    A problem about MMM-BMW-DS
    25 Posts 4 Posters 12.1k Views 4 Watching
    • zokiyaZ Offline
      zokiya
      I’m new to magic mirror.I found a cute module MMM-BMW-DS, I really love it and want to use it.But I encountered a problem that I am trying to use the darksky weather module but it never loads and just displays “Acquiring your weather…”
      I have got a new API keys and try again, but it doesn’t seem to work.
      What should I do next?Please help me:folded_hands:
      Here is the relevant section of the config.js
      disabled: false,
      module: “MMM-BMW-DS”,
      position: “bottom_bar”, // bottom_bar is best
      apiKey: “My API key”, // Free API key @ darksky.net
      tempUnits: “F”, // MUST BE CAPITAL LETTER C or F
      lat: ‘31.318889’,
      lng: ‘121.395’,
      css: “1”, // 1=default, 2=Clean, 3=Lord of the Rings, 4=handwriting, 5=Julee, 6=Englebert, “” = returns default css
      ownTitle: “Current Conditions”, // Use your own language and statement
      playSounds: “yes”, // yes = weather sounds, no = no weather sounds
      useHeader: false,
      header: “Your header”,
      maxWidth: “100%”,
        Mykle1 Project Sponsor Module Developer @zokiya
        @zokiya
              disabled: false,
              module: "MMM-BMW-DS",
              position: "bottom_bar", // bottom_bar is best
                apiKey: "YOUR API KEY GOES HERE", // Free API key @ darksky.net
                tempUnits: "F", // MUST BE CAPITAL LETTER C or F
                lat: '31.318889',
                lng: '121.395',
                css: "1", // 1=default, 2=Clean, 3=Lord of the Rings, 4=handwriting, 5=Julee, 6=Englebert, "" = returns default css
                ownTitle: "Current Conditions", // Use your own language and statement
                playSounds: "yes", // yes = weather sounds, no = no weather sounds
                useHeader: false,
                header: "Your header",
                maxWidth: "100%",
        Your curly quotes are not acceptable, causing syntax errors. Notice the difference. I’ve fixed them and tested the entry. Copy and paste it and add your API key.
        Consider using a code editor that will eliminate those problems.
        zokiyaZ 1 Reply Last reply Reply Quote 0
        • zokiyaZ Offline
          zokiya @Mykle1
          @Mykle1
          Thank you for your correction:winking_face: But I just try again and it still doesn’t seem to work.:dizzy_face: Is there anything else I can check besides ‘config.js’?
            sdetweil @zokiya
            @zokiya number to the right of : should not have quotes… turns them into strings
                    lat: '31.318889',
                    lng: '121.395',
            zokiyaZ Mykle1M 2 Replies Last reply Reply Quote 0
            • zokiyaZ Offline
              zokiya @sdetweil
              Thank you.I took your suggestion to modify the code, but it doesn’t seem to work.:face_with_cold_sweat:
              S Mykle1M 2 Replies Last reply Reply Quote 0
                sdetweil @zokiya
                @zokiya open the developers window, ctrl-shift-i on the keyboard, select the tab labeled console, and scroll up to see any errors, usually red text.
                  @sdetweil said in A problem about MMM-BMW-DS:
                  In this case, they ARE stings. The OP’s config example is rife with syntax errors. So, I corrected it, tested it, confirmed its validity and posted it, minus the API key. :thumbsup:
                    sdetweil @Mykle1
                    @Mykle1 hmmmmm, need to learn, never correct a module author!
                      @zokiya
                      Please follow sdetweil’s suggestion to look for errors. Again, if you copy and paste the following config entry directly into your config it should avoid the syntax errors. Enter your API key EXACTLY. This is very important.
                            disabled: false,
                              lat: '31.318889',
                              lng: '121.395',
                              useHeader: false,
                              maxWidth: "100%",
                        Feel free to correct me any time you like. :-)
                        I’ve learned much by being corrected. :thumbsup:
                        • T Offline
                          TheGeekfather @Mykle1
                          @Mykle1
                          Your modules are excellent :)
                          • Off topic but does Hello-Lucy still work? I’ve installed it but always starts off with blank screen - even when I put hide all - false. Mic works but no response. I start with saying hello lucy and then Show - your key words like HOROSCOPE. Any help would be GREATLY Appreciated!
                            Mykle1 Project Sponsor Module Developer @TheGeekfather
                            @TheGeekfather said in A problem about MMM-BMW-DS:
                            Thank you for your kind words. :thumbsup:
                            Yes, in fact I’ve just finished a substantial upgrade. You’ve installed recently?
                            Please paste your config entry in a code block ( </> in menu) so I can take a look at it.
                            • T Offline
                              @Mykle1
                              		disabled: false,
                              		module: "Hello-Lucy",
                              		position: "bottom_left",
                                			keyword: "HELLO LUCY",               // MUST BE CAPITALS to make Lucy start listening
                                			timeout: 15,                        // timeout listening for a command/sentence
                                			defaultOnStartup: "Hello-Lucy",
                                			standByMethod: 'DPMS',              // 'DPMS' = anything else than RPi or 'PI'
                                			sounds: ["1.mp3", "11.mp3"],        // welcome sound at startup. Add several for a random choice of welcome sound
                                			confirmationSound: "ding.mp3",      // when command is accepted. use your own or default, name and extension of sound file
                                			                // startHideAll: false,   if true, all modules start as hidden
                                			pageOneModules: ["Hello-Lucy", "MMM-Astro"],    // default modules to show on page one/startup
                                			pageTwoModules: ["MMM-BMW-DS", "MMM-Events"],     // modules to show on page two
                                			pageThreeModules: ["email"],               // modules to show on page three
                                			pageFourModules: ["MMM-iFrame"],                // modules to show on page four
                                			pageFiveModules: [],                              // modules to show on page five
                                			pageSixModules: [],                               // modules to show on page six
                                			pageSevenModules: [],                             // modules to show on page seven
                                			pageEightModules: [],                             // modules to show on page eight
                                			pageNineModules: [],                              // modules to show on page nine
                                			pageTenModules: [],                               // modules to show on page ten
                                @TheGeekfather
                                Ok, the config is fine. I just tested it.
                                1. When you say Hello Lucy, the microphone icon does not start pulsing?
                                2. Have you installed and enabled the modules that are named in the config?
                                • T Offline
                                  @Mykle1
                                  Hi, Yes, modules are set to disabled: false
                                  Also, I don’t see any microphone icon and even with starthideall at false - still blank on boot up screen?
                                  i can hear my microphone through my speaker when I talk so mic seems to be working
                                  unless, I’m not suppose to hear my voice on speaker?
                                    @TheGeekfather
                                    First, you need to comment out after the comma if you are using this line. The entire line is commented out in your example. If you uncomment that line then the module will error.
                                    Then the module is not loading. You should see the microphone icon along with, Say, ‘Hello Lucy’ on screen.
                                    That seems odd. Mine does not do that. I don’t know if that’s a problem
                                    Start your mirror using npm start dev and then click the console tab in the window that opens. Scroll to find any errors in red and report
                                    • T Offline
                                      @Mykle1
                                      I Just heard “Hello Michael What would you like to see”
                                      It seems I was missing lmtool which I just installed
                                      • T Offline
                                        TheGeekfather @TheGeekfather
                                        @TheGeekfather
                                        OK, getting closer :)
                                        says under mic icon
                                        Initializing then undefined so it seems I just have to get mic to work
                                          @TheGeekfather
                                          Did you not follow the readme on how to install the dependencies?
                                          T 2 Replies Last reply Reply Quote 0
                                          • T Offline
                                            @Mykle1
                                            OK, that might be the problem because for some reason all the modules were installed in
                                            modules/default
                                            so when I bash dependencies, it says it couldn’t find the /modules/Hello-Lucy folder
                                            I moved the Hello-Lucy folder to modules - ran bash dependencies.sh again but no go :(
                                            Thank you for any help !!! I’m a retired computer science teacher that wont’s to keep on learning :)
