF Offline
                      @falke69 What I didn’t like with MMM-ioBroker, was that the door and windows sensor didn’t display “auf”/“zu” but “true”/“false” or “1”/“0”. I couldn’t find a place in the code to modify or translate the status messages, so I dropped it.
                      • F Offline
                        falke69 @Fozi
                        @Fozi
                        that’s how I solved it
                        Program on CCU
                        var sec=dom.GetObject("Verschlussensoren");
                        string i;
                        string list;
                        string seit;
                        string itemName;
                        string status_new;
                        string stunde=system.Date("%H").ToInteger();
                        string minute=system.Date("%M").ToInteger();
                        string textReplace = "Kontakt";
                        list="";
                        integer textReplaceLength = textReplace.Length();
                        foreach(i,sec.EnumUsedIDs()) {
                        var item=dom.GetObject(i);
                        var dev=dom.GetObject(item.Device());
                        if((dev.HssType()=="HM-Sec-RHS") ||
                        (dev.HssType()=="HM-Sec-SC") ||
                        (dev.HssType()=="HM-Sec-SC-2")||
                        (dev.HssType()=="HM-Sec-RHS-2")||
                        (dev.HssType()=="HM-Sec-SCo")) {
                        var status = item.DPByHssDP("STATE").Value();
                        if(status.Value()) {
                        if (status == 1 ) { status_new = "gekippt"; }
                        if (status == 2 ) { status_new = "offen"; }
                        itemName=dev.Name();
                        if(itemName.Length() >= textReplaceLength){
                        itemName = itemName.Substr(textReplaceLength, itemName.Length() - textReplaceLength);
                        list=list # itemName #",";
                        if(list.Length() < 5){
                        list=" kein Fenster ";
                        WriteLine(list);
                        dom.GetObject("offene Fenster").State(list);
                        settings MMM-ioBroker
                        // iobroker offene Fenster / brennende Lampen
                                 disabled: false,
                                 position: 'top_right',
                              host: 'localhost',
                                port: '8082',
                                https: false,
                                devices: [
                                { name: 'offene Fenster:',
                                deviceStates: [
                              { id: 'hm-rega.0.3102', icon: '',  suffix: '' },
                              { name: 'brennende Lampen:',
                                deviceStates: [
                                { id: 'hm-rega.0.9048', icon: '',  suffix: '' },
                        FoziF M 2 Replies Last reply Reply Quote 1
