    How to start smart mirror
    7 Posts 4 Posters 2.5k Views 5 Watching
    • A
      Atahan
      Hi there
      I am new raspberry and I install magicmiror.
      When I run the software with the code I shared below, nothing appears on the screen.
      DISPLAY=:0 npm start
      When I look at module file from file manager, I see that modules like clock, calendar are installed. I’d appreciate it if you could help me.
      PS: I use raspberry pi4 2Gb and television
      • qu1queQ
        qu1que Project Sponsor
        Take a look at your config.js file. At first installation, you have a file called config.js.sample. You must rename that file to config.js and try again.
        The path to those files is: /home/pi/MagicMirror/config/
        • A
          Atahan @qu1que
          @qu1que said in How to start smart mirror:
          Thank you for your comment. I try this but it doens’t fix. Can I ask one more question
          Does config file contain both config.js and config.js.sample files?
          qu1queQ Mykle1M 2 Replies Last reply Reply Quote 0
          • qu1queQ
            qu1que Project Sponsor @Atahan
            @Atahan
            On a clean installation of MM, only config.js.sample exists, I think. You have to rename it to config.js and configure it as you wish. If config.js doesn’t exists, you can not watch anything on the screen of your mirror.
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @Atahan
              @Atahan
              I would make a copy of the config,js,sample and rename the copy to config.js, leaving the sample file as a safety net in case something goes wrong when you start editing.
              https://forum.magicmirror.builders/topic/4528/how-to-create-a-working-config-for-absolute-beginners
              qu1queQ 1 Reply Last reply Reply Quote 0
                The installer should have done all this for you
                • qu1queQ
                  qu1que Project Sponsor @Mykle1
                  @Mykle1
                  Yes, always is a good idea to make a backup of a file before modified it :winking_face:
