Solved MM2.10 & Pi3b - run-start.sh issue? (Exit status 7, errno 7, error code ELIFECYCLE)
@xray2607 said in MM2.10 & Pi3b - run-start.sh issue? (Exit status 7, errno 7, error code ELIFECYCLE):
However, several hours later trying to get the screensaver disabled
I’m gonna ask some questions… did u try the automated install or manual, as automated asks it u want screensaver off and then does it.
I updated the run-start.sh script in 2.10 to do some additional work…
can u change line 1 of runstart.sh to
#!/bin/bash
to
#!/bin/bash -x
and then do npm start from the MagicMirror folder, you might see
> ./run-start.sh + ./untrack-css.sh + '[' -z '' ']' + export DISPLAY=:0 + DISPLAY=:0 ++ uname -m + arch=aarch64 + false=false ++ grep -v '^\s//' config/config.js ++ grep -i serveronly: ++ tr -d ',"'\''' ++ awk '{print tolower($2)}' + serveronly= + serveronly=false ++ pgrep Xorg + xorg=5557 ++ uname + mac=Linux + '[' false. '!=' false. -o aarch64 == armv6l ']' + '[' 5557. == . -a Linux '!=' Darwin ']' + electron js/electron.js
please post your results
also, can u show me the output of
uname -a
and
lsb_release -athx
Many thanks, Sam!
Will do first thing in the morning.
XR
@sdetweil, did the inputs you recommended.
Following output after changing the run-start.sh file:
> magicmirror@2.10.0 start /home/pi/MagicMirror > ./run-start.sh + ./untrack-css.sh + '[' -z :0.0 ']' ++ uname -m + arch=armv7l + false=false ++ grep -v '^\s//' config/config.js ++ grep -i serveronly: ++ awk '{print tolower($2)}' ++ tr -d ',"'\''' + serveronly= + serveronly=false ++ pgrep Xorg + xorg=484 ++ uname + mac=Linux + '[' false. '!=' false. -o armv7l == armv6l ']' + '[' 484. == . -a Linux '!=' Darwin ']' + electron js/electron.js [06:29:21.444] [LOG] Starting MagicMirror: v2.10.0 [06:29:21.459] [LOG] Loading config ... [06:29:21.470] [LOG] Loading module helpers ... [06:29:21.593] [LOG] Initializing new module helper ... [06:29:21.594] [LOG] Module helper loaded: updatenotification [06:29:21.597] [LOG] No helper found for module: clock. [06:29:22.784] [LOG] Initializing new module helper ... [06:29:22.785] [LOG] Module helper loaded: calendar [06:29:22.989] [LOG] Initializing new module helper ... [06:29:22.990] [LOG] Module helper loaded: MMM-Fuel [06:29:23.274] [LOG] Initializing new module helper ... [06:29:23.275] [LOG] Module helper loaded: MMM-NetworkConnection [06:29:24.444] [LOG] Initializing new module helper ... [06:29:24.445] [LOG] Module helper loaded: MMM-DarkSkyForecast [06:29:26.327] [LOG] Initializing new module helper ... [06:29:26.328] [LOG] Module helper loaded: MMM-RTSPStream [06:29:26.415] [LOG] Initializing new module helper ... [06:29:26.416] [LOG] Module helper loaded: newsfeed [06:29:26.417] [LOG] All module helpers loaded. [06:29:26.418] [LOG] Starting server on port 8080 ... [06:29:26.445] [LOG] Server started ... [06:29:26.447] [LOG] Connecting socket for: updatenotification [06:29:26.448] [LOG] Connecting socket for: calendar [06:29:26.450] [LOG] Starting node helper for: calendar [06:29:26.451] [LOG] Connecting socket for: MMM-Fuel [06:29:26.452] [LOG] Starting module helper: MMM-Fuel [06:29:26.454] [LOG] Connecting socket for: MMM-NetworkConnection [06:29:26.455] [LOG] MMM-NetworkConnection helper started ... [06:29:26.456] [LOG] Connecting socket for: MMM-DarkSkyForecast [06:29:26.457] [LOG] ====================== Starting node_helper for module [MMM-DarkSkyForecast] [06:29:26.459] [LOG] Connecting socket for: MMM-RTSPStream [06:29:26.463] [LOG] PM2: Stopping all OMXPlayer Streams... [06:29:26.468] [LOG] Connecting socket for: newsfeed [06:29:26.470] [LOG] Starting module: newsfeed [06:29:26.470] [LOG] Sockets connected & modules started ... [06:29:27.165] [LOG] Launching application. [06:29:31.793] [LOG] Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/removed-for-privacy-reasons> [06:29:32.245] [LOG] Create new news fetcher for url: first-feed - Interval: 300000 [06:29:32.335] [LOG] Create new news fetcher for url: second-feed - Interval: 300000 [06:29:32.340] [LOG] Create new news fetcher for url: third-feed - Interval: 300000 [06:29:33.717] [LOG] starting network connection testing [06:29:34.289] [LOG] Starting stream stream1 using VLC with args --width 600 --height 340 -I dummy --video-on-top --no-video-deco --no-embedded-video --video-title=stream1 rtsp://admin:removed-for-privacy-reasons@192.168.1.41:554/11... [06:29:34.383] [INFO] DP2: Running window resizers... [06:29:36.398] [LOG] Whoops! There was an uncaught exception... [06:29:36.399] [ERROR] TypeError: Cannot convert undefined or null to object at Function.keys (<anonymous>) at stopProcs (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:469:32) at pm2.list (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:498:17) at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2/lib/API.js:606:19 at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2-axon-rpc/lib/client.js:45:10 at Parser.<anonymous> (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2-axon/lib/sockets/req.js:67:8) at Parser.emit (events.js:182:13) at Parser._write (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/amp/lib/stream.js:91:16) at doWrite (_stream_writable.js:410:12) at writeOrBuffer (_stream_writable.js:394:5) [06:29:36.408] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? [06:29:36.409] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues [06:29:41.434] [INFO] DP2: Running window resizers... [06:30:33.602] [LOG] starting network connection testing [06:31:05.984] [LOG] Whoops! There was an uncaught exception... [06:31:05.985] [ERROR] { Error: connect EHOSTUNREACH 151.101.2.219:80 at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1161:14) errno: 'EHOSTUNREACH', code: 'EHOSTUNREACH', syscall: 'connect', address: '151.101.2.219', port: 80 } [06:31:05.991] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? [06:31:05.992] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues [06:31:20.713] [LOG] Shutting down server... [06:31:20.715] [LOG] Stopping module helper: updatenotification [06:31:20.716] [LOG] Stopping module helper: calendar [06:31:20.717] [LOG] Stopping module helper: MMM-Fuel [06:31:20.718] [LOG] Stopping module helper: MMM-NetworkConnection [06:31:20.719] [LOG] Stopping module helper: MMM-DarkSkyForecast [06:31:20.721] [LOG] Shutting down MMM-RTSPStream streams that were using vlc [06:31:20.722] [LOG] Killing DevilsPie2... [06:31:20.727] [LOG] Killing All VLC Streams... [06:31:20.729] [LOG] Stopping module helper: newsfeed
Output on command ‘uname -a’:
Linux raspberrypi 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l GNU/Linux
Output on command 'lsb_release -a:
No LSB modules are available. Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
Any data I removed above from the output of the start script do not interfere with the problem.
The modules in question, RTSPStream+Calendar+Newsfeed work perfectly with the data I omitted.Many thanks again, Sam, for looking into this.
Post note: Can the issue really be the EHOSTUNREACH ?
I have not removed the MMM-NetworkConnection module from the config.js file. Yet.Best
XR -
… and no, I did the manual install.
XR
@xray2607 The error log rather hints to your streaming module being the issue
[06:29:36.399] [ERROR] TypeError: Cannot convert undefined or null to object at Function.keys () at stopProcs (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:469:32) at pm2.list (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:498:17)
Have you tried deactivating that one and restarting the mirror?
Maybe there’s a problem with both modules disturbing each other for some reason? -
@lavolp3
I will have to check that in the evening, as I have not yet disabled any of the modules.- The mirror was restarted around 40 times over the last 48h (complete reboot as well as disconnecting the PSU for 30min or so).
- Did a couple of ‘npm start dev’ sessions as well. (but I only have limited understanding of what I am seeing in the dev window)
- Individually reinstalled a couple of the modules.
- Did ‘npm audit’ and ‘npm audit fix’ (0 vulnerabilities), plus ‘npm install’ in the MagicMirror folder (again, no problems)
I am struggling with the fact that everything worked fine up to one point, and without me doing anything it stops working smoothly.
If I did anything wrong, I would like to understand the why/how in order to avoid it in the future.Going to post my findings here.
XR
ok, before changing anything else.
the manual update (git pull & npm install) leaves out a crucial step… if any of the modules need dependencies,then THEY ALSO need an npm install cycle done in their folders…
so, look thru all the module folders, if any contain a package.json file, then run npm install in each folder that does
please do check and update as required
i see both MMM-RTSPStream and MMM-NetworkConnection have that file…
MMM-RTSPStream is the module to put out the message right before the error… so… its likely that is the problem -
@sdetweil, thanks for your swift reply, will do.
@sdetweil, you are correct.
I determined that the MMM-RTSPStream module is causing the problem for sure, by cross testing the two modules.Am doing a new install of this as an update install via npm install in the appropriate module folder did not make it work again.
- re removing the screensaver/blank screen, do you know how to fix this as well?
Thank you for your help!
Best XR
u want to turn off screensaver?
if so , run the screensaveroff.sh from here
