First Steps
8 Posts 2 Posters 4.4k Views 2 Watching
  • G Offline
    geeflaxx
    Hey
    i wanted creat my mirror automatically installation (curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash)
    i did it via ssh and i got that fault (http://www.bilder-upload.eu/show.php?file=7554b1-1477179229.jpg)
    i have node v6.8.1
    npm 3.10.8
    maybe it doesn’t pi compatibilty?
    maybe a better picture: http://www.bilder-upload.eu/show.php?file=d5ee11-1477181137.png
    what can i do ?
    for any answer thanksfull.
    S 1 Reply Last reply Oct 23, 2016, 7:28 AM Reply Quote 0
      strawberry 3.141 Project Sponsor Module Developer @geeflaxx
      @geeflaxx it canf find the library on your system
      try sudo apt-get install libgtk2.0-0
      • G Offline
        geeflaxx
        i tried it
        but now i have the fault that libXss.so.1 is missing
        i google it but i didn’t find a good answer…
        which library should i download now ?
        i have many screen’s and i hope you can help me :/
        (i used the multiupload picload.org)
        https://pl.vc/nlwkl
        https://pl.vc/6jqck
        https://pl.vc/1lpl8h
        https://pl.vc/sesey
        thats my npm-debug.log
        • 0 info it worked if it ends with ok
          1 verbose cli [ ‘/usr/local/bin/node’, ‘/usr/local/bin/npm’, ‘start’ ]
          2 info using npm@3.10.9
          3 info using node@v6.8.1
          4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
          5 info lifecycle magicmirror@2.0.0~prestart: magicmirror@2.0.0
          6 silly lifecycle magicmirror@2.0.0~prestart: no script for prestart, continuing
          7 info lifecycle magicmirror@2.0.0~start: magicmirror@2.0.0
          8 verbose lifecycle magicmirror@2.0.0~start: unsafe-perm in lifecycle true
          9 verbose lifecycle magicmirror@2.0.0~start: PATH: /usr/local/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.b$
          10 verbose lifecycle magicmirror@2.0.0~start: CWD: /home/pi/MagicMirror
          11 silly lifecycle magicmirror@2.0.0~start: Args: [ ‘-c’, ‘electron js/electron.js’ ]
          12 info lifecycle magicmirror@2.0.0~start: Failed to exec start script
          13 verbose stack Error: magicmirror@2.0.0 start: electron js/electron.js
          13 verbose stack spawn ENOENT
          13 verbose stack at ChildProcess. (/usr/local/lib/node_modules/npm/lib/utils/spawn.js:33:16)
          13 verbose stack at emitTwo (events.js:106:13)
          13 verbose stack at ChildProcess.emit (events.js:191:7)
          13 verbose stack at maybeClose (internal/child_process.js:877:16)
          13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
          14 verbose pkgid magicmirror@2.0.0
          15 verbose cwd /home/pi/MagicMirror
          16 error Linux 4.4.21-v7+
          17 error argv “/usr/local/bin/node” “/usr/local/bin/npm” “start”
          18 error node v6.8.1
          19 error npm v3.10.9
          20 error file sh
          21 error code ELIFECYCLE
          22 error errno ENOENT
          23 error syscall spawn
          24 error magicmirror@2.0.0 start: electron js/electron.js
          24 error spawn ENOENT
          25 error Failed at the magicmirror@2.0.0 start script ‘electron js/electron.js’.
          25 error Make sure you have the latest version of node.js and npm installed.
          25 error If you do, this is most likely a problem with the magicmirror package,
          25 error not with npm itself.
          25 error Tell the author that this fails on your system:
          25 error electron js/electron.js
          25 error You can get information on how to open an issue for this project with:
          25 error npm bugs magicmirror
          25 error Or if that isn’t available, you can get their info via:
          25 error npm owner ls magicmirror
          25 error There is likely additional logging output above.
          26 verbose exit [ 1, true ]
        • G Offline
          geeflaxx
          i haven’t the error after i use
          '‘sudo apt-get install libxss1 lsof’
          but now i have a new one, the same error but with the code that “libgconf-2.so.4” is missing
          why isn’t so many pakets install?
          S 1 Reply Last reply Oct 23, 2016, 7:36 PM Reply Quote 0
            @geeflaxx is your raspbian version up to date?
            • G Offline
              geeflaxx
              i remove the order MagicMirror and install it automatically
              npm WARN grunt-yamllint@0.2.0 requires a peer of grunt@~0.4.0 but none was installed.
              Dependencies installation Done!
              We’re ready! Run DISPLAY=:0 npm start from the ~/MagicMirror directory to start your MagicMirror.
              i look the error in my installation is red ’ UNMET PEER DEPENDENCY grunt@1.0.1’
              and now i use ‘npm start’
              the same error
              libgconf-2.so.4 is still missing
              if i use sudo apt-get install libconf-2-4
              E: Unable to locate package libconf-2-4
              i think it’s the false access i don’t have the rights cause (permission deniedmaybe)?
              or i think too that i haven’t the electron-prebuilt pakets ?
              • G Offline
                geeflaxx
                @strawberry-3-141 please help me
                okay i think my script electron js/electron.js is destroy
                i installed with sudo apt-get install libconf2-4 and it’s work
                but if i started npm the same error but with ‘libnss3.so’
                http://www.bilder-upload.eu/show.php?file=99f2e4-1477258272.png
                i am so desperately, i think i use the problem but the same come with another code…
                http://www.bilder-upload.eu/show.php?file=967e7b-1477258720.png
                why is that red?
                S 1 Reply Last reply Oct 24, 2016, 7:31 AM Reply Quote 0
                  @geeflaxx there must be something wrong with your whole setup. i would personally go and do it again with this instructions https://forum.magicmirror.builders/topic/236/complete-setup-tutorial
