    MMM-Mail
    emailimap
    22 Posts 9 Posters 28.5k Views 11 Watching
    • PiepsP
      Pieps @travisbarket
      @travisbarket damn, your right. That’s a stupic copy paste failure… the right key is pass
      • cowboysdudeC
        Thank you @travisbarket I’ll get around to trying it again soon LOL
        • cowboysdudeC
          Deleted it and started over and BAM working! Thank you all!
            carteblanche @Pieps
            @Pieps Great work on the module! I’ve tried it and it works great.
            Really love the New Mail alert feature, however for me the sender name is coming up as “undefined”. Any suggestions?
            Another thought on spam…I get a lot of spam mail and since the module picks up mail from the server before it passes through my client-side spam filter its sending a lot of those unwanted spam messages into my mirror. It would be cool if the module could somehow filter the messages that get displayed. Do you think something like that is feasible?
            AbuitimeA 1 Reply Last reply
            • AbuitimeA
              Abuitime @carteblanche
              @carteblanche One suggestion on spam. I had the same problem and so I had all my filtered emails(those not spam) forwarded to an external email account. I then setup the module with the external email account.
              Just a suggestion :)
              C 1 Reply Last reply
                carteblanche @Abuitime
                @Abuitime Thanks for the suggestion! However I’m wondering how did you set up the forwarder to only forward the filtered mail? The way my forwarder works is it picks up mail from the server side so again it gets forwarded prior to it being filtered by my spam filter.
                • PiepsP
                  Pieps
                  hi @carteblanche,
                  I will take a look to the undefined name problem. I have an Idea to solve it ;-)
                  In terms of the spam problem, I think the best solution is to use a server-side spam filter or the solution by @carteblanche . Another possible solution would be to copy the non spam mails to another imap folder. As soon as I come to, I will add the IMAP-Folder to the module-config.
                    carteblanche @Pieps
                    @Pieps Sounds Good, Thanks!!
                    • PiepsP
                      Pieps
                      So … I think that I’ve solved the Problem.
                      @carteblanche: could you try it please. To update the module use git pull in the MMM-Mail folder.
                      Please give me a feedback if the notifications come with the right name.
                      C 2 Replies Last reply
                        carteblanche @Pieps
                        @Pieps Thanks for making a quick fix! Once github is back online I will definitely do the pull and let you know the result.
                          carteblanche @Pieps
                          @Pieps perfect that fixed the issue. Now the notifications come in with the right name. Thanks again for the quick solution!
                            chrisvanlaar
                            I can see that it contact the mailserver. It found 3 new mails (that’s correct) but in the mirrorscreen it didn’t load this new mail. It says continue loading but nothing happend further.
                            What’s going wrong?
                            Chris
                              MagicMirrorPi
                              I have the same problem. In the terminal i can see the following:
                              “MMM-Mail-Helper: Mailbox Closed: INBOX
                              Mail-Seach complete
                              3 Mails fetched”
                              But the Mirror didn’t display emails. He say “No unread emails”. Anyone an idea? I connect with an outlook.com Account.
                              • PiepsP
                                Pieps
                                Hi Guys,
                                I saw the issue on my screen to.
                                I’m sorry, bot I have no time to debug the module on the moment.
                                So, please feel free to debug it by yourself and giv a pull request after you have solved the issue.
                                Otherwise, maybe i will have a look on the module in the middle of january.
                                Greetings Pieps
                                  marpin
                                  @pieps Hi, cant see my mails if i log with my outlook account
