    Magic Mirror will not boot but Pi will, Cache issue?
    25 Posts 2 Posters 9.5k Views 2 Watching
    • T
      tkaauf32 @sdetweil
      @sdetweil I guess I need to delete the wolfram. I’m using an 8GB but I have’t manually changed anything so I’m surprised that it doesn’t work anymore. Maybe the logs put it over the edge.
        sdetweil @tkaauf32
        @tkaauf32 logs are pretty small… do the du /var/logs | sort | head thing, just on the logs folder…
        T 1 Reply Last reply
        • T
          tkaauf32 @sdetweil
          @sdetweil Permission denied. Also tried it with /logs and /log. /log says “is a directory” and the latter says permission denied
            sdetweil @tkaauf32
            @tkaauf32 sorry, typo
             du  /var/log 2>/dev/null
            may need sudo
            sudo du  /var/log 2>/dev/null
            • T
              tkaauf32 @sdetweil
                sdetweil @tkaauf32
                @tkaauf32 so, all the space is used IN the /var/log folder itself, not subfolders…
                but 13040 is a tiny 0.1% WAY below the critical threshold… (if u are over 80% used, you are in trouble)
                • T
                  tkaauf32 @sdetweil
                  @sdetweil said in Magic Mirror will not boot but Pi will, Cache issue?:
                  o
                  I don’t know what that means haha
                    sdetweil @tkaauf32
                    @tkaauf32 said in Magic Mirror will not boot but Pi will, Cache issue?:
                    the du command dumps out blocks used, and does it by folder.
                    in the last screenshot, there are 13040 blocks used for the entire /var/log subtree
                    there are 6846289 blocks of space on the memory card disk volume… so, divide
                    (13040*100) by 6846289 to get the percentage used = 0.19046815%
                    in system design, if u ever got over 80% used of the total capacity (memory, cpu, disk space), the system is in danger of failure ‘soon’… (I am a long time (45 yrs) computer system solution designer)
                    • T
                      tkaauf32 @sdetweil
                      @sdetweil I’m just curious how you think it went over 80% total capacity? Will this continue to happen over time? Or should i just buy a 16gig SD and it will likely solve the issue?
                        sdetweil @tkaauf32
                        @tkaauf32 the bigger disk will help…
                        the Wolfram stuff is eating a lot of space.,
                        but I don’t see anything else really large taking a lot of space… MagicMirror is only taking about 10%
                        home folder is under 15%
