    ioBroker MagicMirror Module
    16 Posts 8 Posters 9.4k Views 7 Watching
    • FoziF
      Fozi Project Sponsor @falke69
      @falke69 is “[IPv4] 0.0.0.0 - Alle IP-Adressen zulassen” enabled?
      If this doesn’t work, too, the I’d ask bluefox in the ioBroker forum. There is also a very lenghty thread about that issue.
      F 1 Reply Last reply
      • F
        falke69 @Fozi
        @Fozi have all settings exactly as in the screenshot
        FoziF 1 Reply Last reply
        • FoziF
          @falke69 Damned…Then try port 8087, maybe this is your standard port.
          Are you using Homematic components, too? If so, then check MMM-Homematic. I switched to that module as its presentation is much nicer and the readouts of the actuators and sensors are translated and can be coloured if thresholds are met.
          • F
            falke69 @Fozi
            @Fozi have already installed MMM-Homematic.
            But found the other module better (line break)
            If all of my windows are open, everything is shown on one line
            • FoziF
              @falke69 What I didn’t like with MMM-ioBroker, was that the door and windows sensor didn’t display “auf”/“zu” but “true”/“false” or “1”/“0”. I couldn’t find a place in the code to modify or translate the status messages, so I dropped it.
              • F
                falke69 @Fozi
                @Fozi
                that’s how I solved it
                Program on CCU
                var sec=dom.GetObject("Verschlussensoren");
                string i;
                string list;
                string seit;
                string itemName;
                string status_new;
                string stunde=system.Date("%H").ToInteger();
                string minute=system.Date("%M").ToInteger();
                string textReplace = "Kontakt";
                list="";
                integer textReplaceLength = textReplace.Length();
                foreach(i,sec.EnumUsedIDs()) {
                var item=dom.GetObject(i);
                var dev=dom.GetObject(item.Device());
                if((dev.HssType()=="HM-Sec-RHS") ||
                (dev.HssType()=="HM-Sec-SC") ||
                (dev.HssType()=="HM-Sec-SC-2")||
                (dev.HssType()=="HM-Sec-RHS-2")||
                (dev.HssType()=="HM-Sec-SCo")) {
                var status = item.DPByHssDP("STATE").Value();
                if(status.Value()) {
                if (status == 1 ) { status_new = "gekippt"; }
                if (status == 2 ) { status_new = "offen"; }
                itemName=dev.Name();
                if(itemName.Length() >= textReplaceLength){
                itemName = itemName.Substr(textReplaceLength, itemName.Length() - textReplaceLength);
                list=list # itemName #",";
                if(list.Length() < 5){
                list=" kein Fenster ";
                WriteLine(list);
                dom.GetObject("offene Fenster").State(list);
                settings MMM-ioBroker
                // iobroker offene Fenster / brennende Lampen
                         disabled: false,
                         module: 'MMM-ioBroker',
                         position: 'top_right',
                      host: 'localhost',
                        port: '8082',
                        https: false,
                        devices: [
                        { name: 'offene Fenster:',
                        deviceStates: [
                      { id: 'hm-rega.0.3102', icon: '',  suffix: '' },
                      { name: 'brennende Lampen:',
                        deviceStates: [
                        { id: 'hm-rega.0.9048', icon: '',  suffix: '' },
                FoziF M 2 Replies Last reply
                • FoziF
                  @falke69 Thanks so much! I bookmarked this post for later use, if the MMM-Homeatic module won’t serve as I expect. Very interesting that you have to script the CCU. Great job!
                  • kusselinK
                    kusselin
                    Hallo Zusammen, ich klinke mich hier mal mit ein. Ich habe das MMM-irobroker modul installiert und auch in die Config geschrieben. Ich habe einen Zigbee stick udn dort habe ich ein lumi weather sensor erfolgreich gepairt.
                    Leider bin ich mir nun nicht schlüssig was in die Config mit reinkommt damit die humidity und die temoeratur angezeigt wird. Könnt ihr mir den Code bitte mitteilen…jetzt sieht der Code so aus:
                        position: 'bottom_right',
                          host: '192.168.200.120',
                          port: '8081',
                          https: false,
                          devices: [
                              { name: 'lumi.weather',
                                deviceStates: [
                                                  { id: 'mqtt.0.sensorX.temperature', icon: 'wi wi-thermometer', suffix: '&deg;' },
                                                  { id: 'mqtt.0.sensorX.humidity',    icon: 'wi wi-humidity',    suffix: '%' }
                    Das mqtt passt natürlich nicht. Ich weiss es aber nicht wie ich es einfügen muss.
                    Hier noch die Infos aus iobroker für den Weather adapter:
                    00158d0002fb4915
                    lumi.weather
                    	device
                    battery
                    Battery percent
                    	state	battery.percent
                    humidity	state
                    Humidity
                    	state	value.humidity			50.3 %
                    link_quality	state
                    Link quality
                    	state	state			70
                    pressure	state
                    Pressure
                    	state	value.pressure			1009 hPa
                    temperature	state
                    Temperature
                    	state	value.temperature			20.31 °C
                    voltage
                    Battery voltage
                    	state	battery.voltage
                    Über ne Info wie der Code aussehen muss herzichen Dank.
                    Gruss
                    (Hello everyone, I’m going to hook myself in here. I installed the MMM-irobroker module and also wrote it in the config. I have a Zigbee stick and there I successfully paired a lumi weather sensor.
                    Unfortunately I am not conclusive now what comes into the config so that the humidity and the temperature is displayed. Can you tell me the code please … now the code looks like this:)
                    Das Webinterface von iobroker erreiche ich mit 192.168.200.120:8081
                    Die ID habe ich gelesen ist wichtig…nur finde ich diese auch nicht…ist halt immer schwer wenn man sowas zum ersten mal macht! Ist mit ID die API gemeint?
                    Reply Quote -1
                      Jensen
                      Ich habe beim Modul ioBroker Probleme.
                      Es wird nur undefined angezeigt.
                      Ich konnte durch console.Logs erkennen, daß dort die Daten ankommen.
                      Wo muß ich nun weitersuchen?
                      Bin für jede Hilfe dankbar.
                      Gruß Jens
                      Reply Quote -1
                        Jensen
                        das war die Lösung, ändern in MMM-ioBroker.js
                          getTemplate: function () {
                            return 'MMM-ioBroker.njk';
                          MichaelS @falke69
                          @falke69
                          Hallo, ich habe auch das Problem mit den Anzeigen true und false. Würde gerne Ihre Lösung umsetzten. Ich verstehe aber nicht mit welchem Programm und wo das programmiert wird.
                          Im ioBroker selbst (welcher Adapter) oder auf dem Magic Mirror (welches Modul).
                          Ich würde mich sehr über Unterstützung freuen.
                          Beste Grüße
                          Michael
