    A problem about MMM-BMW-DS
    25 Posts 4 Posters 11.3k Views 4 Watching
    • zokiyaZ Offline
      zokiya @Mykle1
      @Mykle1
      Thank you for your correction:winking_face: But I just try again and it still doesn’t seem to work.:dizzy_face: Is there anything else I can check besides ‘config.js’?
        sdetweil @zokiya
        @zokiya number to the right of : should not have quotes… turns them into strings
                lat: '31.318889',
                lng: '121.395',
                css: "1", // 1=default, 2=Clean, 3=Lord of the Rings, 4=handwriting, 5=Julee, 6=Englebert, "" = returns default css
                ownTitle: "Current Conditions", // Use your own language and statement
        zokiyaZ Mykle1M 2 Replies Last reply Reply Quote 0
        • zokiyaZ Offline
          zokiya @sdetweil
          Thank you.I took your suggestion to modify the code, but it doesn’t seem to work.:face_with_cold_sweat:
          S Mykle1M 2 Replies Last reply Reply Quote 0
            sdetweil @zokiya
            @zokiya open the developers window, ctrl-shift-i on the keyboard, select the tab labeled console, and scroll up to see any errors, usually red text.
              @sdetweil said in A problem about MMM-BMW-DS:
              In this case, they ARE stings. The OP’s config example is rife with syntax errors. So, I corrected it, tested it, confirmed its validity and posted it, minus the API key. :thumbsup:
                sdetweil @Mykle1
                @Mykle1 hmmmmm, need to learn, never correct a module author!
                  Mykle1 Project Sponsor Module Developer @zokiya
                  @zokiya
                  Please follow sdetweil’s suggestion to look for errors. Again, if you copy and paste the following config entry directly into your config it should avoid the syntax errors. Enter your API key EXACTLY. This is very important.
                        disabled: false,
                        module: "MMM-BMW-DS",
                        position: "bottom_bar", // bottom_bar is best
                          apiKey: "YOUR API KEY GOES HERE", // Free API key @ darksky.net
                          tempUnits: "F", // MUST BE CAPITAL LETTER C or F
                          lat: '31.318889',
                          lng: '121.395',
                          playSounds: "yes", // yes = weather sounds, no = no weather sounds
                          useHeader: false,
                          header: "Your header",
                          maxWidth: "100%",
                  zokiyaZ 1 Reply Last reply Reply Quote 0
                    Feel free to correct me any time you like. :-)
                    I’ve learned much by being corrected. :thumbsup:
                    • T Offline
                      TheGeekfather @Mykle1
                      @Mykle1
                      Your modules are excellent :)
                      • Off topic but does Hello-Lucy still work? I’ve installed it but always starts off with blank screen - even when I put hide all - false. Mic works but no response. I start with saying hello lucy and then Show - your key words like HOROSCOPE. Any help would be GREATLY Appreciated!
                        Mykle1 Project Sponsor Module Developer @TheGeekfather
                        @TheGeekfather said in A problem about MMM-BMW-DS:
                        Thank you for your kind words. :thumbsup:
                        Yes, in fact I’ve just finished a substantial upgrade. You’ve installed recently?
                        Please paste your config entry in a code block ( </> in menu) so I can take a look at it.
