    ioBroker MagicMirror Module
    16 Posts 8 Posters 9.3k Views 7 Watching
    • G
      GermanBluefox
      Re: IObroker
      You can find it here: https://github.com/ioBroker/MMM-ioBroker
      • cruunnerrC
        cruunnerr
        @GermanBluefox
        i just installed the module and it works :) so far so good ^^
        The only thing is, that no icons appear. Any idea?
                  disabled: false,
                  module: 'MMM-ioBroker',
                  position: 'top_center',
                    host: '192.168.x.x',
                    port: '8082',
                    https: false,
                    devices: [
                        { name: "Oelstand",
                          deviceStates: [
                                            { id: "mqtt.0.Oeltank.Oelstand", icon: "fa fa-oil-can", suffix: " L" },
                        { name: 'Oelpreis',
                          deviceStates: [
                                            { id: 'javascript.0.Heizoel.Ist.Price', icon: 'fa fa-euro-sign', suffix: ' €/100L' },
                                         //   { id: 'avascript.0.Heizoel.Ist.Date',    icon: 'fa clock',    suffix: '' }
                        { name: 'Wohnzimmer',
                          deviceStates: [
                                            { id: 'maxcube.0.devices.thermostat_XXXXX.setpoint', icon: 'wi wi-thermometer', suffix: '°' },
                                            { id: 'maxcube.0.devices.thermostat_XXXXX.valve', icon: 'wi wi-thermometer', suffix: ' %' },
                        { name: 'Esszimmer',
                          deviceStates: [
                        { name: 'Kueche',
                          deviceStates: [
                        { name: 'Schlafzimmer',
                          deviceStates: [
                        { name: 'Bad',
                          deviceStates: [
          Chris87-ux
          @GermanBluefox ,
          Thanks for this module it is a great thing, unfortunately it seems to be not working with modbus values.
                position: 'bottom_bar',
                  host: '192.168.178.xx',
                  port: '8087',
                  https: false,
                  devices: [
                      { name: 'Pufferspeicher',
                        deviceStates: [
                                          { id: 'modbus.0.inputRegisters.12288_puffer_füllung',       icon: 'wi wi-thermometer',   suffix: '%' },
                                          { id: 'modbus.0.inputRegisters.78_Pufferspeicher_Druck',    icon: 'wi wi-barometer',     suffix: 'bar'}
                      { name: 'Druckluft',
                        deviceStates: [
                                          { id: 'modbus.0.inputRegisters.42_Druckluft_Dachboden1',       icon: 'wi wi-barometer',   suffix: 'bar' }
          do you see any failure in the code?
          Everything i see on the mirror is e.g. “— %”.
          Br Chris
          • FoziF
            Fozi Project Sponsor @Chris87-ux
            @Chris87-ux I’m a bit late to the party but as I’m tinkering with that module. too, maybe I can help.
            First, change the port to 8082. This seems to have been changed in one of the 2.x releases of the simple API.
            Second, go in ioBroker to the adapter setting for the web adater (!) and check “Eingebaute ‘Simple API’”
            Now the values should be pulled from ioBroker. Hope that helps.
            • F
              falke69 @Fozi
              @Fozi does not work :disappointed_face:
              • FoziF
                Fozi Project Sponsor @falke69
                @falke69 is “[IPv4] 0.0.0.0 - Alle IP-Adressen zulassen” enabled?
                If this doesn’t work, too, the I’d ask bluefox in the ioBroker forum. There is also a very lenghty thread about that issue.
                • F
                  falke69 @Fozi
                  @Fozi have all settings exactly as in the screenshot
                  • FoziF
                    @falke69 Damned…Then try port 8087, maybe this is your standard port.
                    Are you using Homematic components, too? If so, then check MMM-Homematic. I switched to that module as its presentation is much nicer and the readouts of the actuators and sensors are translated and can be coloured if thresholds are met.
                    • F
                      falke69 @Fozi
                      @Fozi have already installed MMM-Homematic.
                      But found the other module better (line break)
                      If all of my windows are open, everything is shown on one line
                      • FoziF
                        @falke69 What I didn’t like with MMM-ioBroker, was that the door and windows sensor didn’t display “auf”/“zu” but “true”/“false” or “1”/“0”. I couldn’t find a place in the code to modify or translate the status messages, so I dropped it.
                        • F
                          falke69 @Fozi
                          @Fozi
                          that’s how I solved it
                          Program on CCU
                          var sec=dom.GetObject("Verschlussensoren");
                          string i;
                          string list;
                          string seit;
                          string itemName;
                          string status_new;
                          string stunde=system.Date("%H").ToInteger();
                          string minute=system.Date("%M").ToInteger();
                          string textReplace = "Kontakt";
                          list="";
                          integer textReplaceLength = textReplace.Length();
                          foreach(i,sec.EnumUsedIDs()) {
                          var item=dom.GetObject(i);
                          var dev=dom.GetObject(item.Device());
                          if((dev.HssType()=="HM-Sec-RHS") ||
                          (dev.HssType()=="HM-Sec-SC") ||
                          (dev.HssType()=="HM-Sec-SC-2")||
                          (dev.HssType()=="HM-Sec-RHS-2")||
                          (dev.HssType()=="HM-Sec-SCo")) {
                          var status = item.DPByHssDP("STATE").Value();
                          if(status.Value()) {
                          if (status == 1 ) { status_new = "gekippt"; }
                          if (status == 2 ) { status_new = "offen"; }
                          itemName=dev.Name();
                          if(itemName.Length() >= textReplaceLength){
                          itemName = itemName.Substr(textReplaceLength, itemName.Length() - textReplaceLength);
                          list=list # itemName #",";
                          if(list.Length() < 5){
                          list=" kein Fenster ";
                          WriteLine(list);
                          dom.GetObject("offene Fenster").State(list);
                          settings MMM-ioBroker
                          // iobroker offene Fenster / brennende Lampen
                                   disabled: false,
                                   position: 'top_right',
                                host: 'localhost',
                                  port: '8082',
                                  https: false,
                                  devices: [
                                  { name: 'offene Fenster:',
                                  deviceStates: [
                                { id: 'hm-rega.0.3102', icon: '',  suffix: '' },
                                { name: 'brennende Lampen:',
                                  deviceStates: [
                                  { id: 'hm-rega.0.9048', icon: '',  suffix: '' },
                          FoziF M 2 Replies Last reply Reply Quote 1
                          • FoziF
                            @falke69 Thanks so much! I bookmarked this post for later use, if the MMM-Homeatic module won’t serve as I expect. Very interesting that you have to script the CCU. Great job!
                            • kusselinK
                              kusselin
                              Hallo Zusammen, ich klinke mich hier mal mit ein. Ich habe das MMM-irobroker modul installiert und auch in die Config geschrieben. Ich habe einen Zigbee stick udn dort habe ich ein lumi weather sensor erfolgreich gepairt.
                              Leider bin ich mir nun nicht schlüssig was in die Config mit reinkommt damit die humidity und die temoeratur angezeigt wird. Könnt ihr mir den Code bitte mitteilen…jetzt sieht der Code so aus:
                                  position: 'bottom_right',
                                    host: '192.168.200.120',
                                    port: '8081',
                                    https: false,
                                    devices: [
                                        { name: 'lumi.weather',
                                          deviceStates: [
                                                            { id: 'mqtt.0.sensorX.temperature', icon: 'wi wi-thermometer', suffix: '&deg;' },
                                                            { id: 'mqtt.0.sensorX.humidity',    icon: 'wi wi-humidity',    suffix: '%' }
                              Das mqtt passt natürlich nicht. Ich weiss es aber nicht wie ich es einfügen muss.
                              Hier noch die Infos aus iobroker für den Weather adapter:
                              00158d0002fb4915
                              lumi.weather
                              	device
                              battery
                              Battery percent
                              	state	battery.percent
                              humidity	state
                              Humidity
                              	state	value.humidity			50.3 %
                              link_quality	state
                              Link quality
                              	state	state			70
                              pressure	state
                              Pressure
                              	state	value.pressure			1009 hPa
                              temperature	state
                              Temperature
                              	state	value.temperature			20.31 °C
                              voltage
                              Battery voltage
                              	state	battery.voltage
                              Über ne Info wie der Code aussehen muss herzichen Dank.
                              Gruss
                              (Hello everyone, I’m going to hook myself in here. I installed the MMM-irobroker module and also wrote it in the config. I have a Zigbee stick and there I successfully paired a lumi weather sensor.
                              Unfortunately I am not conclusive now what comes into the config so that the humidity and the temperature is displayed. Can you tell me the code please … now the code looks like this:)
                              Das Webinterface von iobroker erreiche ich mit 192.168.200.120:8081
                              Die ID habe ich gelesen ist wichtig…nur finde ich diese auch nicht…ist halt immer schwer wenn man sowas zum ersten mal macht! Ist mit ID die API gemeint?
                              1 Reply Last reply Reply Quote -1
                                Jensen
                                Ich habe beim Modul ioBroker Probleme.
                                Es wird nur undefined angezeigt.
                                Ich konnte durch console.Logs erkennen, daß dort die Daten ankommen.
                                Wo muß ich nun weitersuchen?
                                Bin für jede Hilfe dankbar.
                                Gruß Jens
                                  Jensen
                                  das war die Lösung, ändern in MMM-ioBroker.js
                                    getTemplate: function () {
                                      return 'MMM-ioBroker.njk';
                                    MichaelS @falke69
                                    @falke69
                                    Hallo, ich habe auch das Problem mit den Anzeigen true und false. Würde gerne Ihre Lösung umsetzten. Ich verstehe aber nicht mit welchem Programm und wo das programmiert wird.
                                    Im ioBroker selbst (welcher Adapter) oder auf dem Magic Mirror (welches Modul).
                                    Ich würde mich sehr über Unterstützung freuen.
                                    Beste Grüße
                                    Michael
