Solved Magic Mirror updated now doesnt work
@bachoo786 did u also do the required npm install after the git pull??
apologize, where did u see the instructions?
many users are having this problem, want to see if I can fix that
@sdetweil I just searched on MM forum I did git pull and after that done the npm install but have problems. I cannot also access the mirror on another machine. I have forwarded the mirror ports too.
@bachoo786 ok, did the npm install good…
please edit the run-start.sh and change line 1 to
#!/bin/bash -x
save
then npm start againalso, what modules do you have installed?
if they have a package.json, did u do an npm install in those module folders? -
@sdetweil my run-start.sh already contains the # before !bin/bash-x see below:
#!/bin/bash # use bash instead of sh ./untrack-css.sh if [ -z "$DISPLAY" ]; then #If not set DISPLAY is SSH remote or tty export DISPLAY=:0 # Set by default display fi # get the processor architecture arch=$(uname -m) false='false'
all my modules have package.json and I did do a npm install. The last module I installed was mmm-remote control via the script that was on the module github page.
@bachoo786 you missed the -x at the end… turns on bash debug
#!/bin/bash -x
@bachoo786 said in Magic Mirror updated now doesnt work:
SINCE you did the magicmirror upgrade?
@sdetweil so this is the result:
pi@raspberrypi:~/MagicMirror $ npm start > magicmirror@2.10.0 start /home/pi/MagicMirror > ./run-start.sh + ./untrack-css.sh + '[' -z '' ']' + export DISPLAY=:0 + DISPLAY=:0 ++ uname -m + arch=armv7l + false=false ++ grep -v '^\s//' config/config.js ++ grep -i serveronly: ++ tr -d ',"'\''' ++ awk '{print tolower($2)}' + serveronly= + serveronly=false ++ pgrep Xorg + xorg=519 ++ uname + mac=Linux + '[' false. '!=' false. -o armv7l == armv6l ']' + '[' 519. == . -a Linux '!=' Darwin ']' + electron js/electron.js [15:39:07.703] [LOG] Starting MagicMirror: v2.10.0 [15:39:07.725] [LOG] Loading config ... [15:39:07.735] [LOG] Loading module helpers ... [15:39:07.814] [LOG] Initializing new module helper ... [15:39:07.817] [LOG] Module helper loaded: updatenotification [15:39:07.819] [LOG] No helper found for module: clock. [15:39:08.557] [LOG] Initializing new module helper ... [15:39:08.558] [LOG] Module helper loaded: MMM-SystemStats [15:39:08.559] [LOG] No helper found for module: currentweather. [15:39:08.560] [LOG] No helper found for module: weatherforecast. [15:39:08.561] [LOG] No helper found for module: random_quotes. [15:39:08.564] [LOG] Initializing new module helper ... [15:39:08.564] [LOG] Module helper loaded: MMM-homeassistant-sensors [15:39:09.297] [LOG] Initializing new module helper ... [15:39:09.298] [LOG] Module helper loaded: MMM-UKNationalRail [15:39:09.299] [LOG] No helper found for module: MMM-TFL. [15:39:09.368] [LOG] Initializing new module helper ... [15:39:09.369] [LOG] Module helper loaded: newsfeed [15:39:09.370] [LOG] All module helpers loaded. [15:39:09.372] [LOG] Starting server on port 8181 ... [15:39:09.389] [INFO] You're using a full whitelist configuration to allow for all IPs [15:39:09.408] [LOG] Server started ... [15:39:09.410] [LOG] Connecting socket for: updatenotification [15:39:09.413] [LOG] Connecting socket for: MMM-SystemStats [15:39:09.415] [LOG] Connecting socket for: MMM-homeassistant-sensors [15:39:09.418] [LOG] Connecting socket for: MMM-UKNationalRail [15:39:09.420] [LOG] MMM-UKNationalRail helper started ... [15:39:09.421] [LOG] Connecting socket for: newsfeed [15:39:09.422] [LOG] Starting module: newsfeed [15:39:09.423] [LOG] Sockets connected & modules started ... [15:39:09.587] [LOG] Whoops! There was an uncaught exception... [15:39:09.588] [ERROR] { Error: listen EADDRINUSE 127.0.0.1:8181 at Server.setupListenHandle [as _listen2] (net.js:1330:14) at listenInCluster (net.js:1378:12) at GetAddrInfoReqWrap.doListen [as callback] (net.js:1492:7) at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:55:10) errno: 'EADDRINUSE', code: 'EADDRINUSE', syscall: 'listen', address: '127.0.0.1', port: 8181 } [15:39:09.605] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? [15:39:09.605] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues [15:39:09.652] [LOG] Launching application.
so, it looks like u have another version running,
pm2 status
pm2 stop 0then npm start
@sdetweil do I have to do that? I never did update the modules after I upgraded the mirror.
yes… if the base dependencies change, then u should update the dependencies of the modules
my automated upgrade script does all this.
