    Issues with a special Google calendar
    19 Posts 3 Posters 6.4k Views 3 Watching
      sdetweil @Clubjack
      @Clubjack well, it looks like the code doesn’t parse it correctly… I don’t know… not my code.
      I am not in a position to debug it currently
      C 1 Reply Last reply
        Clubjack @sdetweil
        @sdetweil ok. Thank You very much for your help. Great.
          Clubjack @Clubjack
          @Clubjack
          I found the problem.
          I copyed the Module, to Show it on an other Page (mmm-pages). But that didnt work.
          With only one calendar it works great.
          Now i have some other questions.
          1. Is it possible to Change the timeformat from a date?
            From “16:00 Test” to “16 Test”.
          2. Is it possible to delete time from special entrys?
            From “14:00 work” to “work”?
          Edit: I was to fast. It only worked a few minutes.
          Now, i can do what i want, it dosnt show this calendar.
            sdetweil @Clubjack
            @Clubjack ext2 cannot by replicated onto different pages @Sean (author) said. he bypasses all the
            MM module presentation rules…
              Clubjack @sdetweil
              @sdetweil now it works. there Was a Problem with an empty calendar Slot. 🙈
              Do You know, if my questions in the Post before, are makeable?
                sdetweil @Clubjack
                @Clubjack sure… u can select the three dots to the right on any post to mark it
                  Clubjack @sdetweil
                  @sdetweil not markable… Makeable😉
                    sdetweil @Clubjack
                    @Clubjack sorry, mind sees what it wants to see!
                    https://github.com/eouia/MMM-CalendarExt2/blob/master/doc/Configuration/View.md
                    dateFormat	Object	{...}	{...}	See Event Time.
                    timeFormat	Object	{...}	{...}	See Event Time.
                    dateTimeFormat	Object	{...}	{...}	See Event Time.
                    relativeFormat	Object	{...}	{...}	See Event Time.
                      Clubjack @sdetweil
                      Oh, right, I saw that once. But forget it again. Thank You
                      • BKeyportB
                        BKeyport Module Developer
                        by the way, if you wanna dump the empty slots:
                        1. in config.js under views add
                        className: "remove_empty_slot",
                        1. add the following css to custom.css
                        /* CalExt2 - Hide empty days on agenda */
                        .CX2 .remove_empty_slot .eventCount_0 {
                                display:none;
