    Default Calendar adjustment
    5 Posts 3 Posters 2.8k Views 2 Watching
      surger13 Project Sponsor
      first of all thanks to all who are involved here, I am impressed. With the help of the forum I have build a MM and installed the software as noob. But I can read English better than write, so I apologize that I use the help of google to post here. ;)
      A question about the default calendar module. How can I display a relative date without the word “um” (in english “at”)? Someone has an idea?
      Dirk
        barnosch
        Hi Dirk,
        is it the standard calender module?
        where does you source come from? Where do you get this information from?
        I am also interested in a module like this and could look into it aswell.
        Ist das das Standard Kalender Modul? Wo ist deine Quelle?
        Wäre auch an dem Modul interessiert und könnte es mir dann genauer anschauen
          Hello barnosch,
          it is the default calendar module from MagicMirror.
          Dirk
            roramirez Core Contributors @surger13
            @surger13 That part is controller by moment.js. It’s not possible configurated. Only way to make this is change the source code of calendar.js in the module directory.
              Two years later… :)
              After updating to MM 2.10, I noticed again that the “um” or “at” still bothers me and makes the calendar entries unnecessarily wide.
              Does anybody have another idea or a tip, what exactly should be changed in the calendar.js to remove it?
