    Mirror not displaying after rotation
    6 Posts 3 Posters 1.4k Views 3 Watching
      JRB1988
      When I switch my screen to vertical by using rotate_display=1, the magic mirror stops displaying on the screen. The pi desktop is rotated and I can see the magic mirror displaying on my VNC but its not on the screen. Any thoughts what might be causing this?
      S lavolp3L 2 Replies Last reply Reply Quote 0
        sdetweil @JRB1988
        @JRB1988 did the display number change from :0?
          JRB1988 @sdetweil
          @sdetweil Sorry I’m not sure what you mean. Where would I check the display number? Is that a setting for the magic mirror or for the raspberry pi in general
          If its just a matter of seeing if the orientation changed then the screen did have the orientation I wanted but when I booted magic mirror it was all black (on the monitor) but appeared on my VNC.
          • lavolp3L Offline
            lavolp3 Module Developer @JRB1988
            @JRB1988 the command is display_rotate=1
            Not sure if that’s the issue though.
            If you have a Pi 4 have a look at this:
            https://www.raspberrypi.org/forums/viewtopic.php?f=28&t=247619&p=1516639#p1516639
            How to troubleshoot modules
            MMM-soccer v2, MMM-AVStock
              sdetweil @JRB1988
              @JRB1988 the startup script does DISPLAY=:0 & npm start
              here is a topics with different methods to find the display number…
                JRB1988 @lavolp3
                @lavolp3 Thanks that link did the trick. Thanks!
