Unsolved Magic Mirror will not boot but Pi will, Cache issue?
@tkaauf32 change head -n 10 to -n 20
I hope you can decipher this haha
Screen Shot 2019-12-30 at 11.04.44 AM
@tkaauf32 need with head -n 20, to give more lines of output
/opt/Wolfram is taking a bit of space
@sdetweil I pasted the wrong image. Thanks for your patience with me
Screen Shot 2019-12-30 at 11.25.35 AM
@tkaauf32 its not the logs… not even showing in the top 20.
that /opt/Wolfram is taking 16.7 % or disk space (1146764/6846289)
/usr/lib & share is taking 53%
I would guess that your memory card is too small…what size is it?
what did u add last? -
@sdetweil I guess I need to delete the wolfram. I’m using an 8GB but I have’t manually changed anything so I’m surprised that it doesn’t work anymore. Maybe the logs put it over the edge.
@tkaauf32 logs are pretty small… do the du /var/logs | sort | head thing, just on the logs folder…
@sdetweil Permission denied. Also tried it with /logs and /log. /log says “is a directory” and the latter says permission denied
