    Issues with a special Google calendar
    19 Posts 3 Posters 6.3k Views 3 Watching
      sdetweil @Clubjack
      @Clubjack bummer
      I would open an issue on the github site for the module
        Clubjack @sdetweil
        But what could be the problem,when all the other calendars worked?
          sdetweil @Clubjack
          @Clubjack well, it looks like the code doesn’t parse it correctly… I don’t know… not my code.
          I am not in a position to debug it currently
            Clubjack @sdetweil
            @sdetweil ok. Thank You very much for your help. Great.
              Clubjack @Clubjack
              @Clubjack
              I found the problem.
              I copyed the Module, to Show it on an other Page (mmm-pages). But that didnt work.
              With only one calendar it works great.
              Now i have some other questions.
              1. Is it possible to Change the timeformat from a date?
                From “16:00 Test” to “16 Test”.
              2. Is it possible to delete time from special entrys?
                From “14:00 work” to “work”?
              Edit: I was to fast. It only worked a few minutes.
              Now, i can do what i want, it dosnt show this calendar.
                sdetweil @Clubjack
                @Clubjack ext2 cannot by replicated onto different pages @Sean (author) said. he bypasses all the
                MM module presentation rules…
                  Clubjack @sdetweil
                  @sdetweil now it works. there Was a Problem with an empty calendar Slot. 🙈
                  Do You know, if my questions in the Post before, are makeable?
                    sdetweil @Clubjack
                    @Clubjack sure… u can select the three dots to the right on any post to mark it
                      Clubjack @sdetweil
                      @sdetweil not markable… Makeable😉
                        sdetweil @Clubjack
                        @Clubjack sorry, mind sees what it wants to see!
                        https://github.com/eouia/MMM-CalendarExt2/blob/master/doc/Configuration/View.md
                        dateFormat	Object	{...}	{...}	See Event Time.
                        timeFormat	Object	{...}	{...}	See Event Time.
                        dateTimeFormat	Object	{...}	{...}	See Event Time.
                        relativeFormat	Object	{...}	{...}	See Event Time.
                          Clubjack @sdetweil
                          Oh, right, I saw that once. But forget it again. Thank You
                          • BKeyportB Online
                            BKeyport Module Developer
                            by the way, if you wanna dump the empty slots:
                            1. in config.js under views add
                            className: "remove_empty_slot",
                            1. add the following css to custom.css
                            /* CalExt2 - Hide empty days on agenda */
                            .CX2 .remove_empty_slot .eventCount_0 {
                                    display:none;
