    Magic Mirror updated now doesnt work
    36 Posts 2 Posters 14.1k Views 2 Watching
      sdetweil @bachoo786
      @bachoo786 how did u update? manual, git pull? or the automated script
        bachoo786 @sdetweil
        @sdetweil git pull but I had to stash as I had made changes to the .css file of one of the modules.
          sdetweil @bachoo786
          @bachoo786 did u also do the required npm install after the git pull??
          apologize, where did u see the instructions?
          many users are having this problem, want to see if I can fix that
            bachoo786 @sdetweil
            @sdetweil I just searched on MM forum I did git pull and after that done the npm install but have problems. I cannot also access the mirror on another machine. I have forwarded the mirror ports too.
              sdetweil @bachoo786
              @bachoo786 ok, did the npm install good…
              please edit the run-start.sh and change line 1 to
              #!/bin/bash -x
              save
              then npm start again
              also, what modules do you have installed?
              if they have a package.json, did u do an npm install in those module folders?
                bachoo786 @sdetweil
                @sdetweil my run-start.sh already contains the # before !bin/bash-x see below:
                #!/bin/bash
                  # use bash instead of sh
                ./untrack-css.sh
                if [ -z "$DISPLAY" ]; then #If not set DISPLAY is SSH remote or tty
                        export DISPLAY=:0 # Set by default display
                fi
                # get the processor architecture
                arch=$(uname -m)
                false='false'
                all my modules have package.json and I did do a npm install. The last module I installed was mmm-remote control via the script that was on the module github page.
                  sdetweil @bachoo786
                  @bachoo786 you missed the -x at the end… turns on bash debug
                  #!/bin/bash -x
                    sdetweil @bachoo786
                    @bachoo786 said in Magic Mirror updated now doesnt work:
                    SINCE you did the magicmirror upgrade?
                      bachoo786 @sdetweil
                      @sdetweil so this is the result:
                      > magicmirror@2.10.0 start /home/pi/MagicMirror
                      > ./run-start.sh
                      + ./untrack-css.sh
                      + '[' -z '' ']'
                      + export DISPLAY=:0
                      + DISPLAY=:0
                      ++ uname -m
                      + arch=armv7l
                      + false=false
                      ++ grep -v '^\s//' config/config.js
                      ++ grep -i serveronly:
                      ++ tr -d ',"'\'''
                      ++ awk '{print tolower($2)}'
                      + serveronly=
                      + serveronly=false
                      ++ pgrep Xorg
                      + xorg=519
                      ++ uname
                      + mac=Linux
                      + '[' false. '!=' false. -o armv7l == armv6l ']'
                      + '[' 519. == . -a Linux '!=' Darwin ']'
                      + electron js/electron.js
                      [15:39:07.703] [LOG]    Starting MagicMirror: v2.10.0
                      [15:39:07.725] [LOG]    Loading config ...
                      [15:39:07.735] [LOG]    Loading module helpers ...
                      [15:39:07.814] [LOG]    Initializing new module helper ...
                      [15:39:07.817] [LOG]    Module helper loaded: updatenotification
                      [15:39:07.819] [LOG]    No helper found for module: clock.
                      [15:39:08.557] [LOG]    Initializing new module helper ...
                      [15:39:08.558] [LOG]    Module helper loaded: MMM-SystemStats
                      [15:39:08.559] [LOG]    No helper found for module: currentweather.
                      [15:39:08.560] [LOG]    No helper found for module: weatherforecast.
                      [15:39:08.561] [LOG]    No helper found for module: random_quotes.
                      [15:39:08.564] [LOG]    Initializing new module helper ...
                      [15:39:08.564] [LOG]    Module helper loaded: MMM-homeassistant-sensors
                      [15:39:09.297] [LOG]    Initializing new module helper ...
                      [15:39:09.298] [LOG]    Module helper loaded: MMM-UKNationalRail
                      [15:39:09.299] [LOG]    No helper found for module: MMM-TFL.
                      [15:39:09.368] [LOG]    Initializing new module helper ...
                      [15:39:09.369] [LOG]    Module helper loaded: newsfeed
                      [15:39:09.370] [LOG]    All module helpers loaded.
                      [15:39:09.372] [LOG]    Starting server on port 8181 ...
                      [15:39:09.389] [INFO]   You're using a full whitelist configuration to allow for all IPs
                      [15:39:09.408] [LOG]    Server started ...
                      [15:39:09.410] [LOG]    Connecting socket for: updatenotification
                      [15:39:09.413] [LOG]    Connecting socket for: MMM-SystemStats
                      [15:39:09.415] [LOG]    Connecting socket for: MMM-homeassistant-sensors
                      [15:39:09.418] [LOG]    Connecting socket for: MMM-UKNationalRail
                      [15:39:09.420] [LOG]    MMM-UKNationalRail helper started ...
                      [15:39:09.421] [LOG]    Connecting socket for: newsfeed
                      [15:39:09.422] [LOG]    Starting module: newsfeed
                      [15:39:09.423] [LOG]    Sockets connected & modules started ...
                      [15:39:09.587] [LOG]    Whoops! There was an uncaught exception...
                      [15:39:09.588] [ERROR]  { Error: listen EADDRINUSE 127.0.0.1:8181
                          at Server.setupListenHandle [as _listen2] (net.js:1330:14)
                          at listenInCluster (net.js:1378:12)
                          at GetAddrInfoReqWrap.doListen [as callback] (net.js:1492:7)
                          at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:55:10)
                        errno: 'EADDRINUSE',
                        code: 'EADDRINUSE',
                        syscall: 'listen',
                        address: '127.0.0.1',
                        port: 8181 }
                      [15:39:09.605] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                      [15:39:09.605] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                      [15:39:09.652] [LOG]    Launching application.
                        sdetweil @bachoo786
                        so, it looks like u have another version running,
                        pm2 status
                        pm2 stop 0
                        then npm start
                        • 1 / 4
