    Magic Mirror updated now doesnt work
    36 Posts 2 Posters 16.1k Views 2 Watching
      bachoo786 @sdetweil
      @sdetweil I just searched on MM forum I did git pull and after that done the npm install but have problems. I cannot also access the mirror on another machine. I have forwarded the mirror ports too.
        sdetweil @bachoo786
        @bachoo786 ok, did the npm install good…
        please edit the run-start.sh and change line 1 to
        #!/bin/bash -x
        save
        then npm start again
        also, what modules do you have installed?
        if they have a package.json, did u do an npm install in those module folders?
          bachoo786 @sdetweil
          @sdetweil my run-start.sh already contains the # before !bin/bash-x see below:
          #!/bin/bash
            # use bash instead of sh
          ./untrack-css.sh
          if [ -z "$DISPLAY" ]; then #If not set DISPLAY is SSH remote or tty
                  export DISPLAY=:0 # Set by default display
          fi
          # get the processor architecture
          arch=$(uname -m)
          false='false'
          all my modules have package.json and I did do a npm install. The last module I installed was mmm-remote control via the script that was on the module github page.
            sdetweil @bachoo786
            @bachoo786 you missed the -x at the end… turns on bash debug
            #!/bin/bash -x
              sdetweil @bachoo786
              @bachoo786 said in Magic Mirror updated now doesnt work:
              SINCE you did the magicmirror upgrade?
                bachoo786 @sdetweil
                @sdetweil so this is the result:
                > magicmirror@2.10.0 start /home/pi/MagicMirror
                > ./run-start.sh
                + ./untrack-css.sh
                + '[' -z '' ']'
                + export DISPLAY=:0
                + DISPLAY=:0
                ++ uname -m
                + arch=armv7l
                + false=false
                ++ grep -v '^\s//' config/config.js
                ++ grep -i serveronly:
                ++ tr -d ',"'\'''
                ++ awk '{print tolower($2)}'
                + serveronly=
                + serveronly=false
                ++ pgrep Xorg
                + xorg=519
                ++ uname
                + mac=Linux
                + '[' false. '!=' false. -o armv7l == armv6l ']'
                + '[' 519. == . -a Linux '!=' Darwin ']'
                + electron js/electron.js
                [15:39:07.703] [LOG]    Starting MagicMirror: v2.10.0
                [15:39:07.725] [LOG]    Loading config ...
                [15:39:07.735] [LOG]    Loading module helpers ...
                [15:39:07.814] [LOG]    Initializing new module helper ...
                [15:39:07.817] [LOG]    Module helper loaded: updatenotification
                [15:39:07.819] [LOG]    No helper found for module: clock.
                [15:39:08.557] [LOG]    Initializing new module helper ...
                [15:39:08.558] [LOG]    Module helper loaded: MMM-SystemStats
                [15:39:08.559] [LOG]    No helper found for module: currentweather.
                [15:39:08.560] [LOG]    No helper found for module: weatherforecast.
                [15:39:08.561] [LOG]    No helper found for module: random_quotes.
                [15:39:08.564] [LOG]    Initializing new module helper ...
                [15:39:08.564] [LOG]    Module helper loaded: MMM-homeassistant-sensors
                [15:39:09.297] [LOG]    Initializing new module helper ...
                [15:39:09.298] [LOG]    Module helper loaded: MMM-UKNationalRail
                [15:39:09.299] [LOG]    No helper found for module: MMM-TFL.
                [15:39:09.368] [LOG]    Initializing new module helper ...
                [15:39:09.369] [LOG]    Module helper loaded: newsfeed
                [15:39:09.370] [LOG]    All module helpers loaded.
                [15:39:09.372] [LOG]    Starting server on port 8181 ...
                [15:39:09.389] [INFO]   You're using a full whitelist configuration to allow for all IPs
                [15:39:09.408] [LOG]    Server started ...
                [15:39:09.410] [LOG]    Connecting socket for: updatenotification
                [15:39:09.413] [LOG]    Connecting socket for: MMM-SystemStats
                [15:39:09.415] [LOG]    Connecting socket for: MMM-homeassistant-sensors
                [15:39:09.418] [LOG]    Connecting socket for: MMM-UKNationalRail
                [15:39:09.420] [LOG]    MMM-UKNationalRail helper started ...
                [15:39:09.421] [LOG]    Connecting socket for: newsfeed
                [15:39:09.422] [LOG]    Starting module: newsfeed
                [15:39:09.423] [LOG]    Sockets connected & modules started ...
                [15:39:09.587] [LOG]    Whoops! There was an uncaught exception...
                [15:39:09.588] [ERROR]  { Error: listen EADDRINUSE 127.0.0.1:8181
                    at Server.setupListenHandle [as _listen2] (net.js:1330:14)
                    at listenInCluster (net.js:1378:12)
                    at GetAddrInfoReqWrap.doListen [as callback] (net.js:1492:7)
                    at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:55:10)
                  errno: 'EADDRINUSE',
                  code: 'EADDRINUSE',
                  syscall: 'listen',
                  address: '127.0.0.1',
                  port: 8181 }
                [15:39:09.605] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                [15:39:09.605] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                [15:39:09.652] [LOG]    Launching application.
                  sdetweil @bachoo786
                  so, it looks like u have another version running,
                  pm2 status
                  pm2 stop 0
                  then npm start
                    bachoo786 @sdetweil
                    @sdetweil do I have to do that? I never did update the modules after I upgraded the mirror.
                      sdetweil @bachoo786
                      yes… if the base dependencies change, then u should update the dependencies of the modules
                      my automated upgrade script does all this.
                        bachoo786
                        @sdetweil nope its only one version
                          sdetweil @bachoo786
                          @bachoo786 version = instance… sorry
                          pm2 status
                          if something is running, shut it down
                            bachoo786 @sdetweil
                            @sdetweil ok so what shall I do now? I am lost. I always avoid updating my magicmirror as the new update always breaks it.
                              sdetweil @bachoo786
                              @bachoo786
                              please read my posts
                              do
                              pm2 status
                              if anything is running, not stopped then do
                              pm2 stop ??
                              where xx is the name or number of the item running
                              once u have nothing running, then redo the npm start from the MagicMirror folder so we can diagnose the rest of the problem
                                bachoo786 @sdetweil
                                @sdetweil ok I have done that and here is the result:
                                > ./run-start.sh
                                + ./untrack-css.sh
                                + '[' -z '' ']'
                                + export DISPLAY=:0
                                + DISPLAY=:0
                                ++ uname -m
                                + arch=armv7l
                                + false=false
                                ++ tr -d ',"'\'''
                                + serveronly=
                                + serveronly=false
                                ++ pgrep Xorg
                                + xorg=519
                                ++ uname
                                + mac=Linux
                                [15:51:26.871] [LOG]    Starting MagicMirror: v2.10.0
                                [15:51:26.879] [LOG]    Loading config ...
                                [15:51:26.884] [LOG]    Loading module helpers ...
                                [15:51:26.924] [LOG]    Initializing new module helper ...
                                [15:51:26.925] [LOG]    Module helper loaded: updatenotification
                                [15:51:26.926] [LOG]    No helper found for module: clock.
                                [15:51:27.306] [LOG]    Initializing new module helper ...
                                [15:51:27.306] [LOG]    Module helper loaded: MMM-SystemStats
                                [15:51:27.307] [LOG]    No helper found for module: currentweather.
                                [15:51:27.308] [LOG]    No helper found for module: weatherforecast.
                                [15:51:27.308] [LOG]    No helper found for module: random_quotes.
                                [15:51:27.310] [LOG]    Initializing new module helper ...
                                [15:51:27.311] [LOG]    Module helper loaded: MMM-homeassistant-sensors
                                [15:51:27.697] [LOG]    Initializing new module helper ...
                                [15:51:27.698] [LOG]    Module helper loaded: MMM-UKNationalRail
                                [15:51:27.699] [LOG]    No helper found for module: MMM-TFL.
                                [15:51:27.735] [LOG]    Initializing new module helper ...
                                [15:51:27.735] [LOG]    Module helper loaded: newsfeed
                                [15:51:27.736] [LOG]    All module helpers loaded.
                                [15:51:27.737] [LOG]    Starting server on port 8181 ...
                                [15:51:27.744] [INFO]   You're using a full whitelist configuration to allow for all IPs
                                [15:51:27.750] [LOG]    Server started ...
                                [15:51:27.751] [LOG]    Connecting socket for: updatenotification
                                [15:51:27.752] [LOG]    Connecting socket for: MMM-SystemStats
                                [15:51:27.753] [LOG]    Connecting socket for: MMM-homeassistant-sensors
                                [15:51:27.754] [LOG]    Connecting socket for: MMM-UKNationalRail
                                [15:51:27.754] [LOG]    MMM-UKNationalRail helper started ...
                                [15:51:27.755] [LOG]    Connecting socket for: newsfeed
                                [15:51:27.756] [LOG]    Starting module: newsfeed
                                [15:51:27.756] [LOG]    Sockets connected & modules started ...
                                [15:51:27.943] [LOG]    Launching application.
                                [15:51:29.943] [LOG]    Create new news fetcher for url: http://feeds.bbci.co.uk/news/england/rss.xml - Interval: 300000
                                [15:51:29.984] [LOG]    Create new news fetcher for url: http://feeds.skynews.com/feeds/rss/world.xml - Interval: 300000
                                  sdetweil @bachoo786
                                  @bachoo786 ok, so the node_helper side is working ok…
                                  now open the developers window, ctrl-shift-i, select the console tab, and scroll up to see any errors
                                    bachoo786 @sdetweil
                                    @sdetweil I dont have access to the mirror now as I am not home. The thing that stopped working was when I updated MM I cannot access it anymore remotely. Before updating mm I could as my ports are also forwarded.
                                      sdetweil @bachoo786
                                      i don’t understand that. update app has nothing to do with ssh type access…
                                      if u mean MMM-remotecontrol type access, correct, the mirror app is down for some reason… that is what we are debugging
                                        from the prior message, the backend is happy (node_helpers, web server)
                                          bachoo786 @sdetweil
                                          @sdetweil I mean when I updated my to 2.10 that’s when all the problem started. Before updating my I installed mmm remote control now I don’t know if that module has caused this issue of me not being able to access magic mirror remotely.
                                            sdetweil @bachoo786
                                            @bachoo786 ok. we need to see the front end console log thru the dev window
