    Magic Mirror will not boot but Pi will, Cache issue?
    25 Posts 2 Posters 8.8k Views 2 Watching
      sdetweil @tkaauf32
      @tkaauf32 need with head -n 20, to give more lines of output
      /opt/Wolfram is taking a bit of space
      • T Offline
        tkaauf32 @sdetweil
        @sdetweil I pasted the wrong image. Thanks for your patience with me
        0_1577727269763_ff6f75b7-7d77-4203-b3c3-6b434617c8a2-image.png Screen Shot 2019-12-30 at 11.25.35 AM
          sdetweil @tkaauf32
          @tkaauf32 its not the logs… not even showing in the top 20.
          that /opt/Wolfram is taking 16.7 % or disk space (1146764/6846289)
          /usr/lib & share is taking 53%
          I would guess that your memory card is too small…
          what size is it?
          what did u add last?
          • T Offline
            tkaauf32 @sdetweil
            @sdetweil I guess I need to delete the wolfram. I’m using an 8GB but I have’t manually changed anything so I’m surprised that it doesn’t work anymore. Maybe the logs put it over the edge.
              sdetweil @tkaauf32
              @tkaauf32 logs are pretty small… do the du /var/logs | sort | head thing, just on the logs folder…
              • T Offline
                tkaauf32 @sdetweil
                @sdetweil Permission denied. Also tried it with /logs and /log. /log says “is a directory” and the latter says permission denied
                  sdetweil @tkaauf32
                  @tkaauf32 sorry, typo
                   du  /var/log 2>/dev/null
                  may need sudo
                  sudo du  /var/log 2>/dev/null
                  • T Offline
                    tkaauf32 @sdetweil
                      sdetweil @tkaauf32
                      @tkaauf32 so, all the space is used IN the /var/log folder itself, not subfolders…
                      but 13040 is a tiny 0.1% WAY below the critical threshold… (if u are over 80% used, you are in trouble)
                      • T Offline
                        tkaauf32 @sdetweil
                        @sdetweil said in Magic Mirror will not boot but Pi will, Cache issue?:
                        o
                        I don’t know what that means haha
                          sdetweil @tkaauf32
                          @tkaauf32 said in Magic Mirror will not boot but Pi will, Cache issue?:
                          the du command dumps out blocks used, and does it by folder.
                          in the last screenshot, there are 13040 blocks used for the entire /var/log subtree
                          there are 6846289 blocks of space on the memory card disk volume… so, divide
                          (13040*100) by 6846289 to get the percentage used = 0.19046815%
                          in system design, if u ever got over 80% used of the total capacity (memory, cpu, disk space), the system is in danger of failure ‘soon’… (I am a long time (45 yrs) computer system solution designer)
                          • T Offline
                            tkaauf32 @sdetweil
                            @sdetweil I’m just curious how you think it went over 80% total capacity? Will this continue to happen over time? Or should i just buy a 16gig SD and it will likely solve the issue?
                              sdetweil @tkaauf32
                              @tkaauf32 the bigger disk will help…
                              the Wolfram stuff is eating a lot of space.,
                              but I don’t see anything else really large taking a lot of space… MagicMirror is only taking about 10%
                              home folder is under 15%
