    MM2.10 & Pi3b - run-start.sh issue? (Exit status 7, errno 7, error code ELIFECYCLE)
    12 Posts 3 Posters 3.3k Views 3 Watching
      sdetweil @xray2607
      @xray2607 said in MM2.10 & Pi3b - run-start.sh issue? (Exit status 7, errno 7, error code ELIFECYCLE):
      However, several hours later trying to get the screensaver disabled
      I’m gonna ask some questions… did u try the automated install or manual, as automated asks it u want screensaver off and then does it.
      I updated the run-start.sh script in 2.10 to do some additional work…
      can u change line 1 of runstart.sh to
      #!/bin/bash
      to
      #!/bin/bash -x
      and then do npm start from the MagicMirror folder, you might see
      > ./run-start.sh
      + ./untrack-css.sh
      + '[' -z '' ']'
      + export DISPLAY=:0
      + DISPLAY=:0
      ++ uname -m
      + arch=aarch64
      + false=false
      ++ grep -v '^\s//' config/config.js
      ++ grep -i serveronly:
      ++ tr -d ',"'\'''
      ++ awk '{print tolower($2)}'
      + serveronly=
      + serveronly=false
      ++ pgrep Xorg
      + xorg=5557
      ++ uname
      + mac=Linux
      + '[' false. '!=' false. -o aarch64 == armv6l ']'
      + '[' 5557. == . -a Linux '!=' Darwin ']'
      + electron js/electron.js
      please post your results
      also, can u show me the output of
      uname -a
      and
      lsb_release -a
      thx
      • X
        xray2607
        Many thanks, Sam!
        Will do first thing in the morning.
        XR
        • X
          xray2607
          @sdetweil, did the inputs you recommended.
          Following output after changing the run-start.sh file:
          > magicmirror@2.10.0 start /home/pi/MagicMirror
          > ./run-start.sh
          + ./untrack-css.sh
          + '[' -z :0.0 ']'
          ++ uname -m
          + arch=armv7l
          + false=false
          ++ tr -d ',"'\'''
          + serveronly=
          + serveronly=false
          ++ pgrep Xorg
          + xorg=484
          ++ uname
          + mac=Linux
          + '[' false. '!=' false. -o armv7l == armv6l ']'
          + '[' 484. == . -a Linux '!=' Darwin ']'
          [06:29:21.444] [LOG]    Starting MagicMirror: v2.10.0
          [06:29:21.459] [LOG]    Loading config ...
          [06:29:21.470] [LOG]    Loading module helpers ...
          [06:29:21.593] [LOG]    Initializing new module helper ...
          [06:29:21.594] [LOG]    Module helper loaded: updatenotification
          [06:29:21.597] [LOG]    No helper found for module: clock.
          [06:29:22.784] [LOG]    Initializing new module helper ...
          [06:29:22.785] [LOG]    Module helper loaded: calendar
          [06:29:22.989] [LOG]    Initializing new module helper ...
          [06:29:22.990] [LOG]    Module helper loaded: MMM-Fuel
          [06:29:23.274] [LOG]    Initializing new module helper ...
          [06:29:23.275] [LOG]    Module helper loaded: MMM-NetworkConnection
          [06:29:24.444] [LOG]    Initializing new module helper ...
          [06:29:24.445] [LOG]    Module helper loaded: MMM-DarkSkyForecast
          [06:29:26.327] [LOG]    Initializing new module helper ...
          [06:29:26.328] [LOG]    Module helper loaded: MMM-RTSPStream
          [06:29:26.415] [LOG]    Initializing new module helper ...
          [06:29:26.416] [LOG]    Module helper loaded: newsfeed
          [06:29:26.417] [LOG]    All module helpers loaded.
          [06:29:26.418] [LOG]    Starting server on port 8080 ...
          [06:29:26.445] [LOG]    Server started ...
          [06:29:26.447] [LOG]    Connecting socket for: updatenotification
          [06:29:26.448] [LOG]    Connecting socket for: calendar
          [06:29:26.450] [LOG]    Starting node helper for: calendar
          [06:29:26.451] [LOG]    Connecting socket for: MMM-Fuel
          [06:29:26.452] [LOG]    Starting module helper: MMM-Fuel
          [06:29:26.454] [LOG]    Connecting socket for: MMM-NetworkConnection
          [06:29:26.455] [LOG]    MMM-NetworkConnection helper started ...
          [06:29:26.456] [LOG]    Connecting socket for: MMM-DarkSkyForecast
          [06:29:26.457] [LOG]    ====================== Starting node_helper for module [MMM-DarkSkyForecast]
          [06:29:26.459] [LOG]    Connecting socket for: MMM-RTSPStream
          [06:29:26.463] [LOG]    PM2: Stopping all OMXPlayer Streams...
          [06:29:26.468] [LOG]    Connecting socket for: newsfeed
          [06:29:26.470] [LOG]    Starting module: newsfeed
          [06:29:26.470] [LOG]    Sockets connected & modules started ...
          [06:29:27.165] [LOG]    Launching application.
          [06:29:31.793] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/removed-for-privacy-reasons>
          [06:29:32.245] [LOG]    Create new news fetcher for url: first-feed - Interval: 300000
          [06:29:32.335] [LOG]    Create new news fetcher for url: second-feed - Interval: 300000
          [06:29:32.340] [LOG]    Create new news fetcher for url: third-feed - Interval: 300000
          [06:29:33.717] [LOG]    starting network connection testing
          [06:29:34.289] [LOG]    Starting stream stream1 using VLC with args --width 600 --height 340 -I dummy --video-on-top --no-video-deco --no-embedded-video --video-title=stream1 rtsp://admin:removed-for-privacy-reasons@192.168.1.41:554/11...
          [06:29:34.383] [INFO]   DP2: Running window resizers...
          [06:29:36.398] [LOG]    Whoops! There was an uncaught exception...
          [06:29:36.399] [ERROR]  TypeError: Cannot convert undefined or null to object
              at Function.keys (<anonymous>)
              at stopProcs (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:469:32)
              at pm2.list (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:498:17)
              at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2/lib/API.js:606:19
              at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2-axon-rpc/lib/client.js:45:10
              at Parser.<anonymous> (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2-axon/lib/sockets/req.js:67:8)
              at Parser.emit (events.js:182:13)
              at Parser._write (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/amp/lib/stream.js:91:16)
              at doWrite (_stream_writable.js:410:12)
              at writeOrBuffer (_stream_writable.js:394:5)
          [06:29:36.408] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          [06:29:36.409] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
          [06:29:41.434] [INFO]   DP2: Running window resizers...
          [06:30:33.602] [LOG]    starting network connection testing
          [06:31:05.984] [LOG]    Whoops! There was an uncaught exception...
          [06:31:05.985] [ERROR]  { Error: connect EHOSTUNREACH 151.101.2.219:80
              at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1161:14)
            errno: 'EHOSTUNREACH',
            code: 'EHOSTUNREACH',
            syscall: 'connect',
            address: '151.101.2.219',
            port: 80 }
          [06:31:05.991] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          [06:31:05.992] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
          [06:31:20.713] [LOG]    Shutting down server...
          [06:31:20.715] [LOG]    Stopping module helper: updatenotification
          [06:31:20.716] [LOG]    Stopping module helper: calendar
          [06:31:20.717] [LOG]    Stopping module helper: MMM-Fuel
          [06:31:20.718] [LOG]    Stopping module helper: MMM-NetworkConnection
          [06:31:20.719] [LOG]    Stopping module helper: MMM-DarkSkyForecast
          [06:31:20.721] [LOG]    Shutting down MMM-RTSPStream streams that were using vlc
          [06:31:20.722] [LOG]    Killing DevilsPie2...
          [06:31:20.727] [LOG]    Killing All VLC Streams...
          [06:31:20.729] [LOG]    Stopping module helper: newsfeed
          Output on command ‘uname -a’:
          Linux raspberrypi 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l GNU/Linux
          Output on command 'lsb_release -a:
          No LSB modules are available.
          Distributor ID:	Raspbian
          Description:	Raspbian GNU/Linux 10 (buster)
          Release:	10
          Codename:	buster
          Any data I removed above from the output of the start script do not interfere with the problem.
          The modules in question, RTSPStream+Calendar+Newsfeed work perfectly with the data I omitted.
          Many thanks again, Sam, for looking into this.
          Post note: Can the issue really be the EHOSTUNREACH ?
          I have not removed the MMM-NetworkConnection module from the config.js file. Yet.
          Best
          XR
          • X
            xray2607
            … and no, I did the manual install.
            XR
            lavolp3L S 2 Replies Last reply
            • lavolp3L
              lavolp3 Module Developer @xray2607
              @xray2607 The error log rather hints to your streaming module being the issue
                  at Function.keys ()
              Have you tried deactivating that one and restarting the mirror?
              Maybe there’s a problem with both modules disturbing each other for some reason?
              How to troubleshoot modules
              MMM-soccer v2, MMM-AVStock
              • X
                xray2607
                @lavolp3
                I will have to check that in the evening, as I have not yet disabled any of the modules.
                • The mirror was restarted around 40 times over the last 48h (complete reboot as well as disconnecting the PSU for 30min or so).
                • Did a couple of ‘npm start dev’ sessions as well. (but I only have limited understanding of what I am seeing in the dev window)
                • Individually reinstalled a couple of the modules.
                • Did ‘npm audit’ and ‘npm audit fix’ (0 vulnerabilities), plus ‘npm install’ in the MagicMirror folder (again, no problems)
                I am struggling with the fact that everything worked fine up to one point, and without me doing anything it stops working smoothly.
                If I did anything wrong, I would like to understand the why/how in order to avoid it in the future.
                Going to post my findings here.
                XR
                  sdetweil @xray2607
                  ok, before changing anything else.
                  the manual update (git pull & npm install) leaves out a crucial step… if any of the modules need dependencies,then THEY ALSO need an npm install cycle done in their folders…
                  so, look thru all the module folders, if any contain a package.json file, then run npm install in each folder that does
                  please do check and update as required
                  i see both MMM-RTSPStream and MMM-NetworkConnection have that file…
                  MMM-RTSPStream is the module to put out the message right before the error… so… its likely that is the problem
                  • X
                    xray2607
                    @sdetweil, thanks for your swift reply, will do.
                    • X
                      xray2607
                      @sdetweil, you are correct.
                      I determined that the MMM-RTSPStream module is causing the problem for sure, by cross testing the two modules.
                      Am doing a new install of this as an update install via npm install in the appropriate module folder did not make it work again.
                      • re removing the screensaver/blank screen, do you know how to fix this as well?
                      Thank you for your help!
                      Best XR
                        sdetweil @xray2607
                        u want to turn off screensaver?
                        if so , run the screensaveroff.sh from here
                        • X
                          xray2607
                          Yup, this is when I ran into the troubles.
                          Many thanks for the lift, sam.
                          Will close the issue as it is related to a ‘simple’ module install challenge …
                          XR
