    Magic Mirror will not boot but Pi will, Cache issue?
    25 Posts 2 Posters 8.8k Views 2 Watching
      sdetweil @tkaauf32
      @tkaauf32 change head -n 10 to -n 20
      • T Offline
        tkaauf32
        I hope you can decipher this haha
        0_1577726759666_d55e67d9-9db4-4a13-9820-e92f4186c64d-image.png Screen Shot 2019-12-30 at 11.04.44 AM
          sdetweil @tkaauf32
          @tkaauf32 need with head -n 20, to give more lines of output
          /opt/Wolfram is taking a bit of space
          • T Offline
            tkaauf32 @sdetweil
            @sdetweil I pasted the wrong image. Thanks for your patience with me
            0_1577727269763_ff6f75b7-7d77-4203-b3c3-6b434617c8a2-image.png Screen Shot 2019-12-30 at 11.25.35 AM
              sdetweil @tkaauf32
              @tkaauf32 its not the logs… not even showing in the top 20.
              that /opt/Wolfram is taking 16.7 % or disk space (1146764/6846289)
              /usr/lib & share is taking 53%
              I would guess that your memory card is too small…
              what size is it?
              what did u add last?
              • T Offline
                tkaauf32 @sdetweil
                @sdetweil I guess I need to delete the wolfram. I’m using an 8GB but I have’t manually changed anything so I’m surprised that it doesn’t work anymore. Maybe the logs put it over the edge.
                  sdetweil @tkaauf32
                  @tkaauf32 logs are pretty small… do the du /var/logs | sort | head thing, just on the logs folder…
                  • T Offline
                    tkaauf32 @sdetweil
                    @sdetweil Permission denied. Also tried it with /logs and /log. /log says “is a directory” and the latter says permission denied
                      sdetweil @tkaauf32
                      @tkaauf32 sorry, typo
                       du  /var/log 2>/dev/null
                      may need sudo
                      sudo du  /var/log 2>/dev/null
                      • T Offline
                        tkaauf32 @sdetweil
                          sdetweil @tkaauf32
                          @tkaauf32 so, all the space is used IN the /var/log folder itself, not subfolders…
                          but 13040 is a tiny 0.1% WAY below the critical threshold… (if u are over 80% used, you are in trouble)
                          • T Offline
                            tkaauf32 @sdetweil
                            @sdetweil said in Magic Mirror will not boot but Pi will, Cache issue?:
                            o
                            I don’t know what that means haha
                              sdetweil @tkaauf32
                              @tkaauf32 said in Magic Mirror will not boot but Pi will, Cache issue?:
                              the du command dumps out blocks used, and does it by folder.
                              in the last screenshot, there are 13040 blocks used for the entire /var/log subtree
                              there are 6846289 blocks of space on the memory card disk volume… so, divide
                              (13040*100) by 6846289 to get the percentage used = 0.19046815%
                              in system design, if u ever got over 80% used of the total capacity (memory, cpu, disk space), the system is in danger of failure ‘soon’… (I am a long time (45 yrs) computer system solution designer)
                              • T Offline
                                tkaauf32 @sdetweil
                                @sdetweil I’m just curious how you think it went over 80% total capacity? Will this continue to happen over time? Or should i just buy a 16gig SD and it will likely solve the issue?
                                  sdetweil @tkaauf32
                                  @tkaauf32 the bigger disk will help…
                                  the Wolfram stuff is eating a lot of space.,
                                  but I don’t see anything else really large taking a lot of space… MagicMirror is only taking about 10%
                                  home folder is under 15%
