    A problem about MMM-BMW-DS
    25 Posts 4 Posters 13.1k Views 4 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @zokiya
      @zokiya
            disabled: false,
            module: "MMM-BMW-DS",
            position: "bottom_bar", // bottom_bar is best
              apiKey: "YOUR API KEY GOES HERE", // Free API key @ darksky.net
              tempUnits: "F", // MUST BE CAPITAL LETTER C or F
              lat: '31.318889',
              lng: '121.395',
              css: "1", // 1=default, 2=Clean, 3=Lord of the Rings, 4=handwriting, 5=Julee, 6=Englebert, "" = returns default css
              ownTitle: "Current Conditions", // Use your own language and statement
              playSounds: "yes", // yes = weather sounds, no = no weather sounds
              useHeader: false,
              header: "Your header",
              maxWidth: "100%",
      Your curly quotes are not acceptable, causing syntax errors. Notice the difference. I’ve fixed them and tested the entry. Copy and paste it and add your API key.
      Consider using a code editor that will eliminate those problems.
      zokiyaZ 1 Reply Last reply Reply Quote 0
      • zokiyaZ
        zokiya @Mykle1
        @Mykle1
        Thank you for your correction:winking_face: But I just try again and it still doesn’t seem to work.:dizzy_face: Is there anything else I can check besides ‘config.js’?
          sdetweil @zokiya
          @zokiya number to the right of : should not have quotes… turns them into strings
                  lat: '31.318889',
                  lng: '121.395',
          zokiyaZ Mykle1M 2 Replies Last reply Reply Quote 0
          • zokiyaZ
            zokiya @sdetweil
            Thank you.I took your suggestion to modify the code, but it doesn’t seem to work.:face_with_cold_sweat:
            S Mykle1M 2 Replies Last reply Reply Quote 0
              sdetweil @zokiya
              @zokiya open the developers window, ctrl-shift-i on the keyboard, select the tab labeled console, and scroll up to see any errors, usually red text.
              • Mykle1M
                @sdetweil said in A problem about MMM-BMW-DS:
                In this case, they ARE stings. The OP’s config example is rife with syntax errors. So, I corrected it, tested it, confirmed its validity and posted it, minus the API key. :thumbsup:
                  sdetweil @Mykle1
                  @Mykle1 hmmmmm, need to learn, never correct a module author!
                  • Mykle1M
                    @zokiya
                    Please follow sdetweil’s suggestion to look for errors. Again, if you copy and paste the following config entry directly into your config it should avoid the syntax errors. Enter your API key EXACTLY. This is very important.
                          disabled: false,
                            lat: '31.318889',
                            lng: '121.395',
                            useHeader: false,
                            maxWidth: "100%",
                    • Mykle1M
                      Feel free to correct me any time you like. :-)
                      I’ve learned much by being corrected. :thumbsup:
                      • T
                        TheGeekfather @Mykle1
                        @Mykle1
                        Your modules are excellent :)
                        • Off topic but does Hello-Lucy still work? I’ve installed it but always starts off with blank screen - even when I put hide all - false. Mic works but no response. I start with saying hello lucy and then Show - your key words like HOROSCOPE. Any help would be GREATLY Appreciated!
                        • Mykle1M
                          Mykle1 Project Sponsor Module Developer @TheGeekfather
                          @TheGeekfather said in A problem about MMM-BMW-DS:
                          Thank you for your kind words. :thumbsup:
                          Yes, in fact I’ve just finished a substantial upgrade. You’ve installed recently?
                          Please paste your config entry in a code block ( </> in menu) so I can take a look at it.
                          • T
                            @Mykle1
                            		disabled: false,
                            		module: "Hello-Lucy",
                            		position: "bottom_left",
                              			keyword: "HELLO LUCY",               // MUST BE CAPITALS to make Lucy start listening
                              			timeout: 15,                        // timeout listening for a command/sentence
                              			defaultOnStartup: "Hello-Lucy",
                              			standByMethod: 'DPMS',              // 'DPMS' = anything else than RPi or 'PI'
                              			sounds: ["1.mp3", "11.mp3"],        // welcome sound at startup. Add several for a random choice of welcome sound
                              			confirmationSound: "ding.mp3",      // when command is accepted. use your own or default, name and extension of sound file
                              			                // startHideAll: false,   if true, all modules start as hidden
                              			pageOneModules: ["Hello-Lucy", "MMM-Astro"],    // default modules to show on page one/startup
                              			pageTwoModules: ["MMM-BMW-DS", "MMM-Events"],     // modules to show on page two
                              			pageThreeModules: ["email"],               // modules to show on page three
                              			pageFourModules: ["MMM-iFrame"],                // modules to show on page four
                              			pageFiveModules: [],                              // modules to show on page five
                              			pageSixModules: [],                               // modules to show on page six
                              			pageSevenModules: [],                             // modules to show on page seven
                              			pageEightModules: [],                             // modules to show on page eight
                              			pageNineModules: [],                              // modules to show on page nine
                              			pageTenModules: [],                               // modules to show on page ten
                            • Mykle1M
                              @TheGeekfather
                              Ok, the config is fine. I just tested it.
                              1. When you say Hello Lucy, the microphone icon does not start pulsing?
                              2. Have you installed and enabled the modules that are named in the config?
                              • T
                                @Mykle1
                                Hi, Yes, modules are set to disabled: false
                                Also, I don’t see any microphone icon and even with starthideall at false - still blank on boot up screen?
                                i can hear my microphone through my speaker when I talk so mic seems to be working
                                unless, I’m not suppose to hear my voice on speaker?
                                • Mykle1M
                                  @TheGeekfather
                                  First, you need to comment out after the comma if you are using this line. The entire line is commented out in your example. If you uncomment that line then the module will error.
                                  Then the module is not loading. You should see the microphone icon along with, Say, ‘Hello Lucy’ on screen.
                                  That seems odd. Mine does not do that. I don’t know if that’s a problem
                                  Start your mirror using npm start dev and then click the console tab in the window that opens. Scroll to find any errors in red and report
                                  • T
                                    @Mykle1
                                    I Just heard “Hello Michael What would you like to see”
                                    It seems I was missing lmtool which I just installed
                                    • T
                                      TheGeekfather @TheGeekfather
                                      @TheGeekfather
                                      OK, getting closer :)
                                      says under mic icon
                                      Initializing then undefined so it seems I just have to get mic to work
                                      • Mykle1M
                                        @TheGeekfather
                                        Did you not follow the readme on how to install the dependencies?
                                        T 2 Replies Last reply Reply Quote 0
                                        • T
                                          @Mykle1
                                          OK, that might be the problem because for some reason all the modules were installed in
                                          modules/default
                                          so when I bash dependencies, it says it couldn’t find the /modules/Hello-Lucy folder
                                          I moved the Hello-Lucy folder to modules - ran bash dependencies.sh again but no go :(
                                          Thank you for any help !!! I’m a retired computer science teacher that wont’s to keep on learning :)
                                          • zokiyaZ
                                            zokiya @Mykle1
                                            @Mykle1 I just copied and pasted the code you corrected, reset my API, and copied and pasted it, but it didn’t work. I checked the developer window and there are only two warnings, and they don’t seem to have anything to do with this module. I checked my Dark Sky console and it shows that my API has not been called. Now I suspect that there is a problem with my network.
