Mirror not displaying after rotation
When I switch my screen to vertical by using rotate_display=1, the magic mirror stops displaying on the screen. The pi desktop is rotated and I can see the magic mirror displaying on my VNC but its not on the screen. Any thoughts what might be causing this?
@JRB1988 did the display number change from :0?
@sdetweil Sorry I’m not sure what you mean. Where would I check the display number? Is that a setting for the magic mirror or for the raspberry pi in general
If its just a matter of seeing if the orientation changed then the screen did have the orientation I wanted but when I booted magic mirror it was all black (on the monitor) but appeared on my VNC.
@JRB1988 the command is
display_rotate=1
Not sure if that’s the issue though.If you have a Pi 4 have a look at this:
https://www.raspberrypi.org/forums/viewtopic.php?f=28&t=247619&p=1516639#p1516639 -
@JRB1988 the startup script does DISPLAY=:0 & npm start
here is a topics with different methods to find the display number…
@lavolp3 Thanks that link did the trick. Thanks!
