    Issues with a special Google calendar
    19 Posts 3 Posters 6.3k Views 3 Watching
      Clubjack @sdetweil
      Arena You Sure?
      There are dates from 06.01. till 02.02.
      In my Android-App i can see the dates. But not in MM.
        sdetweil @Clubjack
        I should have searched for 2020… sorry, yes I see those…
        is this cal listed first?
        there is a total number of entries… so it will truncate
        and there is also how far forward is shown
          maxItems: 100,
          beforeDays: 60,
          afterDays: 365,
        which view are your using?
          Clubjack @sdetweil
          Okay.
          I tryed it using this calendar alone.
          Without other calendars. But nothing is shown.
          I use:
          Mode: week
          Slotcount: 5
          Maxitems: 1000
          Hideoverflow: false
          How i say… The Main Google calendars work fine with the same settings.
            sdetweil @Clubjack
            @Clubjack ok, i put this in the default calendar and it worked…
            so, that means the ext2 is having a problem…
            when did u clone ext2? there was a problem when the api returned the cal data in zipped format…
            he fixed that last week I think…
            so, if u have not updated recently do
            cd ~/MagicMirror/modules/MMM-CalendarExt2
            git pull
            and restart the mirror app
              Clubjack @sdetweil
              @sdetweil thank You
              Git pull says: Already up to date
                sdetweil @Clubjack
                @Clubjack bummer
                I would open an issue on the github site for the module
                  Clubjack @sdetweil
                  But what could be the problem,when all the other calendars worked?
                    sdetweil @Clubjack
                    @Clubjack well, it looks like the code doesn’t parse it correctly… I don’t know… not my code.
                    I am not in a position to debug it currently
                      Clubjack @sdetweil
                      @sdetweil ok. Thank You very much for your help. Great.
                        Clubjack @Clubjack
                        @Clubjack
                        I found the problem.
                        I copyed the Module, to Show it on an other Page (mmm-pages). But that didnt work.
                        With only one calendar it works great.
                        Now i have some other questions.
                        1. Is it possible to Change the timeformat from a date?
                          From “16:00 Test” to “16 Test”.
                        2. Is it possible to delete time from special entrys?
                          From “14:00 work” to “work”?
                        Edit: I was to fast. It only worked a few minutes.
                        Now, i can do what i want, it dosnt show this calendar.
                          sdetweil @Clubjack
                          @Clubjack ext2 cannot by replicated onto different pages @Sean (author) said. he bypasses all the
                          MM module presentation rules…
                            Clubjack @sdetweil
                            @sdetweil now it works. there Was a Problem with an empty calendar Slot. 🙈
                            Do You know, if my questions in the Post before, are makeable?
                              sdetweil @Clubjack
                              @Clubjack sure… u can select the three dots to the right on any post to mark it
                                Clubjack @sdetweil
                                @sdetweil not markable… Makeable😉
                                  sdetweil @Clubjack
                                  @Clubjack sorry, mind sees what it wants to see!
                                  https://github.com/eouia/MMM-CalendarExt2/blob/master/doc/Configuration/View.md
                                  dateFormat	Object	{...}	{...}	See Event Time.
                                  timeFormat	Object	{...}	{...}	See Event Time.
                                  dateTimeFormat	Object	{...}	{...}	See Event Time.
                                  relativeFormat	Object	{...}	{...}	See Event Time.
                                    Clubjack @sdetweil
                                    Oh, right, I saw that once. But forget it again. Thank You
                                    • BKeyportB Online
                                      BKeyport Module Developer
                                      by the way, if you wanna dump the empty slots:
                                      1. in config.js under views add
                                      className: "remove_empty_slot",
                                      1. add the following css to custom.css
                                      /* CalExt2 - Hide empty days on agenda */
                                      .CX2 .remove_empty_slot .eventCount_0 {
                                              display:none;
